Results 1 to 9 of 9
  1. #1
    Member
    Join Date
    Sep 2008
    Posts
    28
    Default window security bars
    Anyone ever built any?
  2. #2
    Super Member
    Join Date
    Mar 2008
    Posts
    6,452
    Northern Fingerlakes region of NY, USA
    Kubota L3830GST, B7500HST, BX2660
    Default Re: window security bars
    Saw lots of them in Argentina, never built any though.
    Aaron Z
    If mankind minus one were of one opinion, then mankind is no more justified in silencing the one than the one - if he had the power - would be justified in silencing mankind.
    John Stuart Mill
  3. #3
    Join Date
    Jan 2008
    Posts
    1,470
    It's not only the bars, but you need to come up with a safe way to EXIT the window in case of a fire. Some sort of quick release from inside to swing open the bars so people can exit. Here in Ca. an etire family was killed because they could not get out of a burning house through the window. People watched them trying to get out but the bars kept them in.
  4. #4
    New Member
    Join Date
    Jun 2012
    Posts
    24
    South Mountain, Pennsylvania
    2002 New Holland TC35D with cab and a 2007 New Holland L170 Skid steer
    Hello,
    I built some at the first house I owned. I put them on all my basement windows. I can't remember everything about them since it was so long ago, but I think I used 1/2" square bar stock and welded them to some channel on the sides. Then bolted through the side channel metal to attach them to the block walls. Probably not too much help, but yes, I have built some !!!!!
    MFWD
  5. #5
    Elite Member
    Join Date
    Apr 2005
    Posts
    3,059
    nicholson, pa
    John Deer Lt160
    I just bought some of the 4mil window security film. It will keep the glass together in case someone tries to smash in a window.
    If you search for window security bars, you can see how they are made. I was thinking of getting those but we have windows that swing out. So we opted for the film.
    http://www.etsy.com/people/Forgeblast?ref=pr_profile
    Is where I have spoons, spreaders, spatuals, sometimes even bread bowls and cups (Kuksa)
  6. #6
    Veteran Member Runner's Avatar
    Join Date
    May 2007
    Posts
    1,665
    Missouri
    John Deere 2520, 1989 John Deere 185, 1960 Panzer T70B
    I built a security grille for my shop door out of bar stock and steel tube.window security bars-img_3886.jpg
    Runner
  7. #7
    Gold Member
    Join Date
    Dec 2006
    Posts
    429
    Coastal Rhode Island
    Jinma 354, purchased 2007
    I used to live in a part of Washington DC where just about every house had window bars. They were not usually made on site, the welder would buy a pre-fab unit and install it. If it wasn't an egress window usually what they would do is drill eight holes around the window frame, 2 on each side, parallel to the glass, and put a piece of 1/2" round steel rod in each hole and weld the frame of the bars to the round rods. If it was an egress window it would have a frame like a prehung door which could be lag bolted to the window frame and the bolt heads would be covered when the window was closed.
    The bars don't have to be Alcatraz-quality. They're really just so you can have the windows open without worrying that a passing opportunistic criminal won't come in and see what you have. It's very rare for the walls of a house to be made out of something that will stand up to a sledgehammer for more than a couple of blows and it's pointless for the bars to be stronger than the walls, it just means that if someone is determined he's going to make a more expensive hole.
  8. #8
    Platinum Member JD 4520's Avatar
    Join Date
    Apr 2011
    Posts
    690
    Brinnon, WA
    John Deere 4520
    Default
    Remember this is only a deterrent like many other security features. Also consider the weakest link theory. A big fat chain lock with a small lock is only limited by breaking the small lock, who cares about the big fat heavy duty chain. Locks on doors are generally only deterrents as well. The more you do to make things hard or create deterrents is usually enough for the potential intruder to go some where else - the weaker link place.
    Gary
    JD 4520, 400X FEL, Frontier Front Blade, Box Blade, Rotary Cutter, Landscape Rake, 48" Wildkat Grapple and PHD
  9. #9
    Elite Member
    Join Date
    Apr 2005
    Posts
    3,059
    nicholson, pa
    John Deer Lt160
    For door frames you may want to look at the stikemaster 2 unit. Its easy to install we have it on all our doors, barn included.
Similar Threads
  1. What has happened to my window!?
    By jmurray01 in forum Rural Living
    Last Post: 05-18-2012, 06:35 AM
  2. Replies: 10
    Last Post: 12-17-2011, 06:59 AM
  3. my new window
    By kunota man in forum ATVs & Utility Vehicles
    Last Post: 09-09-2011, 07:45 AM
  4. Broke my @#$% Window!
    By HOUNDSTOOTH in forum New Holland Owning/Operating
    Last Post: 05-04-2007, 08:58 AM
  5. Another window question
    By GarageSmoker in forum Related Topics
    Last Post: 08-20-2002, 08:57 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
