Page 2 of 6 FirstFirst 12345 ... LastLast
Results 11 to 20 of 52
  1. #11
    Platinum Member BIG DOOLEY's Avatar
    Join Date
    Aug 2012
    Posts
    602
    MICHIGAN
    JOHN DEERE 2320
    Default Re: Bucket Grapple Project Deere 2320
    Quote Originally Posted by BIG DOOLEY View Post
    I have done a little more work this morning.
    Added a 3rd grapple tine and put in some gussets.
    Now I need to round the front off a little and run one more pipe support across to tie in some upper gussets.
    Attachment 290946Attachment 290947Attachment 290948Attachment 290949Attachment 290950Attachment 290951Attachment 290952
    Ready to prep for primer tomorrow.
    Bucket Grapple Project Deere 2320-new-tractor-552.jpgBucket Grapple Project Deere 2320-new-tractor-553.jpgBucket Grapple Project Deere 2320-new-tractor-554.jpgBucket Grapple Project Deere 2320-new-tractor-555.jpgBucket Grapple Project Deere 2320-new-tractor-556.jpg
    2012 JD 2320, HOMEMADE CANOPY, 54" FRONT BLADE, 54" MID DECK MOWER, HYDRAULIC ANGLE 60" REAR BLADE, QUICK HITCH, STAINLESS FRONT MOUNT SPRAY TANK W/BOOM, 200CX LOADER W/ 61" BUCKET, HOMEMADE BALLAST BOX,HOMEMADE BUCKET GRAPPLE
    1998 "BIG DOOLEY" Chevy K3500 Crew Cab (36.000 miles & counting)
    United Steel Workers Union 12934
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #12
    Join Date
    Jul 2007
    Posts
    744
    WV
    John Deere 1026R
    Default
    I'm worried you are gonna scratch the heck out of that chrome rod or bend it. Grapples need cylinder protection
  4. #13
    Join Date
    Aug 2012
    Posts
    602
    MICHIGAN
    JOHN DEERE 2320
    Click image for larger version.
Name:	new tractor 552.JPG
ID:	291066Click image for larger version.
Name:	new tractor 553.JPG
ID:	291067Click image for larger version.
Name:	new tractor 554.JPG
ID:	291068Click image for larger version.
Name:	new tractor 555.JPG
ID:	291069Click image for larger version.
Name:	new tractor 556.JPG
    Primed the pieces late last night and loaded the woodstove in the garage before going to bed.
    I'll shake up some flat black paint today. Rustolium flat black will be an inexpensive / easy way to touch it up before storing it in the shed after gathering the years firewood in the spring.
    Bucket Grapple Project Deere 2320-new-tractor-557.jpgBucket Grapple Project Deere 2320-new-tractor-558.jpgBucket Grapple Project Deere 2320-new-tractor-559.jpgBucket Grapple Project Deere 2320-new-tractor-560.jpgBucket Grapple Project Deere 2320-new-tractor-561.jpgBucket Grapple Project Deere 2320-new-tractor-562.jpgBucket Grapple Project Deere 2320-new-tractor-563.jpg
    Bucket Grapple Project Deere 2320-new-tractor-564.jpgBucket Grapple Project Deere 2320-new-tractor-565.jpgBucket Grapple Project Deere 2320-new-tractor-566.jpg
  5. #14
    Join Date
    Aug 2012
    Posts
    602
    MICHIGAN
    JOHN DEERE 2320
    Quote Originally Posted by swick1 View Post
    No doubt you are right.
    I want to assemble it and fabricate a guard that bolts onto the inner top gussets from the bottom side.
    I wanted to have it on the tractor with the hydraulics working and take measurements cycled in and out and measure for clearance in both positions.
    The guard will most likely need to have a slope or taper because the pick point is lower in the front.
    The cylinder rod is above the bottom edge of the top arms though. from a side view you cannot see the cylinder in the grapple between the 4.5" tall arms.
    I need to clock the cylinder ends so the hoses are on the top of the cylinder too. Then i can fabricate a guard the can be bolted on to cover them as well.
  6. #15
    Join Date
    Aug 2012
    Posts
    602
    MICHIGAN
    JOHN DEERE 2320
    This is a rough sketch of what I was thinking for the lower bolt on guard.
  7. #16
    Join Date
    Jul 2007
    Posts
    744
    WV
    John Deere 1026R
    Default
    That would definitely help. I used a solid 3/8 plate on mine. Good luck!
  8. #17
    Join Date
    Aug 2012
    Posts
    602
    MICHIGAN
    JOHN DEERE 2320
    Yes that looks very nice!
    3/8" you shouldn't have an issue bending your guard.
    I you get a chance, could you send me a photo sometime showing me your front hose disconnect mount.
    Looks interesting.
    I like hoew it is mountd further back on the loader arms by the bracket hole for the bucket leveler
    Tom
  9. #18
    Join Date
    Aug 2012
    Posts
    602
    MICHIGAN
    JOHN DEERE 2320
    Homemade greasable pivot pins.
    Bucket Grapple Project Deere 2320-new-tractor-567.jpgBucket Grapple Project Deere 2320-new-tractor-568.jpgBucket Grapple Project Deere 2320-new-tractor-569.jpg
  10. #19
    Join Date
    Jul 2007
    Posts
    744
    WV
    John Deere 1026R
    Default
    Looks interesting.
    Tom
    I used 3/8 for the whole thing. I could have got away with 1/4 and it would be much lighter. I'm not going to break it though! The quick connects are mounted to an angle bracket where the loader arms bend. I haven't made a final bracket yet. I didn't want to mount them on the crossbar because I get dirt piled up on it when I backdrag. I put a lot of engineering effort into the grapple so it will open wide and be tough. I have a thread on it in the hydraulics forum.
  11. #20
    Join Date
    Aug 2012
    Posts
    602
    MICHIGAN
    JOHN DEERE 2320
    Well I made a guard and I will give this a try and see how things look with the grapple full of brush.
    I can always unbolt it and modify or make a larger guard.
    I have a list of fittings that I need to purchase. I still need to find out what size SAE ORB fitting is on the bottom of the John deere joystick svc to send fluid power to the remotes.
    At an eye glance it appears to be #6 SAE.
    Bucket Grapple Project Deere 2320-new-tractor-573.jpgBucket Grapple Project Deere 2320-new-tractor-576.jpgBucket Grapple Project Deere 2320-new-tractor-581.jpg
Similar Threads
  1. BUCKET GRAPPLE PROJECT
    By BIG DOOLEY in forum Build-It Yourself
    Last Post: 11-24-2012, 07:21 PM
  2. Deere Frontier AL1572 debris grapple bucket
    By Millalien in forum Private Party Ads
    Last Post: 02-26-2012, 02:36 PM
  3. John Deere Grapple Bucket 53"
    By caddison in forum Private Party Ads Archive
    Last Post: 01-14-2011, 12:57 PM
  4. Replies: 41
    Last Post: 02-26-2009, 07:16 PM
  5. Frontier/Deere grapple bucket
    By Millalien in forum John Deere Owning/Operating
    Last Post: 07-11-2008, 11:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
