Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Join Date
    Sep 2010
    Posts
    91
    Central NYS
    Kubota B9200
    Default 3 point lift arm stabilizer
    Anyone have an idea of how to build a device that would stop my lift arms from rising when using a dump trailer? I am using a 3 point tow bar as the tow bar on the tractor is too low. This is on a kubota B9200. Thanks in advance, I have an idea but much wiser minds are here. smoker
  2. #2
    Elite Member SSdoxie's Avatar
    Join Date
    Jun 2010
    Posts
    2,527
    Cumberland Plateau, TN
    Bobcat CT225
    Default Re: 3 point lift arm stabilizer
    Chain the 3pt tow bar to your drawbar at max height you want it. That will allow the 3pt to drop down so you can slide the ball into the hitch when hooking up put pull up against the chain length to prevent it from climbing.
    Dennis
    CT225 w/7TL QA FEL, 60"tooth dirt bucket, 68" smooth bucket, Pallet Forks, Bale Spear. Hydrualic top llin, QH, 48 RC, 60" tiller, Angle blade, Landscape rake, Carry-all, Post hole auger.
  3. #3
    Join Date
    Sep 2010
    Posts
    91
    Central NYS
    Kubota B9200
    What did I say????? "WISER MINDS ARE HERE" !!!!! Can't get much easier than that! Thanks Buddy. smoker
  4. #4
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,901
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    Just dont pull the 3 PH lift lever up too far and damage your drawbar or put the hydraulics into relief by binding the chain.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
  5. #5
    Join Date
    Sep 2010
    Posts
    91
    Central NYS
    Kubota B9200
    Years ago I had an old 9N and it had to bars that went from the 3rd arm to either side of the tow bar. These bars had slots that could be adjusted to the height that you wanted to maintain......well.....I bent the living sh.t out of those arms doing just what you advised me not to do. A learning experience
  6. #6
    Platinum Member Mendonsy's Avatar
    Join Date
    Nov 2012
    Posts
    893
    Mendon, NY
    Kubota B7500HST
    Here's a picture of the linkage that I built for my kubota B7500. It is modeled after the setup that IH had on some of the older 3 points. We had a 686 row crop IH with a similar setup.
    Attached Thumbnails Attached Thumbnails 3 point lift arm stabilizer-hitch-jpg
  7. #7
    Join Date
    Sep 2010
    Posts
    91
    Central NYS
    Kubota B9200
    Thanks for the picture Mendonsy. Interesting. smoker
  8. #8
    Gold Member smiley's Avatar
    Join Date
    Dec 2003
    Posts
    454
    Upstate NY
    Quote Originally Posted by smoker View Post
    My buddys grandfather had a set of those on his 9N and I always thought they were to prevent sidesway so I put chains on my Massey, from the lift arms out to a point on the axle at about the same height as the lift arm mounting points to prevent the snowblower swinging sideways an cramping the PTO
  9. #9
    Elite Member Baby Grand's Avatar
    Join Date
    Nov 2007
    Posts
    4,581
    Windsor, CT.
    Kubotas: L3240GST B2320HST B5100D & G5200H
    Quote Originally Posted by SSdoxie View Post
    That's how I do it:
    3 point lift arm stabilizer-p2180003-jpg
    That's the problem with trouble.
    It always starts out as such fun."
    - Randall Brown
  10. #10
    Join Date
    Sep 2010
    Posts
    91
    Central NYS
    Kubota B9200
    That is perfect! What do they call the device that is attached to your tow bar? I like that idea instead of relying on the grab hook. Thank you for the picture, I appreciate it. smoker
Similar Threads
  1. Leaking 3 point lift arm.
    By Neat 1500 in forum Yanmar
    Last Post: 11-07-2012, 10:24 AM
  2. Cat 1 Three Point Lower Lift Arm Dimensions
    By duwem in forum Mitsubishi/Satoh
    Last Post: 12-07-2011, 03:31 PM
  3. New Holland 914A MMM 3-Point Arm Lift Pin
    By Luremaker in forum New Holland Owning/Operating
    Last Post: 11-13-2011, 02:58 PM
  4. Broken 3 point lift arm
    By longrange2 in forum Yanmar
    Last Post: 06-05-2007, 02:40 AM
  5. 3 point lift arm turn buckles needed
    By LarryP in forum Parts/Repairs
    Last Post: 07-16-2003, 02:37 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
