Results 1 to 10 of 16
11-22-2012, 12:26 PM #1New Member
- Join Date
- Mar 2010
- Posts
- 9
- Location
- Narrows, VA
Outdoor wood burner project
I started this project around the first of September. Im build a 3'depthx3'widthx4'tall firebox with a 4'x4'x5' water jacket here some pictures from the first day I started working on it. Im stick welding everything with 1/8th 7018 electrodes
The main door is 18x18 the ash pan door is 6"x18"
It took 6 4'x8' sheets of 1/4" a36 steel plate to build
the bottom has a 36"x26" grate made out of 3/4" hr round bar, there is fire brick on the sides of the grate on an angle.
11-22-2012, 12:45 PM #2Platinum Member
- Join Date
- Feb 2012
- Posts
- 537
- Location
- sioux city, ia
- Tractor
- Oliver 1855, Case 1840, Cub 1550
Re: Outdoor wood burner project
Nice job! thats a lot of welding. What do you think this will cost to build? What do you have for a heat exchanger in your home, radiant floor or forced air? Keep us posted on the performance of this unit.
11-22-2012, 01:52 PM #3Silver Member
- Join Date
- Nov 2011
- Posts
- 150
- Location
- Kansas
- Tractor
- MF 1652 FEL
I am also very interested in your design and projected cost. That is some very nice work and welding.
11-22-2012, 02:09 PM #4Bronze Member
- Join Date
- Jan 2005
- Posts
- 71
- Location
- Waterport NY
looks good ! only think i would have done to make the build easier is, not worry about a ash collector. We have a Taylor outdoor burner piece of junk . that i plan on replacing with a custom built one... once i find the materials . cheap lol
11-22-2012, 09:22 PM #5New Member
- Join Date
- Mar 2010
- Posts
- 9
- Location
- Narrows, VA
I hooked up the burner to 2 90000 btu heat exchangers one is in my attic and one in my basement. I bought a Taco 0013 stainless circulating pump which I installed in my basement, which is around 70 feet from my burner. The 1" pex then goes to my attic heat exchanger, back down to my basement through another heat exchanger then back to the wood burner. The pump is pushing water through 180 feet of 1" pex. The burner is 15 feet above the pump so it is not having to suck water.
I have been running it for a couple of days, and I'm filling I once a day, with about a wheel barrow load of wood. I am mixing green and dry wood, because I dont have enough seasoned wood this year.
11-22-2012, 09:28 PM #6New Member
- Join Date
- Mar 2010
- Posts
- 9
- Location
- Narrows, VA
11-22-2012, 10:05 PM #7New Member
- Join Date
- Mar 2010
- Posts
- 9
- Location
- Narrows, VA
Cost of unit broken down
Steel plate 1/4" 4x8 sheets $1000.00
2 Heat exchangers $268.00
300 feet Pex 1" $214.00
Taco 0013 stainless pump $348.00
75 cfm fan $68.00
1 " stroke solenion $44.00
5 3/4 weld in bungs $25.00
6 shut off valves $54.00
4 3/4 stainless 90* street $24.00
2 1" pex t $12.00
4 1" sweat x 1" male pex crimp $15.00
15 1" pex elbows $36.00
1" pex crimp tool $30.00
50 1" pex crimp rings $29.00
4 1" pex crimp x 3/4 npt male $13.00
Circulator pump flanges $17.00
Reflective bubble insul $87.00
concrete $50.00
flashing $28.00
pipe insulation $80.00
metal roofing Free
frame to put on siding $100.00
Firebrick $20.00
Foam insulation $114.00
14 feet 1 inch firerope $65.00
firerope adhesive $18.00
Smoke stack 4 1/2 pipe Free
2 electronic thermostats $40.00
Digital temperature controller Free
100 ft 10/2 $110.00
water treatment $40.00
Welding rods, grinding wheels $50.00
So with the cost of gas and electricity that I also used I have close to $3000.00 in it
11-28-2012, 06:33 PM #8New Member
- Join Date
- Nov 2012
- Posts
- 3
- Location
- Malcolm Ne
- Tractor
- JD B A D 4440
You have a good looking heater for a cheap price.
11-28-2012, 07:14 PM #9Gold Member
- Join Date
- Jan 2011
- Posts
- 437
- Location
- Central, OK
- Tractor
- jd 1050 LS I3040H
Excellent job! I keep thinking I will get around to a project like that but stuff always gets in the way
LS I3040H w/ loader
JD 1050 w/ loader and backhoe
11-29-2012, 04:22 PM #10New Member
- Join Date
- Mar 2010
- Posts
- 9
- Location
- Narrows, VA
I took 8 years to plan it and 3 months to build it. I stopped working on my backhoe project to do this one. I'm glad that I built my logsplitter first though.
Similar Threads
Outdoor wood boiler project
By hockeypuck in forum Massey Ferguson Owning/OperatingReplies: 25Last Post: 04-17-2011, 05:46 PM -
another outdoor wood burner question
By badbowtie in forum Build-It YourselfReplies: 3Last Post: 11-21-2010, 08:32 PM -
outdoor wood burner who has built one
By badbowtie in forum Build-It YourselfReplies: 59Last Post: 11-10-2010, 07:52 AM -
Stainless Stove Pipe for Wood Burner
By Tororider in forum Rural LivingReplies: 9Last Post: 01-08-2010, 03:46 PM -
Smokey wood burner help
By Boiler74 in forum Rural LivingReplies: 23Last Post: 12-11-2008, 11:24 AM
