Page 4 of 4 FirstFirst 1234
Results 31 to 37 of 37
  1. #31
    New Member
    Join Date
    Apr 2010
    Posts
    13
    vicksburg, ms
    95-96 MF 1020 4wd (Iseki drive-train Mitsubish eng) 2000 Kioti LK 3054 with FEL
    Default Re: An "axle-surrounding" type backhoe subframe
    thanks ptgdigger.
    You must not live in Ms or have not experienced our road systems unknowingly built over Yazoo clay which expands and contracts causing roadways to shift up and down several inches to several feet over varying distances. Use to see loads ejected off trailers and 18 wheeler trailers broken in half, though not in a while the soil and pavement shifts still occur.
  2. #32
    New Member
    Join Date
    May 2013
    Posts
    3
    Allamuchy, New Jersey
    Luzhong 254
    Default Re: Luzhong 254 backhoe subframe
    Quote Originally Posted by len10 View Post
    I have a Luzhong TC254 (similar to a Jinma 254) with a loader and 3 point hitch mounted backhoe (LW-6). Having never owned a tractor, I had no clue as to the benefits of a subframe vs. a 3 point hitch mounted backhoe . Much of my inspiration for tackling this project came from dfkrug. His thread is here: http://www.tractorbynet.com/forums/b...wn-custom.html
    In his thread, dfkrug describes two major types of subframes used to mount backhoes, a ladder frame and an "axle-surrounding" frame. After researching every subframe design I could find, I decided to go with 殿xle-surrounding type subframe. I created an amalgamation of all the design features I liked in the various designs I came across. The information dfkrug provided in his posts was invaluable. I hope my design might help some with a similar style tractor.
    This was my first venture into metal fabrication. I had help from an experienced welder (not in the design phase), however, if could do it anyone could do it. Although it took much longer than I thought, mostly due to my work schedule, it was a rewarding process.
    I first made some crude plywood templates as seen in the following pictures.
    I had to remove the star shaped hub, so I could slip the template over the square axle housing (see picture).
    Attachment 289377Attachment 289378Attachment 289379
    Hello, I also have the Luzhong 254 would you be willing to make a second one and sell it to me ??????
  3. #33
    New Member
    Join Date
    May 2013
    Posts
    3
    Luzhong 254
    Hello, would you be willing to make a second one and sell it to me ???
  4. #34
    Member
    Join Date
    Jan 2012
    Posts
    31
    Southwest Connecticut
    Terracyclone (Luzhong TC254)
    Quote Originally Posted by Sergeant721 View Post
    I wish I had the time. Unfortunately it wouldn't be economically feasible.
    Jack of all trades, master of none (but working on it)
  5. #35
    New Member
    Join Date
    May 2013
    Posts
    3
    Luzhong 254
    Would you sell the wood forms if you still have them ?
  6. #36
    Member
    Join Date
    Jan 2012
    Posts
    31
    Sorry for the delay in responding. Unfortunately I no longer have the wood forms. I'd be happy to provide you with measurements if that would help. I don't have any plans as the sub frame was designed on the fly. One of the hardest parts of the project was getting holes to align. It was especially difficult to position holes on the sub frame to align with existing threaded holes on the axle. I'm sure more veteran builders have developed tricks to make this process easier. Let me know if the measurements would help.
  7. #37
    Super Member dfkrug's Avatar
    Join Date
    Feb 2004
    Posts
    5,660
    NorCal
    05 Kioti CK30HST w/ Prairie Dog backhoe
    In general, what I like to do to help with hole alignment is to provide some form of self-alignment
    strategy. Usually, this takes the form of having one frame element push up and get stopped in at least
    one dimension by another frame element. A "frame element" can also be a part of the tractor's carcass.
Similar Threads
  1. Backhoe Backhoe subframe and backhoe not attached together?
    By Calvin in forum Attachments
    Last Post: 01-11-2009, 12:01 PM
  2. Backhoe ? 3 PT Backhoe Subframe
    By Lasgambler in forum Attachments
    Last Post: 07-15-2007, 05:32 PM
  3. Backhoe Subframe
    By Seon in forum John Deere Buying/Pricing
    Last Post: 05-10-2006, 12:13 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
