gardrail
Greetings,
I just registered the other night, and thought I'd post one of my projects. With the cost of heating going through the roof, and my cousin having a few hundred gallons of waste motor oil laying around, i thought I'd make an attempt of building a hot water heating system to beef up the heat in my garage and downdstairs when it gets cold.
The basic idea behind this is to get a large pipe, run some exhaust pipes up through it and cap the top and bottom with water tight welds. There will be two 2" bungs to allow for water circulation through the system...
During a salvage yard run, I managed to score some 16" diameter 1/2" wall pipe, and some 1/2" steel plate to serve as both a top & bottom cap of the boiler. The exhaust pipes that will take hot gas from the waste oil burner, up through the boiler is some 1" black iron pipe.
I'll have to upload some pictures later, but so far the top and bottom plates have been cut, and the 5 holes in each side cut out to accommodate the black iron pipe. The pipes have been tack welded in, and just tonight I managed to get an old stick welder out and weld up the pipes in the bottom plate. Keep in mind that this is my second welding project and I've only been welding for a couple months.
In the grand scheme of things, I want to have a cast iron radiator in the garage and setup radiant floor heating in the downstairs of my home. I figure the hard part will be building the boiler and making it water tight. After that I'll focus on an intermediate holding tank for the hot water (since the unit itself will only hold ~ 17 gallons), and running the PEX into the house about 50' away from the burner.
Managed to score pipe for the chimney (8"), and enough 16" diameter pipe to make a few boilers (and a nice piece of 1/2" plate)
Had to burn the paint/tar off of the casing (24" tall x 16" diameter)
The boiler core with the five 1" diameter exhaust pipes running through it tacked in place. will MMA it with 6011 to hopefully make a water tight seal
