Page 6 of 13 FirstFirst ... 3456789 ... LastLast
Results 51 to 60 of 125
  1. #51
    Veteran Member chim's Avatar
    Join Date
    Apr 2002
    Posts
    1,519
    Lancaster County, PA
    Kubota L3200, Ford 1210
    Default Re: DIY Cab - Finally decided it was time
    Thank you for the comments and suggestions. Hopefully the cab will be disassembled for painting by the end of this week. I'm getting very anxious to get it completed. The schedule slipped over the past few weeks with other things happening. We had a couple projects at the house and my Mom became hospitalized and passed last week.
    I've been trying to decide what colors to use where. The colors are ROPS gray and orange. I had been thinking of doing the entire cab frame and skin gray, and the roof orange. When I saw it sitting in the shop this AM I imagined it might look good to do the cab frame in gray and the skin in orange. Suggestions welcomed. The project has stirred a fair amount of interest in the weld shop. One of the guys who paints our fab work is dying to shoot some color on it.
    For the front of the cab where it swallows the hood, one of the guys pointed out some leftover clear plastic material from one of those strip-type doors as found on refrigerated rooms. The same stuff will work for the "ingrown" fender flares. I'll get pics when I come to that part as well as some other detail items that may be of interest.
    The heat may not be completely necessary, and I'll be plumbing it with a bypass just in case it's too much. The cab itself could be viewed as unnecessary. I got through the last 23 winters here with no more than insulated coveralls. I got tired of being cold and having snow blow in my face, plus I wanted to see how tough it would be to build a cab. One thing with the cab is that the cost will stay below $1,000 in cost unless the glass guy comes up with a nasty surprise. That's only half as much as a new cloth cab with plastic windows and no heat.
  2. #52
    Elite Member
    Join Date
    Aug 2004
    Posts
    2,708
    North of Mtl,Que,Can (Ste Adele)
    MT180D
    On my homemade cab I am using lengths of what looks like 'paint brush by the yard' It is mounted in an aluminum strip with a slight angle.
    The product is used to seal the gaps around public storage locker doors. The bristles are about 2.5" long.
    Keeps out water, snow, and blocks cold air yet won't mar the tractor metal work finish.
    B4 that I used different types of weather strip foam strips but they all captured dust and grime and marred the paint surfaces.
    Quote Originally Posted by chim View Post
  3. #53
    Super Member grsthegreat's Avatar
    Join Date
    Jan 2011
    Posts
    5,217
    north idaho
    dk45se hst cab
    nice job... cant wait till i see the finished project.
    currently own
    2011 Kioti DK45SE HST CAB tractor/loader, Jimna 6" - 3 point wood chipper, 60" JD Brush Hog, JD 60" Rototiller, 3 point post hole digger with hydraulic assist, 3 point spring tooth rake, Fimco 55 gallon weed sprayer with 12 foot boom, 3 point hydraulic wood splitter (home built)
    Quick Attach 79" loader mount snowblower & rear powerpack
    Quick Attach 84" Snow Blade
    Quick Attach 42" pallet forks
  4. #54
    Super Member mjncad's Avatar
    Join Date
    Aug 2006
    Posts
    5,114
    Front Range of Colorado
    JD 4200 C.U.T. & JD 130L Lawn tractor
    How much smaller all around will the glass be compared to the window opening to allow for the weather-stripping/mounting gasket? Or maybe I should say how much of a gap between the window opening and glass?
    Моє щоденне меню для терористів: бекон на сніданок, бутерброди з шинкою на обід, і вечерю свинячої відбивної
    Stuff I've made for the JD4200 or done with it are at this link.
    http://picasaweb.google.com/mjncad
  5. #55
    Join Date
    Apr 2002
    Posts
    1,519
    Quote Originally Posted by mjncad View Post
    The glass will be glued in, so it will be a little larger than the openings. The openings are about 5/8" smaller than the glass on eash side.
  6. #56
    Platinum Member etcallhome's Avatar
    Join Date
    Mar 2005
    Posts
    652
    WV,Preston County
    JD 1026R
    Very nice looking cab,,, and like you ,,cab is nice but that heat in the cab is so much nicer... For 25-30 yrs I would be out for hrs plowing FIL,BIL, church lot and mine with everytype winter clothing I could find to keep warm ,wasn't my tractor using the FIL. After buying mine ,told my wife needed a cab, no problem buy one, could not see paying 3-5000 for a metal so bought my first Original Cab with/glass window and wiper. Have had 2 since then all the same but last 2 added water type heater. So much nicer ,,If only out for 30 min that is one thing out for 2-3hrs heater even with my cheap cab ,plus light sweatshirt much nicer than 5 or 6 layers of clothes. But for those who don't agree fine,, let them put on all the articles of clothing and hand warmers . I'm going to stay a lot warmer ,, yes not air tight and yes when wind blows and blowing snow with blower I get a very small amount in cab , total of 10min out of 3hrs I can handle that amount.
    Have fun and be safe !!!
    JD1026R H120 fel w/54"bucket; 60" mmm ; 260 BH/w 12" bucket; ballast box; rear weights; front quick hitch w/angling kit and 54 " blade ;3pt rear 60" blade ; JD 47" frt snowblower ; Original Tractor Cab;Bush Hog 47" tiller and 15" Middle Buster
  7. #57
    New Member
    Join Date
    Jun 2011
    Posts
    2
    Lapoinya, Tasmania, Australia
    Clark Bobcat 753; Iseki SX55 4WD
    Awsome cabin build Chim - like a real pro. Just thought though, when looking at the metal on the lower back part of the cab that it may obstruct your view of the linkages when connecting machinery?
  8. #58
    Join Date
    Oct 2011
    Posts
    72
    Amazing piece of fab work, very impressive. What do you think that thing will weigh once you're finished and how easy is it to take off/put on?
  9. #59
    Join Date
    Apr 2002
    Posts
    1,519
    Without sitting in the seat and looking, I can't tell you how much of the view is blocked. I hope not all that much. The bottom of the window is roughly 3 or 4 inches above the seat back. Maybe a DIY set of EZ extensions will be needed.
    I don't know the weight, but would guess somewhere between 200 and 250#. It isn't too hard to take apart and put together. As mentioned in an earlier post it is made in 4 major pieces (plus the lift-off doors). It was all together for a final fit last week, and we had it apart in about 10 minutes.
    There are a couple metal panels that will get a little Bondo to smooth them out a bit. Then it'll be ready for paint and glass. The glass is all cut and ready. I'm off work all week but will be heading in to hopefully wrap it up and have one of the guys shoot it late this week / early next week.
  10. #60
    Join Date
    Apr 2002
    Posts
    1,519
    How do these projects end up taking so long to complete? I thought the cab would easily be finished before Christmas, and now New Year's Day will pass before the thing is done. At least it's getting closer all the time. I was off work this past week using up vacation days. Managed to get the heater "plumbing" ready to mount the heater, finished light mounting brackets, did a layout and made a small switch mounting plate and with some assistance from Santa's elves completed the bodywork and shot the primer. Finish painting is scheduled for Monday - fingers are crossed.
    When we do the finishing touches and assembly I'll take more pictures. Some of you may find different facets interesting and perhaps useful. I know that I benefited from researching cab builds others have done. If there's something from my build that can help someone else that's great. It's been a lot of fun most of the time. Probably the most challenging thing (except for estimating the completion date) was working with the odd shape of the tractor. It wasn't like building a dog house or installing cabinets in the laundry. Not much of anything on it is anywhere near close to square, level, round or plumb. Like most tractors, the Kubota is a combination of different angled parts joined with French curves.
    Here are the sections. Left to right are the right side, left side, front, right door, left door and "Picasso" is priming the back/top. The roof is on sawhorses behind the other parts.
Similar Threads
  1. Finally decided to join
    By TOMLXIX in forum New Member Introductions
    Last Post: 11-15-2011, 05:52 PM
  2. Finally decided
    By 2002fb in forum John Deere Lawn & Garden
    Last Post: 04-13-2011, 09:55 PM
  3. Buying Advice Finally decided
    By sbohan in forum Kubota Buying/Pricing
    Last Post: 12-21-2010, 09:50 AM
  4. Finally decided on MF 1523
    By 73jeep in forum Massey Ferguson Buying/Pricing
    Last Post: 02-15-2006, 07:39 PM
  5. Finally decided on the B2410
    By seattle in forum Kubota Buying/Pricing
    Last Post: 05-18-2002, 08:17 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
