Results 1 to 8 of 8
  1. #1
    New Member stormdodger's Avatar
    Join Date
    Aug 2009
    Posts
    8
    western canada
    kx 121-2 and looking for a estate tractor
    Default Another set of pallet forks
    I made a set of pallet forks for my 2320 and I must say I can't believe how much I use them. Bought the forks from a steel recycler, they were bent up but was able to straighten them in our press.
    I also had a machine shop cut a 1 3/8" bar and make 5 boss's up for the forks to slid on. I would say it cost about $ 300 and only took a couple of evenings to fab up. Beats paying $1200 at the dealership.!!!!!
  2. #2
    Join Date
    Jan 2001
    Posts
    1,250
    Alberta
    Kubota B2410 with turfs
    Default Re: Another set of pallet forks
    Looks great!! Would sure like a set just like that.
    Kevin
  3. #3
    Join Date
    Jan 2010
    Posts
    87
    Ontario
    Kioti CK20
    Looks great. I use mine as much as the bucket. I would suggest adding some sort of back-stop to avoid having things roll back onto you or your tractor's hood. It would also help for moving brush and things like that.
  4. #4
    Join Date
    Oct 2005
    Posts
    615
    3320 w/cab
    Quote Originally Posted by EGo_SmAsH View Post
    Looks great, but how did you build the quick attach for the bucket. Seems like the hardest part I have tried to build.
  5. #5
    Join Date
    Aug 2009
    Posts
    8
    western canada
    Default
    Great idea. I will have to modify .....
  6. #6
    Join Date
    Aug 2009
    Posts
    8
    western canada
    Default
    Quote Originally Posted by tglass
    I bent the hooks using the press. Worked out not bad! I added extra 4 inch square tube for the pin lock so the level indicator would match the fork when it is on the ground,just like the bucket! Make sense....lol
  7. #7
    Elite Member Bob77064's Avatar
    Join Date
    Sep 2011
    Posts
    3,110
    KY @ TN line
    2011 LS R3039
    Good job, looks great.
  8. #8
    Join Date
    Feb 2012
    Posts
    538
    sioux city, ia
    Oliver 1855, Case 1840, Cub 1550
    Nice job! You could add a grapple to it, for a future project
Similar Threads
  1. Another Set of Homemade Pallet Forks
    By gkh7890 in forum Attachments
    Last Post: 07-20-2011, 05:10 PM
  2. Another set of clamp on pallet forks
    By vic4news in forum Build-It Yourself
    Last Post: 01-11-2009, 03:22 PM
  3. Forks Who has a set of JD pallet forks for 430 loader???
    By swa240z in forum Attachments
    Last Post: 08-18-2003, 09:21 PM
  4. what a real mans set of pallet forks look like
    By markct in forum Build-It Yourself
    Last Post: 04-13-2003, 11:14 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
