Page 1 of 2 12 LastLast
Results 1 to 10 of 17
  1. #1
    Gold Member 204saskman's Avatar
    Join Date
    Jun 2009
    Posts
    322
    Kelliher, Saskatchewan, Canada
    Montana 2844R Hst
    Default PTO leaf blower
    So i had a thread on this a while ago and i built one but it didnt last long(the test and the squirl cage blew apart. So i have gone back to square one and decided to start over again. Now i recently started a new job and the place i work at has a pretty big scrap/bone/parts yard. Now as i was out there the other day i noticed a air mover(about 20" fan and 12" wide) and it is connected to a 5hp electric motor. Now i was sizing this unit up as it has been demmed scrap(they bought about 6 different sizes before they got the right size. Now my questions are the electric motor is rated at 3490 rpm and my tractor only has 540 rpm. So what my question is, is there a speed increasing gear box(i was thinking of something that is 1-6 increase(540 in and 3240 out.). But i have been looking around and it seems that most of them are lik 40-1 or 20-1 or odd sizes like that. If anyone can point me in the right direction it would be helpful.
    Montna 2844R W/FEL with quick attach LDR 400hrs
    96" Home made Chain harrows
    Line ripper/trencher/ sub soiler
    Home built 10' sprayer
    72" Home built snow pusher
    72" HD landscape rake
    60" Farmking 2 stage snow blower
    55" Rototiller
    78" Bush hog disk harrow
    Quick hitch
    2002 kobelco SR35-2 mini excavator 3550 hrs
    24" tooth bucket
    16" tooth bucket
    44" clean up bucket
    Hydralic thumb
    Ripper tooth
  2. #2
    Member
    Join Date
    May 2011
    Posts
    42
    Sunshine coast British Coloumbia
    Kubota tbd
    Default Re: PTO leaf blower
    rotary mowers or some silage harvesters have the gear boxes you are thinking of...
    1990 Toyota Hilux 2.8 td crewcab
    BMW K1300R
    Kubota kx161
    Kubota U15
  3. #3
    Join Date
    Jun 2009
    Posts
    322
    Montana 2844R Hst
    Ya and i have been trying to find one but not having any luck. I might have figured it out that i can build it with some pullys and belts.
    55" Rototiller
    Quick hitch
    24" tooth bucket
    16" tooth bucket
    44" clean up bucket
    Hydralic thumb
    Ripper tooth
  4. #4
    New Member
    Join Date
    Nov 2011
    Posts
    3
    Ocala FL
    JD 5103
    A gearbox off of a pto generator will do it. I bought mine from Central Georgia Generator. They have a website but I dont know how to add a link for it.
  5. #5
    Gold Member GE222's Avatar
    Join Date
    Mar 2009
    Posts
    369
    Northern Illinois
    One big advantage of the belt and sheave drive is the ability to make adjustments for different speeds. Look and the fan curves for your fan. The hp and speed requirements will vary greatly based on both the CFM and static pressure.
  6. #6
    New Member
    Join Date
    Apr 2012
    Posts
    8
    Wausau, WI
    simplicity 4041
    On our family farm yrs back(1974) my Dad built a blower for our large maple tree filled yard and this is what he did. Bought a used Kools KB 60 silo blower at auction for $250. Torched the apron and feed auger and related off so just the fan and frame with wheels remained, put a screen over where the silage used to enter the fan. Rotated the band housing so the 8" outlet was parrallel to the ground and took 2 steel grain shovels and cut and welded them (face to face with 8" inlet pipe) into a nozzel 4" above the ground.
    I pulled that around with a 32hp WD allis and it moved leaves a good 60-70' no problem in in 1 hr our 3 acre lawn was done.
    Cheap, easy and 100% effective and no calculator needed to figure out ratio's and things. I still see these laying around farmyards and junkyards all over.
  7. #7
    Super Member schmism's Avatar
    Join Date
    Jul 2006
    Posts
    5,096
    Peoria IL
    New holland TC(33)
    Steve - TC33D 4x4 FEL, dual rear remotes with toys
  8. #8
    Join Date
    Jun 2009
    Posts
    322
    Montana 2844R Hst
    Quote Originally Posted by schmism View Post
    would but the motor is 3 phase. And i have been looking for a silo blower for over a year and it is very difficult to find one in 540. Lots around that are a 1000 but hardly n e with 540. Like i said i did some reading on these at work and they move alot of air(will move something like 9000 cfm at 3480rpm). Im gonna try and figure this all out and ill try to keep tack of this and post it as i go.
    55" Rototiller
    Quick hitch
    24" tooth bucket
    16" tooth bucket
    44" clean up bucket
    Hydralic thumb
    Ripper tooth
  9. #9
    New Member
    Join Date
    Apr 2012
    Posts
    8
    Wausau, WI
    simplicity 4041
    Take a drive down here to Wausau, WI 54401 because I know where there 3 silo blowers within 5 mi from my house, and 1 has a bad bearing and he will sell that 54" Fox for $50. Another is a JD 60" and the guys out of farming now and $100 would get that and thats in ok shape. Plus at the auto junkyard by me is a Gehl , missing the pto shaft but spins nice and smooth and $25 will do the job. If your just moving air any 60" or smaller your Montana will work just fine and will keep a big smile on your face when using it!
  10. #10
    Join Date
    Jun 2009
    Posts
    322
    Montana 2844R Hst
    ya but its the 1000 bucks in diesel to get me there is the issue lol alough it would be nice vacation
    55" Rototiller
    Quick hitch
    24" tooth bucket
    16" tooth bucket
    44" clean up bucket
    Hydralic thumb
    Ripper tooth
Similar Threads
  1. Snow Attachments Hydraulic conversion of a PTO snow blower
    By drmac in forum Snow Removal
    Last Post: 07-13-2014, 12:30 AM
  2. Silo blower converted to leaf blower
    By shawn1533 in forum Build-It Yourself
    Last Post: 10-24-2011, 10:19 PM
  3. hydraulic pump on PTO for front snow blower
    By jeffgreef in forum Hydraulics
    Last Post: 01-05-2010, 12:23 AM
  4. Cheap way to make a PTO leaf blower
    By Maxwell in forum Attachments
    Last Post: 10-30-2003, 09:04 AM
  5. Chipper 3pt Chipper
    By cmhyland in forum Attachments
    Last Post: 02-10-2003, 06:04 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
