Page 13 of 15 FirstFirst ... 3101112131415 LastLast
Results 121 to 130 of 141
  1. #121
    New Member
    Join Date
    Dec 2009
    Posts
    23
    Default Re: DIY Cab - Finally decided it was time
    Real nice job! I'm coming up on retirement, and first project will be a DIY cab for my 2305. You've given me some ideas :-)
  2. #122
    Gold Member BigMike50's Avatar
    Join Date
    Mar 2013
    Posts
    391
    Uranus
    2012 JD 3520 Cab 1996 JD LX172 1985 Wheel Horse
    very talented! looks like some sort of heavy armor war machine!
  3. #123
    Veteran Member chim's Avatar
    Join Date
    Apr 2002
    Posts
    2,343
    Lancaster County, PA
    Kubota L3200, Ford 1210
    Thank you. Since I built it in our one shop at work, the guys kept track of the progress. When the pieces were put together on the tractor they informed me it was no longer a kubota. The renamed it "The Tank".
  4. #124
    Elite Member irvingj's Avatar
    Join Date
    Feb 2008
    Posts
    2,792
    Etna, NH
    2007 MF GC2310 TLB
    Just went back a few pages and looked again at your cab...very nice, indeed. (Those forward-facing lights are a real help, I bet!) Seems with most any of the vehicles I've ever played with, "weight is the enemy"-- but the reverse seems to be true with tractors. Any idea how much extra weight the cab added? I bet it helps with traction.
    Have you had a chance to play in the snow yet? Did you folks get hit a week or so back, or did you manage to escape that storm? Matter of fact, looks like you might get some more tonight; we're supposed to miss this one. Got about a foot last Tuesday, but a lot of the snow is now going away-- though slowly. WBB
    '07 GC2310 TLB, 2360 snowblower, 2325 MMM, Bro-Tek thumb, Woods GTC40-2 tiller, Woods RB-60 back blade, DR 60" Power Grader, DR Lawn & Leaf Vac
    '05 VW Jetta Wgn TDI
    Numerous vintage Japanese motorcycles
  5. #125
    Join Date
    Apr 2002
    Posts
    2,343
    Quote Originally Posted by irvingj View Post
    I believe the cab weighs around 250#. Still no snow because I don't count the 1-1/2" I scurried out to scrape before it melted. You guys got all of the snow this winter. Mebbe next year! We go in spurts here. Some winters are no-shows and others are a lot more "for real". I'm glad I did the build. It'll come in handy one of these days. Heck, I remmeber some early and late season mowing in the evenings that had me pretty chilly.
  6. #126
    Platinum Member bandaidmd's Avatar
    Join Date
    Jun 2013
    Posts
    601
    DelMarVa
    kubota b2620,b8200
    Wow great job, i came here from the link you posted on someone elses build. I guess you got to "play " yesterday. All we got was rain ( i'm just below chestertown md abt 60 miles south of you)
  7. #127
    Join Date
    Apr 2002
    Posts
    2,343
    Quote Originally Posted by bandaidmd View Post
    .................... I guess you got to "play " yesterday. All we got was rain ( i'm just below chestertown md abt 60 miles south of you)
    You're right. I got to play for a few hours with very heavy snow for a few hours. Shovelling the few feet of sidewalk for the neighbor and a small amount at my garage doors was enough hand work. That snow was almost as heavy as dirt.
    Today's a different story. Freezing rain is what hit us this time. There are a couple large limbs down in the driveway and I'm not comfortable going under the trees to clear them till some of the ice melts off. The property looks like a tree trimmer was here and didn't clean up after himself. I was out for about 10 minutes to move my pickup away from a tree. While keeping one eye on the tree I had to use my MAPP gas torch to thaw the door so it would open. In the short time I was outside four more big branches fell. Things are a mess around here but amazingly the power hasn't gone off - yet.
    Attached Thumbnails Attached Thumbnails DIY Cab - Finally decided it was time-limbs-jpg
  8. #128
    New Member
    Join Date
    Aug 2014
    Posts
    5
    Chesterland
    Kubota L48
    Quote Originally Posted by chim View Post
    Cab looks great, what an inspiration. I plan on doing something similar to my L48 kubota.
    Can you take some closer pictures of the outside door handles and also, how you attached to the floor? What about the areas behind the clutch and brake pedals, how did that turn out?
    Thanks!!!
  9. #129
    Join Date
    Apr 2002
    Posts
    2,343
    Thank you. I'm getting ready to pour concrete tomorrow, so things could get a little busy tonight. I'll try to get the pics though.
    The whole cab is supported at four points. As a matter of fact, there's a bit of new extended floor that is supported by the cab. The cab is a little wider than the fenders and the sides of the cab are parallel with each other. That adds a few inches of floor area at the front (a small triangle between bottom of the cab wall end existing floor).
    I made up clips that take all the weight. Two are bearing on the folded ROPS (tractor won't fit some places w/ the ROPS up). I'm not familiar with the ROPS on your tractor, but there should be some place you can get a solid connection to the ROPS or its mounting hardware.
    The front is supported by short pieces of angle that go down over the FEL joystick support on the right, and a matching support I made for the left side. There are no other supports and it is rock solid.
    For the summer of 2013 I removed the cab. It didn't take long at all, but I missed the lighting that was attached to it when working after dark. This summer I only removed the doors. To get a breeze going I installed one of those 2 speed fans like our school bus driver had when I was a kid.
    The area below the glass in the front is made of plastic strips that are used on large refrigerators they drive forklifts through. That worked OK, but I recently picked up a piece of Lexan in hope of cobbling up something better.
  10. #130
    Join Date
    Apr 2002
    Posts
    2,343
    Weather forecast made me leery about pouring tomorrow, so I cancelled it and had plenty of time for a good meal and pictures. Support details are in the thread. Here are some closer shots of the inside and outside of the door handles. There are also pictures of the extra floor space. One with the cow mat flooring in place and the other with the mat lifted up to see the framing that is attached to the bottom of the cab frame.
    Attached Thumbnails Attached Thumbnails DIY Cab - Finally decided it was time-37-jpg   DIY Cab - Finally decided it was time-29-jpg   DIY Cab - Finally decided it was time-img_1460-jpg   DIY Cab - Finally decided it was time-img_1459-jpg
Similar Threads
  1. Finally decided to join
    By TOMLXIX in forum New Member Introductions
    Last Post: 11-15-2011, 06:52 PM
  2. Finally decided
    By 2002fb in forum John Deere Lawn & Garden
    Last Post: 04-13-2011, 10:55 PM
  3. Buying Advice Finally decided
    By sbohan in forum Kubota Buying/Pricing
    Last Post: 12-21-2010, 10:50 AM
  4. Finally decided on MF 1523
    By 73jeep in forum Massey Ferguson Buying/Pricing
    Last Post: 02-15-2006, 08:39 PM
  5. Finally decided on the B2410
    By seattle in forum Kubota Buying/Pricing
    Last Post: 05-18-2002, 09:17 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
