Results 1 to 10 of 10
  1. #1
    Silver Member Sfrankland's Avatar
    Join Date
    Jun 2012
    Posts
    143
    Newfoundland
    Mahindra Max 28 XL
    Default SSQA for a Mahindra Max 28
    So my local dealer has just informed me that Mahindra has no plans to build a skid steer quick attach for the Max series in the near future so I have to build my own. First thing I did was use the plasma torch to cut the mounting plates of the bucket and clean then up to reuse. Once cleaned up I put them back on and started cutting the the rest of the parts. More pictures to follow tomorrow.
    Attached Thumbnails Attached Thumbnails SSQA for a Mahindra Max 28-image-814255897.jpg   SSQA for a Mahindra Max 28-image-1137607996.jpg   SSQA for a Mahindra Max 28-image-2468224723.jpg   SSQA for a Mahindra Max 28-image-2195309095.jpg   SSQA for a Mahindra Max 28-image-1312035949.jpg
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #2
    Join Date
    Jun 2012
    Posts
    143
    Newfoundland
    Mahindra Max 28 XL
    Default
    Got it just about finished today. Need to pickup a tap so I can thread the holes for the grease nipples and finish weld the threaded rod onto the pins.
    Attached Thumbnails Attached Thumbnails SSQA for a Mahindra Max 28-image-3653865850.jpg   SSQA for a Mahindra Max 28-image-137966336.jpg   SSQA for a Mahindra Max 28-image-4098553941.jpg   SSQA for a Mahindra Max 28-image-3935555716.jpg   SSQA for a Mahindra Max 28-image-4264137898.jpg
    SSQA for a Mahindra Max 28-image-4006794494.jpg   SSQA for a Mahindra Max 28-image-541552363.jpg   SSQA for a Mahindra Max 28-image-3218858546.jpg   SSQA for a Mahindra Max 28-image-3744546415.jpg
  4. #3
    Super Member k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    8,006
    Branson, Mo.
    Kioti DK35se Hydrostat
    Default Re: SSQA for a Mahindra Max 28
    Looking good, great project
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. Home-Brew 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks.Satisfied Everlast PA160 welder owner How to add a link to a post . Best way to search TBN
  5. #4
    Join Date
    Jun 2012
    Posts
    143
    Newfoundland
    Mahindra Max 28 XL
    Default
    Added a 2" receiver to the SSQA and got it all painted. The only issue is the handles to release the bucket should of had more of an offset to better clear the bucket during hookup and removal.
    Attached Thumbnails Attached Thumbnails SSQA for a Mahindra Max 28-image-2027917585.jpg   SSQA for a Mahindra Max 28-image-2769590185.jpg
  6. #5
    Elite Member 94BULLITT's Avatar
    Join Date
    Feb 2011
    Posts
    4,158
    Frederick County, VA
    Kubota BX2360 & L4240 HSTC
    Default
    Looks good.
  7. #6
    Super Member flusher's Avatar
    Join Date
    Jun 2005
    Posts
    5,719
    Northern California-Tehama Co.
    2008 Mahindra 5525, 1964 MF-135 diesel, 1951 Farmall Super A, 1951 Minneapolis Moline BF, 1945 Oliver 60 Row Crop, 1949 JD B widefront
    Hey, nice job The SSQA on my Mahindra 5525 is dealer installed. Your's looks just as good.
    The clamp handles on my SSQA are bent to clear the bucket or whatever attachment I hook onto the SSQA.
  8. #7
    Join Date
    Jun 2012
    Posts
    143
    Newfoundland
    Mahindra Max 28 XL
    Default
    Mine are bent as well but could be bent to allow more offset. They work great but are just a little to close for comfort.
  9. #8
    New Member 200TrueBlue's Avatar
    Join Date
    Dec 2008
    Posts
    19
    NL
    Max 28 XL
    Nice job on the SSQA
    Plasma Cutter thats the gear...
    TB
  10. #9
    Veteran Member kiotiken's Avatar
    Join Date
    Aug 2011
    Posts
    1,802
    Dunrobin, Ont
    2012 Kioti DK45 HST Cab
    Nice job. Must be quite the feeling cutting into a pretty much brand new tractor! Well done.
  11. #10
    Join Date
    Jun 2012
    Posts
    143
    Newfoundland
    Mahindra Max 28 XL
    Default
    Cutting into a new tractor was the easy part getting everything back in working order was the nerve wracking part. A plasma torch is a wonderful tool.
Similar Threads
  1. Buying Advice kobota bx25 vs mahindra max 25
    By Quadrivium in forum Mahindra Buying/Pricing
    Last Post: 03-26-2013, 06:27 PM
  2. How do you like Mahindra Max 25?
    By Smitrock5 in forum Mahindra Owning/Operating
    Last Post: 07-27-2012, 10:58 PM
  3. new Mahindra max 22 owner
    By Viperdave in forum Mahindra Owning/Operating
    Last Post: 06-03-2012, 04:56 PM
  4. Price Check Mahindra Max 22
    By kootch88 in forum Buying/Pricing/Comparisons
    Last Post: 03-13-2012, 07:16 AM
  5. New Mahindra MAX SCUTs
    By Martian in forum Mahindra Buying/Pricing
    Last Post: 01-28-2012, 08:11 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
