Page 5 of 11 FirstFirst ... 2345678 ... LastLast
Results 41 to 50 of 102
  1. #41
    Veteran Member MJPetersen's Avatar
    Join Date
    Feb 2007
    Posts
    1,255
    Warsaw, Poland
    YM 1510-D
    Default Re: Dump trailer angle of the dangle
    Here are a couple of cylinders that are available here, but I do not know where to find them there. Unfortunately.
    A complete setup with a hand pump. $650
    The ideal cylinder for you. 120 cm (4 feet) compressed 45 cm (18 in) and 4 stages. $350 5.6 metric tons.
    This is the one that I have $200 made by "AG Tech"
    Maybe you can find some one there that can get these. the second comes from Italy so it is probably there too.
    Mike
    "In all your ways acknowledge Him and He will direct your paths." Solomon
    YM1510D, YM 1202 tiller, The following home made tools: Quick Hitch, KK copy dirt scoop, imitation Gannon rollover box blade, Forks on 3pt, a Rear Blade with gauge wheels and a 1.5 yd dump trailer.
  2. #42
    Super Star Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    18,049
    Central Ohio
    Kubota MX5100
    Wow, can we even get those cylinders here?? These guys Bailey International | Hydraulic Cylinders Manufacturer | Hydraulic Supply are usually pretty cheap. And their cheapest 3-stage is north of $700 and 2-stage cylinders are still over $400.
    I looked hard and heavy at them when doing my truck. It was cheaper to go the 2-cylinder route and adjust the mounts accordingly.
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    MX5100 DIY Remotes
    MX5100 Diverter install
    Front Snow Plow Install
    Ford 5500 Backhoe
    Kubota MX5100HST w/LA844
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 306
    3 Homemade wood hauling trailers
    Dolmar 6400 84cc ported
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  3. #43
    Join Date
    Oct 2011
    Posts
    1,963
    Monrovia, California
    Kubota BX25
    Cost makes it tough indeed... No way can I swing a grand for a cylinder.
    So I started drawing trying to take some of the suggestions into account.
    Well, what I could remember.
    This cylinder is under 200 bux and I can drive to get it.
    The blue bed frame is upp'd to 6" tall to give me more angle of teh dangle and
    I now clear the top of the tires.
    The lower cyl mount at the axle is drawn as if attached to said but if I do this
    I will beef that axle up w/ maybe a .5" thick piece of angle plus a
    strongback on the front perhaps, "OR" ..we'll see.
    I do not loose any ground clearance this way.
    It pretty much is as simple as I can keep it.
    "IF" the 10* is ok and "IF" the cyl is strong enough
    The trailer is drawn to scale exactly.
    All parts drawn exactly to size.
    No finals here, still hammering it out.
    Regards,
    Artisan
    Kubota 2012 BX25 (23H.P. / 17.7pto)
    14' Dump / Carson 12K Tow Trailer w/ movable Winch,
    Canopy, Tunes, Stabilizer Soft Pads, 10"-12"BH Buckets, FEL Grapple, Fasse Valved & Switched,
    Fire Extinguisher, ChainSaw Mount, Protective Surround / Enclosure in the works.
    Stayin' Alive (This click could save a life...)
  4. #44
    Join Date
    Oct 2011
    Posts
    1,963
    Kubota BX25
    Oh WOW! I just saw what Mike posted up. VERY COOL!
    yea that ball x ball is cool and a trunnion x ball is cool to!
    THANK You! Mike! Boy that is gonna inspire quite
    a few guys I bet.
    Regards,
    Artisan
  5. #45
    Join Date
    Oct 2011
    Posts
    1,963
    Kubota BX25
    Ah HA! Mike's info was good and I found their website.!
    Mariz
    Regards,
    Artisan
  6. #46
    Join Date
    Oct 2011
    Posts
    1,963
    Kubota BX25
    Regards,
    Artisan
  7. #47
    Join Date
    Oct 2011
    Posts
    1,963
    Kubota BX25
    Mike I hope your ok w/ this... For him-haw sake here is how Mike did his
    w/ the ball x ball telescoping $6.00 cylinder! SIX BUX!
    Regards,
    Artisan
  8. #48
    Join Date
    Apr 2008
    Posts
    18,049
    Central Ohio
    Kubota MX5100
    Quote Originally Posted by Artisan View Post
    Looks better but still not quite what I need to say if it will work.
    You need to draw a line from bed-frame pivot THRU the cylinder-bed pivot and measure THAT angle to the cylinder. THAT is the effective push angle. See diagram Dump trailer angle of the dangle-trailer-jpg
    Also, what is the length of the trailer? And how far forward is the pivot? (IE: where are you pushing on the bed at). It looks like you are a little behind the midpoint. But I need to know exactally (or close) where it is so we can calculate how much it will dump assuming a load of x pounds @ midpoint.
    MX5100 DIY Remotes
    Ford 5500 Backhoe
    Bushhog 306
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  9. #49
    Join Date
    Oct 2011
    Posts
    1,963
    Kubota BX25
    LD1 Your the BEST!
    Boy I am all over the place!
    But "were" learning too...
    Gotta find these "ball and Socket" hinges!
    Look at these pics as taken from HERE
    Regards,
    Artisan
  10. #50
    Join Date
    Oct 2011
    Posts
    1,963
    Kubota BX25
    OK LD1,
    I thunk I have the poop...
    Regards,
    Artisan
Similar Threads
  1. Angle of the Dangle
    By Machold in forum Kubota Owning/Operating
    Last Post: 04-02-2010, 09:32 AM
  2. Dump Trailer Angle
    By GuglioLS in forum Build-It Yourself
    Last Post: 07-09-2006, 11:45 PM
  3. Dump Trailer Angle
    By GuglioLS in forum Trailers & Transportation
  4. Dump angle
    By Yardscaper in forum Power Trac
    Last Post: 08-16-2004, 02:50 PM
  5. C-50 Specs - Dump Angle and Rollback Angle
    By BillG_in_TX in forum Century & Branson
    Last Post: 06-15-2004, 03:01 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
