Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    Elite Member
    Join Date
    Jan 2002
    Posts
    4,607
    SE Wa
    Default Re: Removing PLATE or ears on T posts easily
    Quote Originally Posted by bcarwell View Post
    Thanks to all for some creative answers. Neglected to mention I have ~ 20-30 to do so stopping to make a jig is not feasible as part of the fence is down and I'll have cattle everywhere if I don't hop to. Opted for the vise/chisel/pop off method- still takes some time but they're coming off. Next time for a bigger section I'll remember to find the ones without the wings or to make the suggested tools. Almost thought pounding in upside down was a clever solution until I quickly realized the plates get in the way of the pounder. Anyway, thanks for all the input.
    Bob
    You _could_ 'redneck' them. Put 'em in upside down leaving the plates on.
    Harry K
  2. #12
    Member
    Join Date
    May 2012
    Posts
    26
    rock view, wv
    kubota l3650
    You could buy them from Tractor Supply. I bought 250 last year and over half of them fell off before I got them in the ground. I had to tack weld them back on. They are much needed in this area. The best way to get them off is to lay them at a 90 degree angle over a log. Stand on the t-post and use a air hammer to force the plate off. Good luck.
  3. #13
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Use one of these air hammers to strip off the plate.
    Attached Thumbnails Attached Thumbnails Removing PLATE  or ears on T posts easily-impact-hammer-jpg
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  4. #14
    Gold Member
    Join Date
    Nov 2011
    Posts
    286
    Canton, TX
    JD 301A and yanmar YM2500
    Default
    I've always just used a 2-3lb hammer and just beat them over and off. Occasionally need heavy pliers or vice grips to finish it off.
  5. #15
    Super Member schmism's Avatar
    Join Date
    Jul 2006
    Posts
    5,096
    Peoria IL
    New holland TC(33)
    I've seen earless version at my local farm supply store.
    ask around, you can likely order an earless version for a few pennies less than the normal ones.
    Steve - TC33D 4x4 FEL, dual rear remotes with toys
Similar Threads
  1. Removing fence posts
    By chi6488 in forum Kubota Owning/Operating
    Last Post: 02-28-2012, 01:01 PM
  2. removing Q/A plate
    By spo307 in forum Attachments
    Last Post: 01-10-2010, 09:04 PM
  3. Removing t posts
    By Highsmith in forum Rural Living
    Last Post: 10-17-2007, 10:12 AM
  4. removing old fence posts
    By mthiel in forum Owning/Operating
    Last Post: 04-01-2003, 08:02 AM
  5. Removing Fence Posts
    By RhallVA in forum Kubota Owning/Operating
    Last Post: 02-06-2002, 10:49 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
