Results 1 to 6 of 6
  1. #1
    Platinum Member BIG DOOLEY's Avatar
    Join Date
    Aug 2012
    Posts
    602
    MICHIGAN
    JOHN DEERE 2320
    Default Homemade Bucket Grapple Progress
    Did a little more fabrication.
    Far from done done but i did get the a bracket made for the remote hydraulics plus have started the grapple fabrication.
    I will try to fabricate the cylinder mount and cross or lateral bracing for the grapple teeth soon.
    still need to add zerk fittings and trim the pivot pins.
    Tom
    Homemade Bucket Grapple Progress-new-tractor-509-jpgHomemade Bucket Grapple Progress-new-tractor-510-jpgHomemade Bucket Grapple Progress-new-tractor-511-jpgHomemade Bucket Grapple Progress-new-tractor-512-jpgHomemade Bucket Grapple Progress-new-tractor-513-jpgHomemade Bucket Grapple Progress-new-tractor-514-jpgHomemade Bucket Grapple Progress-new-tractor-515-jpgHomemade Bucket Grapple Progress-new-tractor-518-jpgHomemade Bucket Grapple Progress-new-tractor-519-jpg
    2012 JD 2320, HOMEMADE CANOPY, 54" FRONT BLADE, 54" MID DECK MOWER, HYDRAULIC ANGLE 60" REAR BLADE, QUICK HITCH, STAINLESS FRONT MOUNT SPRAY TANK W/BOOM, 200CX LOADER W/ 61" BUCKET, HOMEMADE BALLAST BOX,HOMEMADE BUCKET GRAPPLE
    1998 "BIG DOOLEY" Chevy K3500 Crew Cab (36.000 miles & counting)
    United Steel Workers Union 12934
  2. #2
    Platinum Member JD 4520's Avatar
    Join Date
    Apr 2011
    Posts
    851
    NW WA
    John Deere 4520
    Default
    Looking good. I don't have that kind of time.
    Gary
    JD 4520, 400X FEL, Frontier Front Blade, Box Blade, Rotary Cutter, Landscape Rake, 48" Wildkat Grapple and PHD
  3. #3
    Join Date
    Oct 2012
    Posts
    162
    Langley BC
    Mihindra 3616
    Default Re: Homemade Bucket Grapple Progress
    nice work. I am following this as I may build something similar myself.
    Cam
  4. #4
    Epic Contributor IslandTractor's Avatar
    Join Date
    Sep 2005
    Posts
    21,131
    Prudence Island, RI
    2007 Kioti DK40se HST, Woods BH
    Nice work. Are you planning to put any gussets or connectors between the two upper jaw arms? If you are doing more than just holding brush in the bucket you'll want to beef up the jaws to prevent them from splaying out (or in).
  5. #5
    Super Member mjncad's Avatar
    Join Date
    Aug 2006
    Posts
    5,114
    In the civilized First World
    A couple
    Looks good. Is there a particular reason the toothed arms were spliced together from two pieces of steel instead of being cut from a single piece? Are you going to add an upholstered pad to the valve's armrest?
    Paraphrasing Douglas Adams - So long and thanks for all the bacon.
  6. #6
    Join Date
    Aug 2012
    Posts
    602
    MICHIGAN
    JOHN DEERE 2320
    Quote Originally Posted by IslandTractor View Post
    Thanks everyone,
    Yes i plan on adding gussets and some cross supports. I have some shedule 80 1-1/4" pipe for cross supports and some 3/8" thick angle iron for the cross support that will hold the front cylinder mount.
    I spliced the grapple teeth together from steel pieces that i had leftover in my remnant pile. I may add an extra layer in those areas on the outside after all the supports are welded in.
    Funny I woke up this morning thinking about adding a pad for the remote bracket.
    I made a pad for the backrest on my harley a few years back. I have some black vinyl and foam padding from that project in the shop.
    I would just have to cut a small piece of plywood and use some screws from the bottom side to mount it. Also cut out small circles where the bolts hold the remote in the plywood so it sits flat.
    Have a great day all.
    Tom
Similar Threads
  1. HOMEMADE BUCKET GRAPPLE
    By BIG DOOLEY in forum Build-It Yourself
    Last Post: 11-23-2012, 01:23 PM
  2. Homemade Rock Bucket w/ Grapple...
    By BigDogues in forum Build-It Yourself
    Last Post: 09-02-2005, 12:01 PM
  3. Homemade grapple
    By OleBlue in forum Build-It Yourself
    Last Post: 11-30-2004, 08:53 PM
  4. homemade grapple
    By Ekim_Otsiam in forum Photos
    Last Post: 07-29-2001, 11:19 PM
  5. homemade grapple
    Last Post: 07-16-2001, 10:26 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
