Results 11 to 15 of 15
09-26-2012, 11:29 PM #11Platinum Member
- Join Date
- Feb 2007
- Posts
- 673
Re: Log Lift Table
about the best two photos that show the base, the splitter started out as a three point unit ran off the tractor Hydraulics, and welded a plate to the three point frame, and mounted the HF crane on it,
the unit was only about $130 and shipping I think was only $6 on it, the log grapple is from northern and was about $30, do not remember the shipping, but had that for loading the rounds, as I have another HF crane on the S10, and my grand son likes to help reel them in,
just for info the power pack is removable for other uses, (use it on the wire roller, have used it to run hydraulic on machine with out the tractor, have used it on other wire type roller for rolling up cable, and can still be used on the three point if needed, built the power pack after fuel got expensive, and my SIL need it one time so that is when the axle and tires were added,
09-27-2012, 06:43 AM #12
10-07-2012, 04:52 AM #13
Re: Log Lift Table
You might be able to get one of those 2000 pound winches from HF and mount on your setup. It looks like they are on sale again for $59.99. Then you wouldn't even have to do any cranking.
12V Winch - ATV/UTV Winch with Load-Holding BrakeCCY Sc2400
Woods PHD35
Very Old 60" BB
Harbor Freight QH
EF115 Flail Mower
BX42s Chipper
County Line Carry-All
County Line (Tarter Gate) 48" Tiller
Homemade 60" Dethatcher
10-07-2012, 09:25 AM #14Bronze Member
- Join Date
- Jun 2011
- Posts
- 60
- Tractor
- TYM 350
Re: Log Lift Table
The least costly method for a log lift attachment is to use a electric winch. This one is self supported.
100 0123 - YouTube
Here is a pic of a attached electric lift.
10-07-2012, 02:34 PM #15
Re: Log Lift Table
Nice setup, but I've always thought the manual jack on those would be slow and tiring to use. You've got a hydraulic pump right there for the splitter - why not add another valve (with relief) and replace the jack with a hyd cylinder? Then you can use the hydraulics to run it faster and easier than it is now. Or perhaps you use the winch for most of the lifting and the jack isn't a big deal? I still think that you have hydraulics right there, it's a shame not to use them to the fullest...
-Dave
"Being a pessimist is great. You can't lose. Either you end up being right...or you are pleasantly surprised."
L3130HST, QA, 723 Loader, 48" Forks, 48" Grapple, Ancient Farmi Skidding winch
Trailer - 10k/16' twin axle w/elec brakes
2005 F250 5.4V8(3V) 3.73/4wd tow vehicle
Similar Threads
Log splitter with lift table and 4 way wedge
By sharp101 in forum Build-It YourselfReplies: 36Last Post: 05-09-2013, 07:35 AM -
Old table saw table used as a welding table
By wstf2 in forum WeldingReplies: 10Last Post: 09-23-2011, 09:26 AM -
Log lift cylinder
By sly601 in forum HydraulicsReplies: 3Last Post: 04-12-2010, 09:01 PM -
Built a new log lift
By Window Geek in forum Build-It YourselfReplies: 3Last Post: 11-17-2008, 11:08 AM -
Table saw / router table combination question
By ejb in forum Build-It YourselfReplies: 18Last Post: 05-18-2005, 07:05 PM
