Page 2 of 15 FirstFirst 1234512 ... LastLast
Results 11 to 20 of 141
  1. #11
    Veteran Member chim's Avatar
    Join Date
    Apr 2002
    Posts
    2,384
    Lancaster County, PA
    Kubota L3200, Ford 1210
    Default Re: DIY Cab - Finally decided it was time
    Quote Originally Posted by Agent Blue View Post
    Hyd - mec is serious saw material..... ....................................... If the cab extends past the fenders how are you going to fill the space between the fender and the steel structure ? Your post proves one does not have to be a professional metals person to construct a cab.
    Thanks guys. That saw is awesome. It has a hydraulic vise that grabs the material being cut with the flick of a lever. Another lever raises and lowers the saw.
    The amount of sealing things will depend on how much heat leaks out / cold leaks in. The cab fits fairly tight across the back. I filled under the seat with a piece of "cow mat" cut to fit pretty closely. The sides do have about 3/8 of an inch between the cab and the upper part of the fender. These areas will probably get some of that stick-on foam weatherstripping stuck to the cab.
    As the fender curves down the gap increases quite a bit. For the curved part of the framing I used 1/2 x 1 steel tube because it seemed a better candidate for bending than the 1 x 1 the rest is made from. The 1/2 x 1 follows the curve of the fender closely enough I plan to fasten a strip of conveyor belt or similar material to the bottom of the 1/2 x 1. Sort of an ingrown fender flare. That would leave about 1/4" gap between the top of the rubber to the bottom edge of the fender. If it's too drafty maybe a few slices of a "memory foam" mattress topper we no longer use will help.
    Things are being laid out to avoid contact between the cab and tractor as best I can. When the cab is removed in the spring the tractor shouldn't have rub marks and scratches.
    There are some hurdles to go, but you're correct about not needing to be a professional to build a cab. A lot of research of old threads and noting the successes and pitfalls of others who have been there before me really helped. It was still intimidating to pull the kubota into the shop and look at the cart of metal that was supposed to be a cab.
  2. #12
    Super Member mjncad's Avatar
    Join Date
    Aug 2006
    Posts
    5,114
    In the civilized First World
    A couple
    Very nice work Chim, and you're lucky to be able to do the fab work at your employer's shop! I suggest you check McMaster-Carr McMaster-Carr for various types of weatherstripping to seal your cab and glass work. With the effort you're putting into this project; there is no sense in cobbling together weatherstripping from other materials that may or may not work.
    By the way; don't you just hate grinding welds? I know I do.
    That is an interesting coincidence concerning your comment about clamps and my signature line.
    Paraphrasing Douglas Adams - So long and thanks for all the bacon.
  3. #13
    Join Date
    Apr 2002
    Posts
    2,384
    Quote Originally Posted by mjncad View Post
    Thank you. Don't know why I didn't think of McM/C before. They are on our vendor's list and have what I've been looking for. The sentiment on clamps is probably shared by all those who like to make things. I'm working on the cab this week on a "stay-cation" and hope to have it completed soon.
  4. #14
    Join Date
    Apr 2002
    Posts
    2,384
    Got back at it today and made some serious headway. I started attaching the brackets that will hold the different sections of the cab together. The plan is to use a gasket between the sections. To help align the pieces and compress the gasket there's a pry hole in the tab.
    Another of the photos is taken at a more straight-on angle of the right fender. A previous picture from a different angle made it look like the hand bent radius is a lot worse than it is.
    Last shot is of the left side. Just a couple more pieces to frame around the door and then on to door frame fab and adding flanges for the glass.
    mjncad - McMaster is shipping gasket material today/tomorrow. Thanks again.
    DIY Cab - Finally decided it was time-18-small-jpgDIY Cab - Finally decided it was time-15-small-jpgDIY Cab - Finally decided it was time-16-small-jpgDIY Cab - Finally decided it was time-17-small-jpg
  5. #15
    Banned
    Join Date
    Nov 2012
    Posts
    109
    east coast
    deere,kubota,case,sears,new holland, Mf
    Lookin god. Better hurry up though. Big snow will be here soon. I was out in the snow today. Only downside is you have to open door to let farts out
  6. #16
    Gold Member 600rider's Avatar
    Join Date
    Jul 2007
    Posts
    361
    union city pa
    2004 kubota b7510
    will you cab have doors on both sides? I made on years ago for a Ford 1310 I had and made it with one and hated it!!! When I got the kubota B7510 I retrofitted the cab to it and resigned it to have 2 doors and am soooo glad I did!!! I also echo the sentiment about you can never have too many clamps!
  7. #17
    Platinum Member CBW1999's Avatar
    Join Date
    May 2008
    Posts
    857
    Northern Vermont on the 45th parallel
    Kubota 7510, Toro Groundsmaster 217D
    Quote Originally Posted by 600rider View Post
    Did you post any pics of your cab on another thread? I have a B7510 and am interested in seeing how you fabricated it. I just don't want to hijack this thread..
    I thank God everyday for all of the blessings he has given me- especially for the one's I do not recognize or see!
  8. #18
    Join Date
    Apr 2002
    Posts
    2,384
    It will have two doors. The right door won't get used unless something happens that prevents me from using the left one. The plan is to remove the cab in warm weather but it might be nice to lift both doors off during the transition in the spring and fall.
    Cigar Face - we had a dusting here today. I'm hoping to wrap up the build really soon.
  9. #19
    Join Date
    Aug 2006
    Posts
    5,114
    A couple
    I love McMaster-Carr's selection and customer service, which helps take some of the sting out of their prices.
  10. #20
    Gold Member RockyNY's Avatar
    Join Date
    Nov 2011
    Posts
    290
    Western NY
    Kioti NX6010CH
    chim, perhaps I missed it, but do you plan to bolt the sections together for easy removal? I'm planning a cab for next year and want to go with a modular design so it can be removed in sections instead of the whole works.
Similar Threads
  1. Finally decided to join
    By TOMLXIX in forum New Member Introductions
    Last Post: 11-15-2011, 05:52 PM
  2. Finally decided
    By 2002fb in forum John Deere Lawn & Garden
    Last Post: 04-13-2011, 09:55 PM
  3. Buying Advice Finally decided
    By sbohan in forum Kubota Buying/Pricing
    Last Post: 12-21-2010, 09:50 AM
  4. Finally decided on MF 1523
    By 73jeep in forum Massey Ferguson Buying/Pricing
    Last Post: 02-15-2006, 07:39 PM
  5. Finally decided on the B2410
    By seattle in forum Kubota Buying/Pricing
    Last Post: 05-18-2002, 08:17 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
