Page 10 of 15 FirstFirst ... 78910111213 ... LastLast
Results 91 to 100 of 141
  1. #91
    Gold Member
    Join Date
    Jan 2012
    Posts
    330
    Brookshire TEXAS
    LS R4047
    Default Re: DIY Cab - Finally decided it was time
    I'M ENVIOUS !!!!!
    2012 LS R4047 , FEL , Backhoe, kingkutter finish mower,68 " rachet rake, Titan skidsteer 72" root Grapple, JD 145,JD166 ........Dodge 3500 cummins, Kenworth w900l Cat powered ...
  2. #92
    Elite Member wmonroe's Avatar
    Join Date
    Nov 2005
    Posts
    3,383
    Southwestern, PA
    1958 Ford 961 Powermaster
    Nice job!
    Kubota L5240 with loader and backhoe
    1958 Ford 961 Powermaster LP
  3. #93
    Veteran Member chim's Avatar
    Join Date
    Apr 2002
    Posts
    2,344
    Lancaster County, PA
    Kubota L3200, Ford 1210
    Quote Originally Posted by triangel View Post
    Where can you buy this stripping? Is it only available in US or is it handled by a chain retailer? just what I am looking for;
    I forget where I bought the material but would think it would be easy to get in Canada. 8 or so years ago a customer wanted to experiment with reducing air flow out of a building by using the strip material to make curtains at their exhaust hoods. I'm pretty sure it was an internet / credit card purchase in lieu of one of our regular vendors. If you google "plastic strip doors" you'll get a bunch of hits. My material is 8" wide and I don't know what gauge. I just did a quick google and found material up to 48" wide. If I recall correctly, it was cheaper for us to buy a bulk roll instead of multiple precut pieces. The roll I cut from has been languishing on a dusty shelf since then. Every now and then a piece comes in handy for something.
    This build has been quite an experience, and I appreciate the positive comments. Cost wasn't appreciably above the target, but it took at least twice the time than I figured on. The people at work helped when they could without interfering with work for "paying customers".
    One thing I'd do differently is the glass installation. The regular butyl glass glue is a large pain. I'd do silicone for both bedding the glass and caulking it.
    The shape of the cab did two things:
    1. It satisfied my desire of having made something with character and matched the mental image I had of the cab.
    2. It added a degree of difficulty and increased the labor needed for the build.
  4. #94
    Elite Member GPintheMitten's Avatar
    Join Date
    Sep 2009
    Posts
    3,337
    Flushing, Michigan
    Kubota B2620 with BH65 backhoe, Ford 2N
    Default
    Very nice design and craftsmanship.
  5. #95
    Silver Member triangel's Avatar
    Join Date
    Nov 2012
    Posts
    115
    melville sk canada
    new holland t1510, 730 case
    Yes I agree, the cost came in about where I figured but the time it is taking was double what I thought but still worth the effort. will look for that door stripping on line. great job on your cab especially the design impressive to say the least. I am amazed at the number local people who do such work and yet there seems to be very few companies willing to make these cabs when there is such a demand or the ones that are out there how overpriced their product is. My cost and labor were less then half of the cheapest one out there which was a sims cab
  6. #96
    Elite Member irvingj's Avatar
    Join Date
    Feb 2008
    Posts
    2,792
    Etna, NH
    2007 MF GC2310 TLB
    Both the stripping and the Armaflex should be available through a refrigeration (or perhaps restaurant) supply house; I used to work with the stuff all the time (previous lifetime).
    Armaflex insulation is very good stuff, available in both tubes --for piping-- and sheets. Here's what I did to my extra-large domestic water pressure tank, to keep it from sweating in the summer; worked very well:
    DIY Cab - Finally decided it was time-dsc04541-jpg
    '07 GC2310 TLB, 2360 snowblower, 2325 MMM, Bro-Tek thumb, Woods GTC40-2 tiller, Woods RB-60 back blade, DR 60" Power Grader, DR Lawn & Leaf Vac
    '05 VW Jetta Wgn TDI
    Numerous vintage Japanese motorcycles
  7. #97
    Join Date
    Apr 2002
    Posts
    2,344
    Finally got her home and put in some seat time today. We had a project at the church that involved taking wheelbarrows of clean stone and dumping them into an areaway. There was no machine access, but the guys welcomed the big orange shovel to load the 14 tons of stone so all they had to do was drive the wheelbarrows and not shovel the stone into them. It only took about 1-1/2 hours start to finish and about 10 minutes drive time each way.
    Whe I got back home I washed her and took a few shots. One problem I discovered is that the trunk paint I was so happy with is WATER SOLUBLE! Splashed some water around the inside of the doors and it loosened the speckled paint. Looks like a little scrub-off and touch-up work will be done in the spring.
    Anyway, here is the finished product:
    DIY Cab - Finally decided it was time-small-done-3-jpgDIY Cab - Finally decided it was time-small-done-1-jpgDIY Cab - Finally decided it was time-small-done-2-jpg
  8. #98
    Veteran Member Marveltone's Avatar
    Join Date
    Jun 2010
    Posts
    1,491
    Somewhere north of Roseau, MN
    Fordson Major Diesel, McCormick Deering W4, Ford 1510, John Deere L111
    You have some serious fabrication skills. Well done!
    Joe
    Joe
    Fordson Major Diesel: Case 3-bottom Trip Plow, Case 12' Trip Field Cultivator, Kewanee 130 Disc, John Deere 1209 Mower Conditioner, John Deere 594LW Side Delivery Rake, New Holland Hayliner 273 Baler, 18' Spike-Tooth Harrow
    Ford 1510: Du-Al 105 Loader, "The Thumb" Grapple, Bush Hog RBC60 Rear Blade, Woods HC54 Rotary Cutter, Tarter 5' Heavy-Duty Hinge Back Box Blade, Buhler Farm King Y600 Snowblower
  9. #99
    Join Date
    Nov 2012
    Posts
    115
    melville sk canada
    Great Job, looks great, there is nothing a like a plan that comes together and turns out right.
  10. #100
    Join Date
    Nov 2012
    Posts
    115
    melville sk canada
    I want to live where you do if the grass is that green now, 25 below and 2 ft of snow where I am and 2 and half months more to go.
Similar Threads
  1. Finally decided to join
    By TOMLXIX in forum New Member Introductions
    Last Post: 11-15-2011, 06:52 PM
  2. Finally decided
    By 2002fb in forum John Deere Lawn & Garden
    Last Post: 04-13-2011, 10:55 PM
  3. Buying Advice Finally decided
    By sbohan in forum Kubota Buying/Pricing
    Last Post: 12-21-2010, 10:50 AM
  4. Finally decided on MF 1523
    By 73jeep in forum Massey Ferguson Buying/Pricing
    Last Post: 02-15-2006, 08:39 PM
  5. Finally decided on the B2410
    By seattle in forum Kubota Buying/Pricing
    Last Post: 05-18-2002, 09:17 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
