Results 1 to 9 of 9
09-26-2012, 07:45 PM #1Gold Member
- Join Date
- Mar 2008
- Posts
- 475
PTO Lawn Vacuum Completed
Done just in time for the falling pine needles. I realize the capacity isn't going to be great but I only do the areas under the pine trees, not lawn clippings. It is designed to come apart easily with minimal bolts, mostly slip fittings. The combination of lawn mower blades and the fan produce an amazing amount of air movement. I can retire the leaf rake at last.
09-26-2012, 09:53 PM #2Gold Member
- Join Date
- Dec 2010
- Posts
- 303
- Location
- Central Pa
- Tractor
- NH Boomer 1025
Re: PTO Lawn Vacuum Completed
Looks nice, how did you make the blower unit.
09-26-2012, 09:56 PM #3
Looks good.
09-27-2012, 10:28 AM #4Gold Member
- Join Date
- Mar 2008
- Posts
- 475
The drum came from a friend that had a walk behind unit he disassembled. The rotar is pretty aggresive, 12" diameter, 4" wide paddles that taper to 2" in the center, ( 4 of them ), and spins in excess of three thousand rpm. The tube is eight inches in diameter. Total investment of $149.00 with some parts in stock. Wood structure may be temporary as it can be duplicated in light sheet metal. Metal parts to be painted after it is a proven design.
09-28-2012, 07:05 PM #5Elite Member
- Join Date
- Dec 2007
- Posts
- 3,543
- Location
- Ohio
- Tractor
- JD 5520, 790 TLB-- Kub L4300, B7800, MX5100
That is really an amazing build. Congratulations.
Any photos of the build process? How does it work so far?******
Don't sweat the small stuff...
10-03-2012, 12:59 PM #6New Member
- Join Date
- Dec 2011
- Posts
- 4
- Location
- South Mills, NC
- Tractor
- Kubota bx1500
Very nice build.
10-03-2012, 07:25 PM #7Gold Member
- Join Date
- Mar 2008
- Posts
- 475
I have an area approximately 9" x 18" with window screen to release the air the fan produces to the holding area. This is clearly not enough venting as air is forced out by the containers holding the leaves as well. The metal fan does a good job of grinding up the maple leafs compacting them in the holders. It doesn't pickup a hundred percent so I am going to try a set of high lift or gator blades to see if it increases the vacuum under the deck. Overall I think it works good for the intended purpose. If one was doing an entire lawn ( like mine 6 plus acres ) the storage bins would definately have to be increased. The mobility is the plus side of the attachment not having to worry about a trailer striking trees / fences in close proximity to the deck while making sharp turns. I thought the fan would take a notable amount of power to operate but it is not noticable in normal grass trimming.
The next project will be fabing a mount for a 59" snowblower to the 4110. I already have a counter weight constructed for this purpose.
10-04-2012, 09:14 AM #8
Don
MF GC2400, FEL, 60in.MMM, 5ft. Cultivator, Single Bottom Plow, Bush Hog RTC48 tiller, MF 2360 front mount snowblower, 5ft backblade. BXpanded Piranha toothbar.
10-04-2012, 10:10 PM #9Gold Member
- Join Date
- Mar 2008
- Posts
- 475
I have a clean out door on the top that is hinged. I opened it about 3/4" and it did seem to solve the air movement problem. I do have to nominate myself for " Dummy of the day ". It seems I was so zeroed in on the rear vacuum ( and the howl of the fan ) I hardly noticed the mid mounted mower was not engaged. It seems the deere has three positions for the PTO, mid, mid and rear, and rear. I had the selector on rear for testing and while noting it was only picking up approximately sixty percent of the pine needles the mid mounted mower was not assisting in the task. To my surprise when the PTO lever was shifted to the center position it was like adding a supercharger. It leaves no pine needles behind and cuts them in fine pieces packing them in the drums. Below 2000 RPM it will back up in the pipe and eventually plug. At 2500 they arrive in the drum at supersonic speeds. No need for high lift blades ... just a little check of the operators manual in ones head to position the correct lever placement.
Now that I know the basics are operating properly I can design some guards for the moving parts. I am leaning towards expanded metal so it can be viewed while operating and removed by several bolts in one piece. Sorry about the brain lapse.......... I guess concentration and trouble shooting out weighed common sense.
Similar Threads
EasyVac Lawn Vacuum
By mixerdriver in forum General Lawn & GardenReplies: 4Last Post: 11-29-2011, 01:04 PM -
Rake I need a really large lawn vacuum / rake
By demoman357 in forum AttachmentsReplies: 5Last Post: 07-15-2010, 12:00 PM -
Lawn / Leaf Vacuum
By Artillian in forum AttachmentsReplies: 14Last Post: 10-15-2009, 02:25 PM -
Lawn Vacuum for Garden Tractor
By jnelson in forum Build-It YourselfReplies: 1Last Post: 04-02-2009, 08:51 PM -
3 pt hitch lawn/leaf vacuum
By cp1260 in forum Kubota Owning/OperatingReplies: 4Last Post: 10-01-2008, 09:45 PM
