Page 9 of 15 FirstFirst ... 6789101112 ... LastLast
Results 81 to 90 of 141
  1. #81
    Super Member mjncad's Avatar
    Join Date
    Aug 2006
    Posts
    5,114
    In the civilized First World
    A couple
    Default Re: DIY Cab - Finally decided it was time
    Quote Originally Posted by geko View Post
    When siliconing, try running a length of masking tape each side before applying silicone - then run finger around, remove tape & you get a perfect, uniform edge, looks great & easy to do in kitchens & bathrooms, maybe not so much on a tractor!!
    Great idea, I'll have to remember that one. I hate caulking as I make a mess that rivals my use of a grease gun. My brother-in-law is an artist with a caulking gun. I've never seen anyone who can run a perfect bead with minimal tooling and mess like he can.
    Quote Originally Posted by PILOON View Post
    For silicone and other caulks a DIY trick that I read and tried is to use an ice cube to push/spread the caulking.
    It works!
    Sure better than wetting the finger tip.
    That's a new one to me.
    Paraphrasing Douglas Adams - So long and thanks for all the bacon.
  2. #82
    Veteran Member chim's Avatar
    Join Date
    Apr 2002
    Posts
    2,338
    Lancaster County, PA
    Kubota L3200, Ford 1210
    I stopped at the shop yesterday afternoon for the remedial work on the caulking for one window. While there I experimented a little with scraping the excess caulk from the glass. It looks like it'll work OK but it will take some patience. The heavy plastic I used as a tool for smoothing the silicone gave it a nice fiinish. I (partially) used geko's masking tape tip - I used tape on the metal frame side and not the glass. When I smoothed the caulk it pushed a bead up onto the tape and that part was easily removed. On the glass side, the squeegee action of the plastic created a very thin film of silicone at the joint and pushed the excess into a windrow on the glass. In retrospect, a piece of 2" wide tape on the glass side may have been worth the effort. Depends on how difficult it is to get the glass cleaned.
    Here's a picture of the joint on a door section. The butyl window adhesive (aka schmootz) has not been trimmed on the other side of the glass, as it is only now getting to the point where it can be worked on without making black deposits on the fingers. When trimmed back it will create a clean straight black line on the back side (inside) of the glass. That will make variations in my silicone joint less noticeable.
    DIY Cab - Finally decided it was time-caulking-jpg
  3. #83
    Join Date
    Dec 2009
    Posts
    72
    Default
    Best silicone tip ever...never lick your finger twice! Eurgh!
  4. #84
    Platinum Member ENG18LT's Avatar
    Join Date
    Jan 2012
    Posts
    616
    Syracuse and Warsaw, NY
    Mahindra 5530 4wd
    Oh my god! I have done that more then once, and each time I say DON'T DO THAT AGAIN FOOL! Then the next time I use silicone caulk, I lick my finger.
    Lee
    Long road home
    Mahindra 5530 w/ FEL, Bushhog 286 cutter, 8' disc, 2 bottom plow, pallet forks, 22' American trailer, geotextile carrier, PHD w/ 12" auger, tooth bar, landscape rake, trailer hitch, broadcast spreader, toolbar, cultipacker, grain drill, and more to come!
  5. #85
    Join Date
    Apr 2002
    Posts
    2,338
    Quote Originally Posted by john casburn View Post
    Awsome cabin build Chim - like a real pro. Just thought though, when looking at the metal on the lower back part of the cab that it may obstruct your view of the linkages when connecting machinery?
    Made some real progress the last few days and have the cab sections done and back on the tractor. I hopped in this evening for a look at the 3PH arms. I can see about the last 6" of the hitch arms and if I press my nose to the glass I can see around a foot of them.
    Here are a few pics I snapped tonight. The first one is the inside of the one side section. It's difficult to see it but there's a heavy clear plastic strip sandwiched between a stainless strip and the curved wheel opening. It just kisses the bottom of the fender opening on the tractor to seal the gap. The sides of the cab are parallel. The cab side doesn't angle in like the fender does. The gap that created goes from almost nothing at the rear to about 3" in the front. My first attempt was using finish washers directly against the plastic. It looked great when I did it and ugly a day later. The finish washers applied pressure in spots and the plastic developed a scalloped appearance. One of the weldors suggested the stainless strip and it looks a lot better. The plastic is a little hard to see in the picture. You can pick it up where it crosses the Visegrip jaw. This also shows the spatter-finish trunk paint I used on the interior.
    DIY Cab - Finally decided it was time-small-flare-jpg
    Here's a better shot of the spatter paint on an interior section. It also shows the closed cell insulation I'm gluing to the inside of all the sheet metal.
    DIY Cab - Finally decided it was time-small-interior-jpg
    This is what it looked like earlier this evening. After this shot I installed the front lights and spent time wiring things, installing the wiper, completing the heater installation and started closing the areas under the windshield. I'd almost guarantee it would be possible to plow snow wearing shorts and a tee shirt with the heater running. Not very much remains till it's "done done". A piece of cow mat needs to be cut for the right side. Doors and weatherstripping need to be installed. Hope to have her home and do a few finished photos by the end of this week.
    DIY Cab - Finally decided it was time-small-no-doors-jpg
  6. #86
    Platinum Member BIG DOOLEY's Avatar
    Join Date
    Aug 2012
    Posts
    602
    MICHIGAN
    JOHN DEERE 2320
    Looking very nice!
    Tom
    2012 JD 2320, HOMEMADE CANOPY, 54" FRONT BLADE, 54" MID DECK MOWER, HYDRAULIC ANGLE 60" REAR BLADE, QUICK HITCH, STAINLESS FRONT MOUNT SPRAY TANK W/BOOM, 200CX LOADER W/ 61" BUCKET, HOMEMADE BALLAST BOX,HOMEMADE BUCKET GRAPPLE
    1998 "BIG DOOLEY" Chevy K3500 Crew Cab (36.000 miles & counting)
    United Steel Workers Union 12934
  7. #87
    Join Date
    Aug 2006
    Posts
    5,114
    A couple
    You're coming down the home stretch now, and I am looking forward to seeing the finished product.
  8. #88
    Join Date
    Apr 2002
    Posts
    2,338
    Default Re: DIY Cab - ALMOST DONE!
    Made a little more progress today. Two different guys at the shop said "Hey Jim, we renamed your tractor The Sherman". A retired employee stopped by today and gave it his seal of approval. All that remains is to have my bud in the sheet metal shop bend a few pieces to trim out the area below the cab and conceal some wiring. The clear plastic strips (material used where forklifts drive through openings) are already there, but there is one tricky spot on each side that needs some support. Here's what it looks like at present:
    DIY Cab - Finally decided it was time-small-front-quarter-jpg
    DIY Cab - Finally decided it was time-small-rear-quarter-jpg
    The interior came out nice with the gray speckled trunk paint and armaflex insulation:
    DIY Cab - Finally decided it was time-small-inside-jpg
    This is how I am keeping the doors from whacking the loader:
    DIY Cab - Finally decided it was time-small-hinge-strap-jpg
    This is the inside of the door latch. The latches are stainless paddles as used on utility bodies. I think they were around $13 each at the hardware store and they work well in this application:
    DIY Cab - Finally decided it was time-small-inside-latch-jpg
  9. #89
    Silver Member triangel's Avatar
    Join Date
    Nov 2012
    Posts
    115
    melville sk canada
    new holland t1510, 730 case
    Where can you buy this stripping? Is it only available in US or is it handled by a chain retailer? just what I am looking for;
  10. #90
    Elite Member
    Join Date
    Mar 2010
    Posts
    2,631
    Ontario
    CT235
    Man that looks good.
    Tim.
Similar Threads
  1. Finally decided to join
    By TOMLXIX in forum New Member Introductions
    Last Post: 11-15-2011, 06:52 PM
  2. Finally decided
    By 2002fb in forum John Deere Lawn & Garden
    Last Post: 04-13-2011, 10:55 PM
  3. Buying Advice Finally decided
    By sbohan in forum Kubota Buying/Pricing
    Last Post: 12-21-2010, 10:50 AM
  4. Finally decided on MF 1523
    By 73jeep in forum Massey Ferguson Buying/Pricing
    Last Post: 02-15-2006, 08:39 PM
  5. Finally decided on the B2410
    By seattle in forum Kubota Buying/Pricing
    Last Post: 05-18-2002, 09:17 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
