Page 12 of 21 FirstFirst ... 29101112131415 ... LastLast
Results 111 to 120 of 206
  1. #111
    Super Star Member
    Join Date
    Dec 2007
    Posts
    10,197
    Central Ohio
    JD 5520, 790- Kub L4300, B7800, MX5100, M7040
    Default Re: Garage/Shop Projected started Here are some Pic's
    Quote Originally Posted by JOE G View Post
    Six Dogs do you have a brand of floor epoxy that you recommend?
    Yes. Sherwin Williams and I think the # is 9000. Ask again when you get closer and I'll look up exact product numbers. Use their "reducer" meaning thinner and buy when you can get 30% or 35% off on some "grand opening" special or something like that. It takes two coats and the first coat uses more than the second. Don't scrimp on product on the second coat and etch concrete with Muriatic acid first, especially if you coated the concrete after you poured it. Somewhere on this site are pictures of my floor and it is absolutely beautiful. Roll the paint on with a wide nappy roller--brush the edges.
    Clean it with Sam's Club Cleaner/Degreaser and No-Rinse Floor Cleaner and use one of those yellow buckets with the ringer built into it. Rust spots or severe stains come out with a scrub brush and degreaser.
    Found a coouple less-than-ideal photos but there are more around. This is after a couple years of use and the floor was dirty at the time so it looks duller than it is. Normally it has a degree of shine and "crispness" to it.
    I debated clear-coating for a third coat but didn't because of the cost but i just might do that this year.
    Attached Thumbnails Attached Thumbnails Garage/Shop Projected started Here are some Pic's-005-jpg   Garage/Shop Projected started Here are some Pic's-002-jpg
    May I be the kind of person my dogs think I am,
  2. #112
    Silver Member JOE G's Avatar
    Join Date
    Aug 2012
    Posts
    243
    Eastern NY
    Husqvarna / John Deere
    Six Dogs, when did you put your shop up? I would like to see more pic's of it.
    Husqvarna YTH24V48LS
    John Deere LT 133
    Husqvarna 7021P
    Husqvarna 562XP Woods Ported with .025 pop up Muffler Mod
    Husqvarna Rancher 55 2005
    Husqvarna 450 Anniversary Edition 2010
    STIHL 009 1998
    STIHL HT 131 Pole Saw 2012
    STIHL FS 110 R Trimmer 2010
    STIHL BR 600 Magnum Blower2012
  3. #113
    Super Star Member
    Join Date
    Dec 2007
    Posts
    10,197
    Central Ohio
    Six Dogs, when did you put your shop up? I would like to see more pics of it.
    Built 2001 so it's 11 years old and is a Morton pole barn. Epoxy done maybe 3 or 4 years ago. Did the garage too. I'll look for more original photos but we might be out of luck. I used to have some taken after I first finished but can't find them. Here's a mediocre photo example.
    Garage/Shop Projected started Here are some Pic's-001-jpg
    The floor has built-in anti skid properties so it's not a high gloss but a soft lowish-gloss leaning towards somewhat slightly flattish gloss. If I were to gloss clear over this now it'd be like leather shoes on clear ice. But it would be pretty.
    Many commercial places use this product so check out fire stations and police depts. It comes in a few colors but gray is 99.9% of what I have seen. Sprinkle flakes cancel out the anti-skid so nix that. You need the anti-skid or trucks slide around on the high idle of start-up.
    Not positive but pretty sure this is the product. I see they now suggest primer and may have way back then but I didn't and was likely given the advice not to.
    http://protective.sherwin-williams.c...3aproduct-6878
  4. #114
    Join Date
    Jan 2006
    Posts
    1,153
    Mass, Northshore, Merrimack Valley
    B6100DT
    I second the epoxy idea. Especially now when the building's empty. There will never be a better or more convenient time.
    Sherwin williams is a good brand. But, I did my garage with Benjamin Moore. M42. It was expensive but worth it.
    Stay away from Rustoleum. A friend of mine had a bad experience with that.
    Dan C.
    B6100DT, FEL, BH
  5. #115
    Join Date
    Aug 2012
    Posts
    243
    Eastern NY
    I would like to do it, I just need to get the building it self done first.
    John Deere LT 133
    Husqvarna 7021P
    STIHL 009 1998
  6. #116
    Join Date
    Aug 2012
    Posts
    243
    Eastern NY
    Here is a Update, Hopefully the build will get back on track, Had a few other projects to tend to.
    John Deere LT 133
    Husqvarna 7021P
    STIHL 009 1998
  7. #117
    Gold Member
    Join Date
    Mar 2010
    Posts
    351
    South PA/Western MD
    So nice!
  8. #118
    Join Date
    Aug 2012
    Posts
    243
    Eastern NY
    Thanks, the detail work is makes it nice but it is also what makes a project take longer.
    John Deere LT 133
    Husqvarna 7021P
    STIHL 009 1998
  9. #119
    Member pwt's Avatar
    Join Date
    Apr 2012
    Posts
    30
    North Bay, Ontario, Canada
    John Deere 4320 and Kubota BX25
    Great wood workmanship.
  10. #120
    Gold Member imgone52's Avatar
    Join Date
    Dec 2011
    Posts
    316
    Tompkins County, New York
    Cub Cadet Yanmar SC2400
    Great looking work. All the time spent on the finish & detail work will pay rewards for many a year. Not only will it be safe and strong, but the good looks will provide a real sense of pride every time you look at it.
    CCY SC2400, FEL, MMM, WB, Chore tote, Broadcast Spreader
Similar Threads
  1. Started rebuilding my shop!
    By Boondox in forum Projects
    Last Post: 07-25-2016, 10:11 PM
  2. Started Garage/Shed this week
    By efam3300 in forum Projects
    Last Post: 07-27-2012, 10:27 PM
  3. New shop/garage
    By JD6430 in forum Projects
    Last Post: 06-06-2012, 01:15 AM
  4. Getting my garage started
    By dieselsmoke1 in forum Photos
    Last Post: 09-08-2009, 09:58 PM
  5. 36x48 Garage/Shop
    By GaryInWA in forum Projects
    Last Post: 08-23-2007, 11:21 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
