Page 1 of 2 12 LastLast
Results 1 to 10 of 20
  1. #1
    Elite Member Cliff_Johns's Avatar
    Join Date
    Jan 2004
    Posts
    2,673
    Northern Illinois
    JD 4110
    Default Drilling out SS rivits and what does HSO mean on a drill bit?
    I'm trying to drill out some stainless steel rivits. I'm going through
    my pile of old drill bits acquired from various places and found some
    that are marked HSO instead of HSS. The markings are quite clear.
    So 2 questions:
    First, what does HSO mean on a drill bit?
    Second, To drill out the rivits, I figure use slow speed and a little
    wd-40 -- this has to be hand drilled. Any other advice?
    Cliff
  2. #2
    Elite Member Scooby074's Avatar
    Join Date
    Aug 2006
    Posts
    4,416
    Nova Scotia
    BX 25
    Default Re: Drilling out SS rivits and what does HSO mean on a drill bit?
    Is HSO the brand?
    And if the rivets are anything besides pop rivets, I'd probably use a cobalt bit anyways.
  3. #3
    bcp
    bcp is offline
    Join Date
    Jul 2009
    Posts
    2,235
    SW WA
    Kubota BX2360
    HLH and HSO example:
    HLH HSO 7/16" Drill Bit 5 5/8" Reduced 3/8" Straight Shank | eBay
    I don't know what either means.
    Bruce
  4. #4
    Gold Member
    Join Date
    Sep 2012
    Posts
    349
    north shore MA.
    Default
    Quote Originally Posted by bcp
    Bruce
    I don't have a link, but there is a website (acronymfinder.com?) that has a lot of odd thing listed.
    Dan H.
  5. #5
    Join Date
    Jan 2004
    Posts
    2,673
    Northern Illinois
    JD 4110
    They are pop rivits.
    Quote Originally Posted by Scooby074 View Post
    Is HSO the brand?
  6. #6
    Platinum Member BIG DOOLEY's Avatar
    Join Date
    Aug 2012
    Posts
    602
    MICHIGAN
    JOHN DEERE 2320
    Is there a size on the bit?
    could the O be a letter "O" which is 0.316"
    HSO = High Speed letter O
    i have seen many bits marked HS and then the size
    or
    maybe it is for Oxide
    black oxide bit ?
    have never read or heard of an HSO category drill bit.
    tom
  7. #7
    Join Date
    Aug 2012
    Posts
    602
    MICHIGAN
    JOHN DEERE 2320
    About removing the rivets.
    if you are not worried about a painted surface or emery wheel marks. i remove alot of s.s. rivets at work by using an angle grinder with a 60 or 80 grit flap disc.
    grind the rivet front or back flush to the sheet metal and use a drift punch or a center punch to remove the other half.
    drilling many times will spin the rivet if you use too much pressure and will usually mark up the mounting surface too.
    tom
  8. #8
    Join Date
    Jan 2004
    Posts
    2,673
    Northern Illinois
    JD 4110
    Specifically, it says HSO then on the next line it says 3/16
    Quote Originally Posted by BIG DOOLEY View Post
    or
    black oxide bit ?
    tom
  9. #9
    Join Date
    Jan 2004
    Posts
    2,673
    Northern Illinois
    JD 4110
    It's on a painted surface that I don't want to dammage, otherwise, I suppose that would work pretty fast.
    Cliff
    snip . . .
    tom
  10. #10
    Elite Member texasjohn's Avatar
    Join Date
    Oct 2005
    Posts
    4,732
    Central Texas, Jarrell
    Kubota 5030HSTC
    how about using a dremel type grinder...or a stone in a drill...just brainstorming...I almost always grind out a rivet than drill it out...
    Joy is having the tools you need and needing the tools you have!
    Kubota 5030 HSTC, BB, Danueser PHD, LA853 QA HD FEL w JD toothbar, 3pt chisel, 3 pt disk, 6' shredder, Kubota FEL hay spike, 3pt hay fork w carryall, Kubota RTV 1140
Similar Threads
  1. drill bit sharpener
    By Soundguy in forum Parts/Repairs
    Last Post: 04-28-2011, 09:25 PM
  2. Drill Bit Sharpener?
    By Agrantina in forum Kubota Owning/Operating
    Last Post: 10-14-2010, 10:55 PM
  3. Do "Drill Doctors" drill bit sharpeners work?
    By DocHeb in forum Related Topics
    Last Post: 01-01-2009, 03:21 AM
  4. Name that drill bit
    By tnau664 in forum Build-It Yourself
    Last Post: 02-05-2007, 07:07 PM
  5. drill bit sharpener
    By htiek126 in forum Build-It Yourself
    Last Post: 11-22-2002, 07:22 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
