Results 1 to 5 of 5
10-12-2012, 10:48 PM #1Elite Member
- Join Date
- Feb 2011
- Posts
- 3,453
- Location
- Tucson AZ
- Tractor
- New Holland TC-45
Boom Pole - Simple - Long & high reach
First off let me state this boom is NOT for HEAVY lifting.
The whole object is long reach or high lift. Construction is pretty simple and quick. By adjusting the bucket to pole chain it can pivot left or right. It is held to the bucket by a 3/4" bolt, left slightly loose.
As shown by the ball I have a hole in the bucket bottom. If just scooping loose soil or sand, often the ball is just left in place. Real handy for moving trailers around. It has also been used for lifting and dumping my 18 footer, when loaded with sand or gravel.
::"I STARTED out with nothing....I still have most of it."
New Holland TC45 1,300+ hours - FEL - back hoe - post hole digger - Hydraulic Gannon - cement mixer - pressure washer - 1975 Dodge 500 flat bed - 1974 chevy C65 6 yard dump truck.
All home made by me. loading forks - 2 drags - roller - Sheep's Foot - Pusher (to unload flat bed truck.) - pickle fork digger - Log splitter -
10-12-2012, 10:54 PM #2Veteran Member
- Join Date
- Jul 2009
- Posts
- 2,241
- Location
- SW WA
- Tractor
- Kubota BX2360
Re: Boom Pole - Simple - Long & high reach
Looks useful, but I would prefer a rigid top brace instead of a chain. If you had a load on it and did a high lift but went a little back past vertical, the only thing keeping it from falling on you is the inch or two of the pipe behind the bolt.
Bruce
10-12-2012, 11:04 PM #3Elite Member
- Join Date
- Feb 2011
- Posts
- 3,453
- Location
- Tucson AZ
- Tractor
- New Holland TC-45
10-12-2012, 11:20 PM #4Veteran Member
- Join Date
- Jul 2009
- Posts
- 2,241
- Location
- SW WA
- Tractor
- Kubota BX2360
I try to look at things with Fail-safe in mind.
Bruce
10-13-2012, 04:00 AM #5Elite Member
- Join Date
- Feb 2011
- Posts
- 3,453
- Location
- Tucson AZ
- Tractor
- New Holland TC-45
Similar Threads
All change among high reach record-breakers...
By Demolitionman in forum Construction EquipmentReplies: 0Last Post: 08-17-2011, 06:07 AM -
Embarq Extended Reach High Speed Internet
By BubbaJr in forum Rural LivingReplies: 10Last Post: 12-19-2008, 03:18 PM -
Boom pole or gin pole( with hydrolic cylinder)
By dennis001us in forum CustomizationReplies: 1Last Post: 01-07-2006, 02:15 PM -
My FEL can't reach high enough
By FL_Cracker in forum Kubota Owning/OperatingReplies: 16Last Post: 11-22-2005, 08:47 PM -
Backhoe - Trailer Receiver Hitch & Boom Pole
By GuglioLS in forum Build-It YourselfReplies: 19Last Post: 02-27-2005, 07:11 PM
