Results 1 to 8 of 8
  1. #1
    Platinum Member BIG DOOLEY's Avatar
    Join Date
    Aug 2012
    Posts
    602
    MICHIGAN
    JOHN DEERE 2320
    Default Started My Ballast Box
    Set out to make my own ballast box.
    This is a 4 cubic foot box made from remnant 1/4" thick plates I welded together.
    I am going to use it for a while and see how I like it.
    I am considering the idea of a mount to piggy back a second weight for larger projects only.
    This here will be just great for wood hauling and snow removal this winter.
    I'll probably will cap this off and paint it.
    Tom
    Started My Ballast Box-new-tractor-339-jpgStarted My Ballast Box-new-tractor-340-jpgStarted My Ballast Box-new-tractor-341-jpgStarted My Ballast Box-new-tractor-342-jpgStarted My Ballast Box-new-tractor-343-jpg
  2. #2
    Veteran Member PhysAssist's Avatar
    Join Date
    Aug 2011
    Posts
    2,333
    Upstate NY- see the BIG lake- look just below it...
    Kubota B2320
    Default
    Quote Originally Posted by BIG DOOLEY
    Tom
    <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=287330"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=287331"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=287332"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=287333"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=287334"/>
    That's pretty nice- nothing sticking out too far in any direction.
    How much do you think it weighs?
    I'm using the kubota ballast box my dealer threw in, and cutting up some old disk segments for extra weight to add to the concrete, but I'm thinking of either putting some cat 1pins on the side, and I'm mounting a hitch receiver to the bottom, now that I modified the 3-pt lift mounts to fit my HF QH.
    Do you plan to put any accessories link tool box or tool holders on yours?
    Thomas
    No matter where you go; there you are...
  3. #3
    Join Date
    Aug 2012
    Posts
    602
    MICHIGAN
    JOHN DEERE 2320
    Default Re: Started My Ballast Box
    Thanks,
    I wouldn't mind a chainsaw scabbard for my 2 saws.
    But i like the fact it is tight to the tractor with no snag issues.
    right now i think i will leave as is because i can always carry saws, gas,oil,toolbox.... in the bucket.
    approximately #780 lbs right now.
    #280 lbs of metal plus 4 cubic feet of stonecrete.
    Tom
  4. #4
    Join Date
    Aug 2011
    Posts
    2,333
    Kubota B2320
    Quote Originally Posted by BIG DOOLEY View Post
    Thanks,
    Tom
    De Nada, I'm always looking out for a better mousetrap, so to speak.
    I see your point, but my forgetfulness makes me worry about what will happen to my tools if I use the bucket while they're in there- there are whole threads about that happening here on TBN.
    We use our RO-BB flipped over [with the scarifiers off of it] for that purpose now [as a carry-all], but it's wide enough to make maneuvering hard in our many narrow access-ways.
    One of the [necessary] downsides of living on a heavily wooded property.
    Take care,
    Thomas
  5. #5
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    28,302
    Branson, Mo.
    Kioti DK35se Hydrostat
    Looks good, and very sturdy, you might consider putting 3 or 4 two inch pipes on the back to carry rakes or shovels if you ever use them from the tractor.. I put a 2 inch reciever hitch in the back of mine, very handy for carrying my sprayer or anything else I can think of to fit the standard receiver.
    James K0UA
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN . Igitur qui desiderat pacem praeparet bellum
  6. #6
    Elite Member GManBart's Avatar
    Join Date
    Dec 2012
    Posts
    4,967
    Detroit, Michigan
    Massey Ferguson 241, Case 580 Super M Series 2, Cat D3B
    Very nice....wish I could buy something similar to save time.
  7. #7
    Join Date
    Aug 2012
    Posts
    602
    MICHIGAN
    JOHN DEERE 2320
    kubota, Deere both carry them.
    Northern tool an on-line retailer sells them.
    NT also has retail outlets, no sure of all the locations
    http://www.northerntool.com/shop/tools/product_200487884_200487884?cm_mmc=Google-pla-_-Farm%20%2B%20Acreage-_-Tractor%20Accessories-_-23468&ci_sku=23468&ci_gpa=pla&ci_kw={keyword}&gcli d=CIW8qY3JxrQCFao7MgodA1oA4g
    The price is a bit steep but thats why I made one.
    check Craigs list for a used one.
    Google homemade tractor ballast images and you will see a variety.
    plywood filled with concrete...
    2012 JD 2320, HOMEMADE CANOPY, 54" FRONT BLADE, 54" MID DECK MOWER, HYDRAULIC ANGLE 60" REAR BLADE, QUICK HITCH, STAINLESS FRONT MOUNT SPRAY TANK W/BOOM, 200CX LOADER W/ 61" BUCKET, HOMEMADE BALLAST BOX,HOMEMADE BUCKET GRAPPLE
    1998 "BIG DOOLEY" Chevy K3500 Crew Cab (36.000 miles & counting)
    United Steel Workers Union 12934
  8. #8
    Join Date
    Dec 2012
    Posts
    4,967
    Detroit, Michigan
    Thanks...I'd seen most of those, but haven't been all that impressed. I just like the way you set yours up so that it's pretty tight to the rear of the tractor. I may have to bite the bullet and buy one to get me by until I can come up with something of my own. For some odd reason, I can rarely buy exactly what I want!
Similar Threads
  1. Ballast Box that Attaches to Box Blade?
    By robertwhite in forum Attachments
    Last Post: 06-24-2012, 12:23 PM
  2. Buying loader - Ballast box or Carryall with box
    By tjwoody in forum Kubota Owning/Operating
    Last Post: 11-22-2011, 08:57 PM
  3. Grading JD2305 Ballast box vs 48" box blade for ballast?
    By JDGREEN1 in forum John Deere Owning/Operating
    Last Post: 04-18-2007, 09:40 AM
  4. Ballast Ballast/ Ballast Box question
    By elginfarm in forum John Deere Owning/Operating
    Last Post: 07-18-2006, 09:12 PM
  5. Utility Storage Box replacing Ballast Box
    By LGinIA in forum Build-It Yourself
    Last Post: 02-14-2003, 05:56 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
