Results 21 to 30 of 33
11-28-2012, 06:11 AM #21Platinum Member
- Join Date
- Oct 2002
- Posts
- 912
- Location
- TR
- Tractor
- MH744
Re: Small snowbloer project
If you can sell it there, lets manufacture more quantity here for you. (I too can contribute on designs, improvements, etc.)
If you people have ideas on small items which can be easily manufactured in quick period, I can help on solid drawings, designs, etc as well as locating a good workshop who can put it in production line quickly. Well, the only problem is marketing and sales. If you can do that in your area, of course, you'll be sole seller there.
(ps: this is not an advertisement, just an idea on what we people here can do somethings real based on your diy projects.)
12-27-2012, 11:44 AM #22New Member
- Join Date
- May 2012
- Posts
- 23
- Location
- Sola, Norway
- Tractor
- Kubota BX1860
12-28-2012, 12:43 AM #23Bronze Member
- Join Date
- Aug 2011
- Posts
- 53
- Tractor
- Komatsu D21S
Looking really nice. I'm looking forward to watching this as you work on it.
Mr. HE
12-28-2012, 01:36 AM #24Super Member
- Join Date
- Aug 2006
- Posts
- 5,114
- Location
- Front Range of Colorado
- Tractor
- JD 4200 C.U.T. & JD 130L Lawn tractor
Very cool Poppey! Your mother-in-law should be happy that you do these projects instead of hanging out in pool halls.
What CAD program are you using?Моє щоденне меню для терористів: бекон на сніданок, бутерброди з шинкою на обід, і вечерю свинячої відбивної
Stuff I've made for the JD4200 or done with it are at this link. http://picasaweb.google.com/mjncad
12-28-2012, 02:38 AM #25New Member
- Join Date
- May 2012
- Posts
- 23
- Location
- Sola, Norway
- Tractor
- Kubota BX1860
I'm using Autodesk Inventor 2012. Before I useds AutoCad and used the 3d tools draw in 3D. When you learn to use Inventor it's fantastic. You constrain parts or connect them than you can rotate and could find that the PTO drive needs to be reverced. Thanks to 600rider who gave this valuable information I could than see his point. Like the auger rotation, it's easy to get it right.
It aldso include design of sprockets and chain, gears coils etc. But Inventor it expensiveeeeeee.
12-29-2012, 01:40 AM #26Super Member
- Join Date
- Aug 2006
- Posts
- 5,114
- Location
- Tractor
All right, another Inventor user on board! I have Inventor 2013 along with AutoCAD 2013. I've used AutoCAD since release 9 back in the 80's, and as good as AutoCAD is as a 2D drafting tool, it sorely is lacking as a 3D modeling tool.
12-29-2012, 02:30 AM #27New Member
- Join Date
- May 2012
- Posts
- 23
- Location
- Sola, Norway
- Tractor
- Kubota BX1860
I´m only a hobby user but also started AutoCad "trying it out" back in 80´s. I do and have for years done some sketches at work but I seldom spend more than an hour or two. At home I have always some projects going on either on my houses or in my metal engineering workshop. You have a nice and tidy place in Colorado and done some nice projects.
12-29-2012, 03:24 AM #28New Member
- Join Date
- May 2012
- Posts
- 23
- Location
- Sola, Norway
- Tractor
- Kubota BX1860
Here are some from my metal hobby https://picasaweb.google.com/1144436...0/MyMetalHobby
12-30-2012, 01:43 AM #29Super Member
- Join Date
- Aug 2006
- Posts
- 5,114
- Location
- Tractor
Thanks Poppey, and I just looked at your photo gallery...very impressive!
02-17-2013, 07:53 AM #30New Member
- Join Date
- May 2012
- Posts
- 23
- Location
- Sola, Norway
- Tractor
- Kubota BX1860
Hi
Here are the design of the rear gearbox. To reverce the rev, I have put in a set of spure gerars Metric module M3 Z40 and further chain and sprocket #60. Than the rev should be correct. I,m putting the drive inside a rectangular tube 150x100x6. The first two images shows shows the drive mounted between plates.
Similar Threads
My Small Tractor Project
By Sutol in forum ProjectsReplies: 9Last Post: 06-21-2012, 07:40 PM -
Small bridge project
By Western in forum ProjectsReplies: 42Last Post: 03-21-2012, 11:55 PM -
A few new pets and a small project
By incubus2432 in forum Rural LivingReplies: 6Last Post: 08-22-2011, 12:41 AM -
Small welding project
By looknlearn in forum WeldingReplies: 3Last Post: 01-11-2011, 06:24 PM -
New Small Project Coming Up
By LBrown59 in forum ProjectsReplies: 6Last Post: 12-10-2008, 10:52 AM
