Results 11 to 20 of 20
10-01-2012, 02:18 AM #11Veteran Member
- Join Date
- Feb 2011
- Posts
- 1,743
- Location
- Trivoli, IL
- Tractor
- SSTT (Sideways Snake Tain Tractor) and STB (sideways train box) tractor, dirt harvester
Re: Drilling out SS rivits and what does HSO mean on a drill bit?
my vote sanding flapper disc. ya it will leave some marks. but just thinking about trying to drill them out. that sounds like murder of the muscles, and then frustration of keeping the rivets from spinning on ya.
i had a rough time finding flapper discs in different sizes at local stores. even large hardware stores. looking from sanding, to drills, to dremals. i finally found a source at farmking near by me. if it was not for that, i would be forced to order the flapper sanding discs online. to get a smaller thickness.
i take above back, i found some small thickness sanding flapper discs in "toolshop" all in one kit for a dremal.
smaller size corded electrical drill with a lock button to keep trigger held. or a dremal has worked for me in other projects. though rivets have not had to deal with in ages...
torch them out?
isn't there an actual tool to remove pop rivets?Ryan
10-01-2012, 09:04 AM #12
Drilling out stainless pop rivets is challenging, especially if they are set in aluminum. I've drilled out hundreds (built a plane). First, get the mandrell out of there. Punch it thru inwards (from the front), with a pin-punch small enough to go through the rivet body. If you dont have a punch like that, grind one. Once the mandrell is out, take a new sharp drill of the size of the rivet, or a tiny step smaller, and drill it out with lots of pressure and very low speed, dry. Watch closely, if the rivet spins a little it may be OK, but if it spins fast, angle the drill as if you are drilling thru at an angle. That is counterintuitive, but will concentrate the drill cutting edges on the part of the rivet that is between the bushing and the head, and make it easy to pop the head off and then punch out the bushing part (another, larger pin punch is needed for this step), so it results in the least amount of drilling to remove the rivet. The rivet is less likely to spin if you drill at an angle. If the rivet stops spinning completely, you can try angling less, or you may have to angle while you woble around the drill over the work. Dont slip out, and dont break the bit. The shorter the bit, the better. A light cordless drill also is nice, and must be variable speed. The slower you turn the drill the better. A drillbit that just came out of your drill doctor will perform the best. The better the drillbit, the longer it will last. But even very good bits will need sharpening fairly soon when drilling stainless. Black and Decker had a drillbit named Bulletdrill. They were stepped on the cutting edges. They worked well for this work too, but mine have all disappeared now, and I dont know if they are available. Also, I cannot sharpen them, so they are kind of a deadend anyway. Good luck.
10-01-2012, 10:19 AM #13
For more information go to www.aircraft-tool.com and search on 1341S.
May be worth a shot?ericher69
IAFF Local 849
10-02-2012, 09:44 AM #14
I will try drilling them out later this week.
I will have a few dremel grinder bits as a backup.
Thanks for the sugestions.
I will relate my experience here.
Still wondering what the HSO stands for.
Cliff
10-02-2012, 01:30 PM #15Platinum Member
- Join Date
- Jan 2006
- Posts
- 878
- Location
- Mass, Northshore, Merrimack Valley
- Tractor
- B6100DT
HSS stands for high speeed steel. O1 is a type of oil hardening tool steel. HSO? Maybe...
McMaster-Carr
.Dan C.
B6100DT, FEL, BH
11-25-2012, 09:39 PM #16
OK, so life gets in the way sometimes. I finally got back to this. I found a good drill bit (I have no idea what type -- it's old) and using just a touch of oil, I drilled very slowly while moving the drill body around a little. I moved from rivit to rivit, and paused a lot to keep everything cool. By doing this, I successfully drilled out the eight rivits. That was very slow work. The most important tool available sometimes is patience.
The project is now complete. Thanks for the help, folks.
CliffMy SF/mystery-noir Novel is out from Grand Mal Press:
Walking Shadow by Clifford Royal Johns
11-26-2012, 07:51 PM #17Gold Member
- Join Date
- Apr 2006
- Posts
- 407
- Location
- western NC
- Tractor
- Ventrac, Steiner
Next time try a mansonary drill bit. They are carbide tipped and will do the job.
12-06-2012, 05:59 AM #18Member
- Join Date
- Jan 2006
- Posts
- 36
- Location
- Sweden
- Tractor
- Kubota 2550
When working with stainless steel, the fundamentals are
- sharp, suitable tools
- low speed
- high pressure
- good cooling
There are special drills for stainless steel and they make a huge difference especially when hand drilling. They use a different edge and spiral angle compared to normal steel drills. The leading drill brand is Dormer (Sandvik, formerly owned by SKF), and in their range they are called A108 drills.
Dormer A108 Hss Quick Spiral Jobber Drill For Stainless Steel 3.00Mm - Amazon.com
Cooling is best done with a cutting paste like RTD Rocol RTD Compound | Reaming Tapping Drilling
BR
/Marcus (who has built 20-ton dairy industry machines all in SS)
12-06-2012, 06:56 AM #19
I too have never heard of HSO.
that said, plain old HSS works just fine on SS. But the keys (as already mentioned) are go slow, and keep things cool. SS work hardens and then its a PITA.".........there is only one way to find out."
"Ok, hold my beer and watch this.........."
Ford 5500 Backhoe
Kubota L3400GST W/LA463 FEL
2005 Dodge 3500 4x4 Diesel
8N Rebuilt and restored
Bushhog 105 and 306 cutters
JD 261 3PH mower
3 Homemade wood hauling trailers
Dolmar 7900
Dolmar 6400 84cc ported BB kit and Muffler Modded
Sachs-Dolmar 120SI Ported
(4) Sachs-Dolmar 116SI Ported
Dolmar PS540
Sachs-Dolmar 115i
Sachs-Dolmar 117
Sachs-Dolmar 112
Dolmar 350 "dads"
12-07-2012, 04:44 PM #20
Similar Threads
drill bit sharpener
By Soundguy in forum Parts/RepairsReplies: 28Last Post: 04-28-2011, 09:25 PM -
Drill Bit Sharpener?
By Agrantina in forum Kubota Owning/OperatingReplies: 17Last Post: 10-14-2010, 10:55 PM -
Do "Drill Doctors" drill bit sharpeners work?
By DocHeb in forum Related TopicsReplies: 31Last Post: 01-01-2009, 03:21 AM -
Name that drill bit
By tnau664 in forum Build-It YourselfReplies: 29Last Post: 02-05-2007, 07:07 PM -
drill bit sharpener
By htiek126 in forum Build-It YourselfReplies: 13Last Post: 11-22-2002, 07:22 AM
