Results 21 to 30 of 125
11-28-2012, 11:37 AM #21
Re: DIY Cab - Finally decided it was time
Very nicely done. Looks better than the original cab and it is removable too.
Again, Nicely done!
11-28-2012, 12:20 PM #22
Is there a connection from the bottom of the cab to the tractor frame?
11-28-2012, 01:00 PM #23Elite Member
- Join Date
- Aug 2004
- Posts
- 2,715
- Location
- North of Mtl,Que,Can (Ste Adele)
- Tractor
- MT180D
Nice work!
I also built one long time back but like to see other folks ideas.
Mine is kinda boxy looking and sometimes I get the urge to re-design it for a 'cooler look'.
I lately discovered a fantastic method of sealing the gaps; check out the seals used in public storage buildings. They are like strips of 3" bristled paint brushes and come in lengths of up to 6 ft and angled slightly. Keeps out rain, snow and wind and will not scratch the paint finishes.
Hands down over foams and felts!
11-28-2012, 02:16 PM #24Bronze Member
- Join Date
- Nov 2011
- Posts
- 91
- Location
- Western NY
- Tractor
- Mahindra 4035
11-28-2012, 07:35 PM #25Gold Member
- Join Date
- Feb 2012
- Posts
- 286
- Tractor
- John Deere 955 With 70a Loader and 7 backhoe,toro 3 wheel truck k321
Maybe instead of opening the door just have a vent you can open to exhaust any excess gasses . Cigar face, do you open your door to let the farts out? How would you even come up with that thought. You must be a forward thinking guy! Impressive.
Originally Posted by Cigar Face
11-28-2012, 08:20 PM #26Veteran Member
- Join Date
- Apr 2002
- Posts
- 1,520
- Location
- Lancaster County, PA
- Tractor
- Kubota L3200, Ford 1210
Had another productive day and got one door swinging (picture below). The goal is to paint on Friday. To answer a few questions that came up:
1. Yes it is made in sections. I posted a couple pics a day or so ago showing the connector plates I made up. They're installed with a weld on one side and bolts on the other.
2. The large pieces are the back / top together. Then there is the front section and two side sections.
3. When looking at the right side of the tractor the back/top section is made like an L rotated 90ー to the right. It attaches to the tractor via exiesting holes. The "lollipop" blinker holes were in just the right spot. It's also bolted through the (10mm?) welded-on nuts at the folding point of the ROPS.
3. The front bolts to the steel put there for the joystick on the right and a new matching (opposite hand) steel mount.
4. The cab fastens to the tractor at the six points described above. The lowest point of attachment is the joystick steel. The cab is quite sturdy even in its unfinished state. Today I was climbing the 1x1 steel tube on the right side to bolt up a connector on the far side. It was very solid and I'm no featherweight at 283#.
5. I'll check out those "brooms". At present nothing touches the painted body except a couple thick rubber washers where the lollipops were. I thought some rubber roofing would be good for blocking off the areas on either side of the hood.
11-28-2012, 09:08 PM #27Banned
- Join Date
- Nov 2012
- Posts
- 109
- Location
- east coast
- Tractor
- deere,kubota,case,sears,new holland, Mf
Cause it smelled like methane for a while and it was snowing hard. Didn't want to let the snow in the cab and the heat out. I opted to sniff the fart but made me light headed.
11-28-2012, 09:21 PM #28Elite Member
- Join Date
- Aug 2004
- Posts
- 2,715
- Location
- Tractor
- MT180D
Yes, that's the product except the version I used has 2.5 inch bristles.
I used it above my engine curved cowl below the windshield cross member where the space varies between 1 to 2.5 ins.
I also fitted 2 strips facing each other and pass the hydraulic hoses and heater lines.
I'd be willing to bet that some cab manufacturers will adopt this in future.
11-28-2012, 09:42 PM #29Gold Member
- Join Date
- Feb 2012
- Posts
- 286
- Tractor
That's disgusting! But funny!
11-29-2012, 01:17 AM #30Super Member
- Join Date
- Aug 2006
- Posts
- 5,114
- Location
- Front Range of Colorado
- Tractor
- JD 4200 C.U.T. & JD 130L Lawn tractor
காலை பன்றி இறைச்சி, மதிய உணவு ஒரு ஹாம் ரொட்டி, மற்றும் இரவு உணவிற்கு ஒரு பன்றி நறுக்கு: ஒரு கடமான், மூட்டு சிறை பட்டி.
Stuff I've made and done with my JD 4200. https://picasaweb.google.com/1101061...fgl=true&pli=1
Similar Threads
Finally decided to join
By TOMLXIX in forum New Member IntroductionsReplies: 3Last Post: 11-15-2011, 05:52 PM -
Finally decided
By 2002fb in forum John Deere Lawn & GardenReplies: 2Last Post: 04-13-2011, 09:55 PM -
Buying Advice Finally decided
By sbohan in forum Kubota Buying/PricingReplies: 6Last Post: 12-21-2010, 09:50 AM -
Finally decided on MF 1523
By 73jeep in forum Massey Ferguson Buying/PricingReplies: 11Last Post: 02-15-2006, 07:39 PM -
Finally decided on the B2410
By seattle in forum Kubota Buying/PricingReplies: 3Last Post: 05-18-2002, 08:17 PM
