Page 4 of 11 FirstFirst 1234567 ... LastLast
Results 31 to 40 of 102
  1. #31
    Join Date
    Oct 2011
    Posts
    1,963
    Monrovia, California
    Kubota BX25
    Default Re: Dump trailer angle of the dangle
    I was considering a side / rear dump Mike. But I nixed it
    because of the ground clearance issue. Mike do you have
    a link to the hardware used at the corners of your
    trailer please?
    Regards,
    Artisan
    Kubota 2012 BX25 (23H.P. / 17.7pto)
    14' Dump / Carson 12K Tow Trailer w/ movable Winch,
    Canopy, Tunes, Stabilizer Soft Pads, 10"-12"BH Buckets, FEL Grapple, Fasse Valved & Switched,
    Fire Extinguisher, ChainSaw Mount, Protective Surround / Enclosure in the works.
    Stayin' Alive (This click could save a life...)
  2. #32
    Join Date
    Oct 2011
    Posts
    1,963
    Kubota BX25
    BLAST! Mikes trailer is so darn cool. This was my original
    idea that I nixed, but after seeing it, I lust after yee! That
    really has a utility to it and I like that...
    I just went looking at cylinders and fell upon Bailynets site.
    They sure do have a great list to shop from, and learn HERE.
    Regards,
    Artisan
  3. #33
    Veteran Member MJPetersen's Avatar
    Join Date
    Feb 2007
    Posts
    1,255
    Warsaw, Poland
    YM 1510-D
    That was not my trailer--it is a trailer that is for sale here on a site similar to ebay. It is pretty cool and utilitarian, but to get it you would have to build the trailer higher than I wanted my trailer to be. Also, because the sides and ends fold down it is not as strong as one that is all welded together. It all depends what you like.
    The one that I pictured earlier has round balls at each corner and special sockets to fit them. I do not know where you would buy those. However, there is another trailer for sale here also that is similar, but a little bit smaller. Its construction is such that the 2 way movements is achieved with simple elements. I include pictures to aid your fantasy.
    One thing to note is that the cylinder has to have a ball or some sort of construction so that it can pivot in 2 directions. My cylinder had this at both ends and I made the sockets to fit on my lathe.
    Here is the link to where they are on sale.
    Mike
    I forgot to add to buy one here costs about $1200.
    Attached Thumbnails Attached Thumbnails Dump trailer angle of the dangle-small-side-dump-3-jpg   Dump trailer angle of the dangle-small-side-dump-jpg   Dump trailer angle of the dangle-small-side-dump-2-jpg   Dump trailer angle of the dangle-small-side-dump-4-jpg   Dump trailer angle of the dangle-small-side-dump-5-jpg
    Dump trailer angle of the dangle-small-side-dump-6-jpg
    "In all your ways acknowledge Him and He will direct your paths." Solomon
    YM1510D, YM 1202 tiller, The following home made tools: Quick Hitch, KK copy dirt scoop, imitation Gannon rollover box blade, Forks on 3pt, a Rear Blade with gauge wheels and a 1.5 yd dump trailer.
  4. #34
    Join Date
    Oct 2011
    Posts
    1,963
    Kubota BX25
    NICE! Thank you Mike...Very cool, inspiring it is. Looks like the
    "balls" in the first pic are just trailer hitch balls.
    Things that make me go hmmmmmm.
    Regards,
    Artisan
  5. #35
    Join Date
    Oct 2011
    Posts
    1,963
    Kubota BX25
    Well, now I have to learn MORE! HA!
    Where to find ready made, non-custom, telescoping hydraulic
    cylinders that are maybe 48" EXTENDED. ???
    Mike is there anyway to find the Original Manufacturer of the
    traielrs in the second set of pictures?
    Regards,
    Artisan
  6. #36
    Join Date
    Jun 2004
    Posts
    66
    Default
    I think what you are looking for is here
    http://www.baumhydraulics.com/calcul...l_calc_ang.htm
    There are other calculators as well.
  7. #37
    Super Star Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    18,198
    Central Ohio
    Kubota MX5100
    Wow, sorry I am late to the thread artisan. Now where to start...
    You mention telescoping cylinder. Those EAT ground clearence. So.....if you can come up with a geometry that is acceptable, then by all means. But Those cylinders arent cheap either. Upwards of a grand each
    I'll start with this http://www.tractorbynet.com/forums/p...into-real.html
    It covers some of the math involved.
    Mike was right about your angle. The effective angle is between the cylinder-bed & bed-frame pivots.
    So...in your first example using a 12" cylinder, you angle actually would have been a little better than 12*. But by turning the cylinder around like you did in the second drawing with the 24" cylinder, your effective angle is actually worse than appears.
    I actually like the first design better than the second because of the direction the cylinder is pointing, BUT...you have a lot of bed overhanging forward of the lift point once it starts to raise, and would have to be built really strong. If thats not a problem, then yes a 12" cylinder would work. Lets walk through some math now...
    A 4"x12" cylinder @ your Bx's 2400psi will make ~30,000lbs of force. Given a 12 degree mounting angle, thats about 6000lbs of vertical force to initiate the dump cycle. Since it looks like the cylinder is mounted to the bed about 2/3rds back from the front, figuring a load in the center, you are further reduced in capacity by 33%, or down to 2 tons of dump force now. Not bad right.
    But keep in mind those axles you said look big, those are going to be seeing 15 TONS of force RIGHT in the middle of the span. NOT good.
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    MX5100 DIY Remotes
    MX5100 Diverter install
    Front Snow Plow Install
    Ford 5500 Backhoe
    Kubota MX5100HST w/LA844
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 306
    3 Homemade wood hauling trailers
    Dolmar 6400 84cc ported
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  8. #38
    Join Date
    Apr 2008
    Posts
    18,198
    Central Ohio
    Kubota MX5100
    Part 2:
    Is there any way you can locate the cylinders farther forward so that they are pushing around the center of the bed?? And use two of them so you dont need something super-strong to span the width of the bed. (similar to how I did my dump truck in that link). Only you could locate the cylinders on the INSIDE of the frame rail.
    By moving farther forward, and compensating with a longer stroke cylinder, you can downsize in cylinder diameter, and share the lower force over two mounts instead of one.
    Just a quick example...
    If you use 2 .5"x30" cylinders mounted @ 12 degrees and the pusher is smack dab in the middle of an 8' bed (I dont know how long you are actually planning), you will get a dump angle of about 48.5 degrees, and a force of ~4000lbs and each mount seeing about 9500lbs of force.
    You can play with different mount angles, length of cylinders, and mounting locations. In the above example, if you move the cylinders rearward a few inches, you will gain angle but loose force. And vice versa if you move them forward. If you lower the base mount (better angle) you will gain more force but not give up much dump angle.
    edit: what ARE the dimensions of the trailer going to be??
    MX5100 DIY Remotes
    Ford 5500 Backhoe
    Bushhog 306
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  9. #39
    Join Date
    Feb 2007
    Posts
    1,255
    Warsaw, Poland
    YM 1510-D
    I thought that you would like those orange ones.
    The "balls" in the first trailer probably are 50 mm (2 in) but they have holes drilled though in the middle so that they can be pinned in place for dumping which ever way you desire. That is the dimension that the balls on my cylinder are.
    If you want the option of being able to dump to the side then you have to locate the cylinder in the middle of the bed and vertical.
    I do not know the company name of the trailer, but it is a small Polish metal fabrication shop. It is being sold by several different tractor sales firms. The pivots in the second trailer are pretty simple and easily fabricated.
    Mike
  10. #40
    Join Date
    Oct 2011
    Posts
    1,963
    Kubota BX25
    Quote Originally Posted by Renze View Post
    snip
    Here in Holland we used to make dump trailers with 3 or 4 stage telescopic cylinders, they arent that expensive. Due to the nature of a telescopic cylinder (the last stage has the smallest diameter piston, which means less force, more speed) you get the best cycle times with a given hydraulic pump.
    Renze might you have a link for me, regarding these
    3&4 stage inexpensive cylinders please?
    Regards,
    Artisan
Similar Threads
  1. Angle of the Dangle
    By Machold in forum Kubota Owning/Operating
    Last Post: 04-02-2010, 08:32 AM
  2. Dump Trailer Angle
    By GuglioLS in forum Build-It Yourself
    Last Post: 07-09-2006, 10:45 PM
  3. Dump Trailer Angle
    By GuglioLS in forum Trailers & Transportation
  4. Dump angle
    By Yardscaper in forum Power Trac
    Last Post: 08-16-2004, 01:50 PM
  5. C-50 Specs - Dump Angle and Rollback Angle
    By BillG_in_TX in forum Century & Branson
    Last Post: 06-15-2004, 02:01 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
