Results 1 to 10 of 15
11-16-2012, 06:28 AM #1
3/8" CHAIN HOOKS FOR FEL BUCKET
I made some chains hooks for the bucket.
Cut off the eyelet on each hook and welded them to some 1/4" plate to spread out the load and strenghten the mounting area.
I may beef up the front edge of the bucket with some extra steel to keep it from flexing or bending over the years.
also
Two of my shop buddies waitng for snacks.
Tom
2012 JD 2320, HOMEMADE CANOPY, 54" FRONT BLADE, 54" MID DECK MOWER, HYDRAULIC ANGLE 60" REAR BLADE, QUICK HITCH, STAINLESS FRONT MOUNT SPRAY TANK W/BOOM, 200CX LOADER W/ 61" BUCKET, HOMEMADE BALLAST BOX,HOMEMADE BUCKET GRAPPLE
1998 "BIG DOOLEY" Chevy K3500 Crew Cab (36.000 miles & counting)
United Steel Workers Union 12934
11-16-2012, 07:45 AM #2Elite Member
- Join Date
- Apr 2009
- Posts
- 3,202
- Location
- adirondacks
Re: 3/8" CHAIN HOOKS FOR FEL BUCKET
That's the way I do mine except I'll run an extra piece of plate the whole length of the bucket(if needed). I also added a 2 inch reciever in the center, works great for multible stuff, hook, shackle, vise.........
11-16-2012, 07:47 AM #3Elite Member
- Join Date
- Apr 2009
- Posts
- 3,202
- Location
- adirondacks
Ooops sorry forgot to add very nicely done
11-16-2012, 07:48 AM #4
Good job, great looking dogs.
11-16-2012, 07:49 AM #5Platinum Member
- Join Date
- Apr 2011
- Posts
- 584
- Location
- Erie Pa.
- Tractor
- Montana R4944, Ford Jubilee, Ford 621, Ford 841
Very nice! Yes I also welded on a plate to the top of the bucket, it was 3/8" all most as wide as the bucket and almost as long as the bucket. Worked really well!
Montana R4944
Ford Jubliee, Ford 841, Ford 621 industrial with FEL & BH
11-16-2012, 08:48 AM #6Elite Member
- Join Date
- Dec 2007
- Posts
- 3,538
- Location
- Ohio
- Tractor
- JD 5520, 790 TLB-- Kub L4300, B7800, MX5100
Great looking and positioned in the right place on the bucket. Good looking welds, too.
Don't sweat the small stuff...
11-16-2012, 12:53 PM #7Gold Member
- Join Date
- Sep 2012
- Posts
- 349
- Location
- north shore MA.
looks good.
The only thing i might add is that the 'made for welding' hooks would sit lower to the plate. That means less strain on the weld.Dan H.
11-16-2012, 01:14 PM #8Veteran Member
- Join Date
- Sep 2002
- Posts
- 1,300
- Location
- Mt. Ulla, NC
- Tractor
- Satoh S-470D, Mitubishi FD 1450D
I've seen the top of the bucket reinforced with a piece of channel iron, then hooks welded to that.
11-16-2012, 06:44 PM #9Elite Member
- Join Date
- Jun 2002
- Posts
- 3,256
- Location
- Ohio, Ashland Cty, Jeromesville
- Tractor
- Jinma 284
Ive done exact same thing and like others took old receiver hitch off truck and cut center out of the receiver leaving the cross tube about 3' wide and welded it upside down on the bucket. it has only been "TACK WELDED" in for 10 years
as I planned on welding in 5ea. 2.25" SQ Tube receivers spaced out to accept a yet to be made grapple which I will get to maybe someday if I have to
I have all those small parts just not the cylinder or the grapple grippers parts.
MI may remember why I went to the other end of the shop, I'm just afraid once I get there I'll forget how to get back!
11-16-2012, 07:05 PM #10
Looks good BD
A 2" pipe welded under the bucket lip across the whole length and to the sides will add a lot of strength as well, but I think that is overkill (as well as 3/8" hooks) for your 2320.John Deere 4110HST
FEL, MMM, FEL Forks (homemade),I-Match, Ballast Box, #380 plow (modified to fit), Markham LD-48 Grapple, Trac-Vac 854 and lots of other STUFF.
John Deere 4x2 Turf Gator
View some of my projects/adventures in my Picasa Album
Simple JDParts Tutorial HERE
Similar Threads
Strengthened bucket, added bucket chain hooks
By hyperrust in forum AttachmentsReplies: 6Last Post: 03-22-2012, 12:00 AM -
"T" Hooks & Bucket Hooks
By crash325 in forum CustomizationReplies: 4Last Post: 05-16-2011, 01:13 PM -
Loader Add Chain Hooks on FEL Bucket
By Mybota3400 in forum Kubota Owning/OperatingReplies: 12Last Post: 12-23-2010, 01:20 AM -
Chain hooks on FEL bucket
By killdozerd11 in forum WeldingReplies: 16Last Post: 03-27-2010, 02:11 PM -
Chain hooks on bucket
By BOOMERANG in forum New Holland Owning/OperatingReplies: 9Last Post: 06-05-2002, 11:07 AM
