Page 2 of 6 FirstFirst 12345 ... LastLast
Results 11 to 20 of 60
  1. #11
    Veteran Member jimgerken's Avatar
    Join Date
    Nov 2001
    Posts
    1,638
    Minnesota
    John Deere 3720
    Default Re: Electrolytic Rust Removal
    Electrolytic Rust Removal-p9170526-jpgElectrolytic Rust Removal-p9050207-jpgElectrolytic Rust Removal-p9110238-jpgElectrolytic Rust Removal-p9110240-jpgElectrolytic Rust Removal-p9110241-jpgI have done some of this too, and have found that "more is better". Higher current and voltage makes the process work faster and more aggressively. Use caution if you have anything higher than about 40 volts DC though, as you can be electrocuted by as little as 45 volts or so.
  2. #12
    Join Date
    Sep 2012
    Posts
    1,208
    north shore MA.
    Default
    Quote Originally Posted by Iplayfarmer
    Does temperature have anything to do with the rate of the process? It got pretty cold overnight.
    Yep. Chemical reactions are faster at higher temps.
    Dan H.
  3. #13
    Join Date
    Jan 2009
    Posts
    1,319
    upstate South Carolina, Greenville
    Kubota M6800, Massey Ferguson 240
    It's an amazing process. No need to use clean water as stated. Process is "line of sight" so must use multiple electrodes on all sides including the inside. Item cannot touch the container, electrodes, or sediment. I used a battery charger (2/10/50 amp) and used the middle setting. Let it sit overnight, remove, brush with a stiff bristle brush, and repeat if necessary. You can tell it is working by the thousands of tiny bubbles rising to the surface. And sodium carbonate is what to use, not bicarbonate.
    Attached Thumbnails Attached Thumbnails Electrolytic Rust Removal-phone-pix-planter-disc-013-a   Electrolytic Rust Removal-phone-pix-planter-disc-016-a
  4. #14
    Join Date
    Apr 2006
    Posts
    2,177
    western NC
    Ventrac, Steiner
    I dont know what is in Arm and Hammer washing soap, but the mineral you want to use is borax, not sodium carbonate or bicarbonate of soda. Twenty Mule Team Borax washing soap would my suggested alternative to the Arm and Hammer, unless the Arm and Hammer also contains borax.
    Just to note, I have not tried sodium carbonate so I cant say if it will or will not work. I suspect it might as there are a lot of minerals that will increase conductivity to water and will work to some degree, some better than others and some not so good. My experiences are that I have had good luck with the borax cleaning the inside of a 1000 gal hydroseeding tank using a welder, (DC),as a power source. Dont remember what setting the welder was on but I started low and dont remember raiseing the setting.
  5. #15
    Join Date
    Jan 2009
    Posts
    1,319
    Default
    All info I have read and researched from multiple places calls for sodium carbonate. I can't speak for borax, but have used the sodium carbonate and know it works. I bought it online in a 5 lb. quantity. It's used in some cooking techniques ( pretzels, I think), also available from what I have read at swimming pool chemical stores, and in the form of "washing powder" from Arm and hammer, but I never found that product locally. All sources emphasize not to use standard baking soda (sodium bicarbonate). I googled it and found it easily and it is cheap! I agree that other chemical solutions that are conductive may also work, but I can attest to the effectiveness of Na carbonate. There's lots of info on this technique if you google "electrolytic rust removal."
    It is an amazing process and is so simple . Rig a plastic drum or trash can like the one in a previous post. I used rebar connected with copper wire as my sacrificial electrodes. The rust and old paint can be just wiped off with almost no effort. The before/after pix I posted of those old hoppers, although soaked overnight for 2 days, took me less than 5 minutes of easy brushing get looking like that. And it doesn't harm chrome (unless undermined by rust). Best of all, it costs only pennies, and produces no chemical waste, just rusty water.
  6. #16
    Super Member Iplayfarmer's Avatar
    Join Date
    Jul 2005
    Posts
    5,238
    Idaho
    Massey Ferguson 1215, Toro 266-H, Farmall Cub, Farmall A
    I tried to upload some pictures from yesterday morning, but I'm having issues. The sacrificial piece was covered in a loose scaly rust, so I'm getting rust from somewhere. I think the pot is just so corroded that it's going to take some time. I tried putting a bolt down into the middle of the pot to be my anode. After all day at work, there was very little change. I think it may have something to do with the smaller surface area of the bolt vs. the larger plate. I went back to the plate for now and I'll leave it for another day or so and see what kind of change I see on the outside of the kettle.
    I may see if I can rig a piece of tube or pipe to be my internal electrode. That would give me more surface area.
    From now on I will only buy cars that are a silver/grey color. Then I can make all body repairs with Duct Tape.
  7. #17
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,721
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    yes.. sodium carbonate is the prefered electrolyte.
    ( bicarb can pit the metal )
    ( lye is too dangerous to use )
    as was stated.. more is better.
    12v is better than 6.
    10a seems to be a great start. I have used 20
    distance from ANODES to work piece matters as well. closer = more current flow.
  8. #18
    Join Date
    Jan 2009
    Posts
    1,319
    I agree you need way more surface area on the inside. You want lots of electrodes, spaced evenly, on all sides. And let it work overnight, then remove, brush and rinse the item, and use a long handle wire brush (like a grill cleaning brush) to quickly clean off the electrodes somewhat just to refresh them. Then repeat. My pictures of the seed hoppers took two overnight soakings to get that clean. Sounds like you need to improve your tub and make sure all the connections are good, and that there is more surface area of electrodes, and that they are more closely spaced. And perhaps some battery chargers may work better than others. I know some don't put out continuous current if they have internal "brains" that may be shutting off current when they sense weird flow. Mine is just a simple Schumaker manual one without an auto shut off feature. The key is the bubbles. If it's not bubbling, it's not working. (but bubbles are tiny, but profuse)
  9. #19
    Join Date
    Mar 2002
    Posts
    52,721
    Central florida
    yup.. 'dumb' chargers are the ones to use.
  10. #20
    Join Date
    Nov 2001
    Posts
    1,638
    Minnesota
    John Deere 3720
    Or a DC welder, if you are impatient like I am. When the bubbling is fierce and the solution is getting warm in the tank, you know you are doing a good job.
Similar Threads
  1. Electrolytic Rust removal
    By jand38 in forum Projects
    Last Post: 11-25-2006, 07:30 PM
  2. Rust removal tip
    By Jethro in forum Kubota Owning/Operating
    Last Post: 10-13-2006, 11:39 PM
  3. heavy rust removal (sandblasting)
    By crazymike in forum Projects
    Last Post: 03-11-2006, 08:46 PM
  4. Rust removal tool
    By Dougwatts in forum Parts/Repairs
    Last Post: 09-15-2004, 11:00 AM
  5. Electrolytic Rust Removal
    By fractal in forum Projects
    Last Post: 03-11-2003, 05:27 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
