Results 1 to 10 of 33
10-25-2012, 03:47 PM #1New Member
- Join Date
- May 2012
- Posts
- 23
- Location
- Sola, Norway
- Tractor
- Kubota BX1860
Small snowbloer project
I have a Kubota BX11860 and have started planning building a front mounted snow blower. Have ordered the gearbox, 3 point hitch kit and lift cylinder on e-bay. Design is getting close but still some details left. I not in a ruch and is not heading to get it ready to handle this years snow. I enjoy designing and building things my self. Have a small lathe, X3 milling machine and a metal band saw as well as a welder.
Suggestions apprisiated. The front lift is supposed to be bolted to the tractor front frame and have some sort of clamps on the side. The rear PTO will be used and I intend to use a chain drive as shown.
11-01-2012, 01:50 PM #2Gold Member
- Join Date
- Sep 2007
- Posts
- 459
- Location
- WI
- Tractor
- BX 2350
Re: Small snowbloer project
Very interesting!
Look forward to the rest of this project.
Good luck
BX2350 w/ 60" mmm, FEL, Hyd frt blade, 50" Farm King Snowblower, Custom F&R Forks
11-03-2012, 01:42 PM #3New Member
- Join Date
- May 2012
- Posts
- 23
- Location
- Sola, Norway
- Tractor
- Kubota BX1860
11-03-2012, 01:51 PM #4New Member
- Join Date
- May 2012
- Posts
- 23
- Location
- Sola, Norway
- Tractor
- Kubota BX1860
11-03-2012, 01:53 PM #5New Member
- Join Date
- May 2012
- Posts
- 23
- Location
- Sola, Norway
- Tractor
- Kubota BX1860
11-03-2012, 01:54 PM #6New Member
- Join Date
- May 2012
- Posts
- 23
- Location
- Sola, Norway
- Tractor
- Kubota BX1860
Wrong how do I cancel posts?
11-05-2012, 08:48 PM #7
Unless your pto turns reverse or your gear box reverses the direction of rotation your snow blower will run backwards! I had a front mounted blower on a ford 1310 compact several years ago and it ran from the rear pto. It had a set up with a drive sprocket that went on the pto shaft and a # 50 chain that went around 2 idler sprockets and the lower drive shaft that ran to the front and drove the blower.
_______
\* *|<---Idler sprockets
PTO---->*| |
_*_<-------drive shaft to the front
11-05-2012, 08:51 PM #8
well that didnt work I will try to get a picture of the manual and post it.
11-05-2012, 09:13 PM #9
11-06-2012, 01:54 AM #10New Member
- Join Date
- May 2012
- Posts
- 23
- Location
- Sola, Norway
- Tractor
- Kubota BX1860
Similar Threads
My Small Tractor Project
By Sutol in forum ProjectsReplies: 9Last Post: 06-21-2012, 07:40 PM -
Small bridge project
By Western in forum ProjectsReplies: 42Last Post: 03-21-2012, 11:55 PM -
A few new pets and a small project
By incubus2432 in forum Rural LivingReplies: 6Last Post: 08-22-2011, 12:41 AM -
Small welding project
By looknlearn in forum WeldingReplies: 3Last Post: 01-11-2011, 06:24 PM -
New Small Project Coming Up
By LBrown59 in forum ProjectsReplies: 6Last Post: 12-10-2008, 10:52 AM
