Results 1 to 5 of 5
08-08-2012, 11:36 PM #1New Member
- Join Date
- Aug 2012
- Posts
- 2
- Location
- Nacogdoches Tx
- Tractor
- Case
pole barn header question
I am building a monitor style pole barn. I have a question about setting the headers for the shed portions of the barn. The sheds are 12'6" wide and are on a 3/12 pitch. I have noticed several builders put a 2X10 on each side of the post. Is this better than doubling the 2x10s and notching the post. Also the birds notch would have to be 8 1/2 inches to hit both headers. I know this would be quicker, but not sure about stronger. Anyone have any insight on which method is better. Does anyone have any experience using the reservoir type water level. I just built one and noticed sometimes it gets an air buble in it. Any advice would be appreciated.
08-09-2012, 06:19 AM #2Platinum Member
- Join Date
- Sep 2009
- Posts
- 546
- Location
- Maryland
- Tractor
- Massey Ferguson 2615 48hp, 4wd, loader
Re: pole barn header question
I put mine on either side of the the post, held them temporarity in place with a couple of 12 pennies and then secured them with 2- 1/2"x10" galvenized carriage bolts. My situation is a little different than yours as I used scissor trusses for the roof and rested the bottom chord on the double 2x12 Southern Yellow Pine Beams for a 24 foot span.
I don't know if have been of any help, but I have know doubt there are plenty of real carpenters out there who will be.
3/12 sounds awfully shallow, what are you using for roofing?
Hope you're enjoying your project, I sure did enjoy mine.Gear Up and Throttle Down.
2011 Massey 2615, 7ft Woods Rear Discharge Finish Mower, 6 ft Lucknow Snow Blower, Danuser post hole digger with 12" and 24" augers, 350 lb 3 pt broadcast spreader, 7ft scraper blade, 7 ft. drag harrow, JD GT 275 rider with 38" snow blower attachment.
08-09-2012, 06:52 AM #3
I think either method would work, but I think the board on the inside and one on the outside looks better than a double on the outside.
Also, another reason they put one on the inside and outsude (and this may not apply to your plans) is that it sandwiches a 2x6 nicely or a knee brace and supports it on both sides".........there is only one way to find out."
"Ok, hold my beer and watch this.........."
Ford 5500 Backhoe
Kubota L3400GST W/LA463 FEL
2005 Dodge 3500 4x4 Diesel
8N Rebuilt and restored
Bushhog 105 and 306 cutters
JD 261 3PH mower
3 Homemade wood hauling trailers
Dolmar 7900
Dolmar 6400 84cc ported BB kit and Muffler Modded
Sachs-Dolmar 120SI Ported
(4) Sachs-Dolmar 116SI Ported
Dolmar PS540
Sachs-Dolmar 115i
Sachs-Dolmar 117
Sachs-Dolmar 112
Dolmar 350 "dads"
08-09-2012, 07:39 AM #4
I prefer notching both sides. It gives you a great way to put knee braces, also you can use a 2x to tie very easy to your rafter tail.
Army Grunt"Be who you are, say what you will, those that matter wont mind, those that mind don't matter".
11-28-2012, 11:07 PM #5
1. Doubling up on the same side is stronger if you put some 16ds thru both headers to make the two boards a single unit. (Not needed though)
2. Notching the post is stronger than a face connection (Again not needed)
3. Notching is a slower process than face attachment is speed of construction is a consideration
Similar Threads
Pole barn header (top grit)
By mtDanE in forum Build-It YourselfReplies: 10Last Post: 09-16-2011, 09:57 AM -
Pole Barn, Pole Question
By HoustonBrama in forum ProjectsReplies: 24Last Post: 07-27-2008, 05:15 PM -
pole barn question??
By WiJC in forum Rural LivingReplies: 11Last Post: 03-25-2005, 09:18 AM -
pole barn header question?
By mopower440 in forum ProjectsReplies: 7Last Post: 11-22-2003, 07:08 PM -
Pole Barn Question
By mytoys in forum ProjectsReplies: 28Last Post: 10-17-2003, 10:58 AM
