BIG DOOLEY
I recently made some wheel spacers for my JD 2320.
The front spacers were needed for tire chain clearance.
1" aluminum with pass thru holes for the lug bolts gives good clearance for the chains.
longer 14mm bolts were required.
HD 2 link ladder chains "fit" on the rear of my 2012 and clear the hydraulic lines and weren't needed.
I made the spacers for future use when i will be pulling logs for fire wood and to give the tractor better stability on sloped terrain.
( I also like to weld and fabricate things for relaxation) i am married with 3 kids not including myself.
in the process of painting the rear spacers.
the rear spacers will not work with the 54d mowing deck on. the tires will hit the deck caster wheels.
so for those of you that have said chains on the rear of your 2320 will not fit without spacers keep this in mind.
I plan to remove them in the summer.
tom
tom
