Page 5 of 6 FirstFirst ... 23456 LastLast
Results 41 to 50 of 52
  1. #41
    Platinum Member BIG DOOLEY's Avatar
    Join Date
    Aug 2012
    Posts
    602
    MICHIGAN
    JOHN DEERE 2320
    Default Re: Bucket Grapple Project Deere 2320
    Quote Originally Posted by 94BULLITT View Post
    Here is a link to Gates website on their hose sleeve.
    Thanks.
    I did a search for retailers on the Goodyear website and 3 autoparts stores nearby are Gates sellers.
    Might have to order it but i can give them a call for pricing.
    Tom
    2012 JD 2320, HOMEMADE CANOPY, 54" FRONT BLADE, 54" MID DECK MOWER, HYDRAULIC ANGLE 60" REAR BLADE, QUICK HITCH, STAINLESS FRONT MOUNT SPRAY TANK W/BOOM, 200CX LOADER W/ 61" BUCKET, HOMEMADE BALLAST BOX,HOMEMADE BUCKET GRAPPLE
    1998 "BIG DOOLEY" Chevy K3500 Crew Cab (36.000 miles & counting)
    United Steel Workers Union 12934
  2. #42
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    Default
    Quote Originally Posted by BIG DOOLEY View Post
    Thanks.
    Tom
    There are other companies that make it. I think NAPA can get the gates hose sleeve.
  3. #43
    Join Date
    Aug 2012
    Posts
    602
    MICHIGAN
    JOHN DEERE 2320
    Just ordered all the hoses and fittings from Surplus Center tonight.
    Hopefully I didn't miss anything.
    I even ordered extra fittings and couplers for spare parts.
    Prices seemed very reasonable at Surplus Center.
    Made some progress and have the grapple functioning.
    I still have some fittings coming so I can change the angle or routing of the hydraulic lines slightly.
    JIC 45's and JIC 90's for the hose ends.
    Inside the wheel well I will use the 45's to redirect the hoses behind the heavy frame for the ROPS and it should protect from any snags.
    Anyway here are some pics.
    Tapping into the power beyond ports and installing the pipe plug.
    Bucket Grapple Project Deere 2320-new-tractor-685-jpgBucket Grapple Project Deere 2320-new-tractor-686-jpgBucket Grapple Project Deere 2320-new-tractor-688-jpgBucket Grapple Project Deere 2320-new-tractor-689-jpgBucket Grapple Project Deere 2320-new-tractor-690-jpgBucket Grapple Project Deere 2320-new-tractor-691-jpgBucket Grapple Project Deere 2320-new-tractor-692-jpgBucket Grapple Project Deere 2320-new-tractor-693-jpgBucket Grapple Project Deere 2320-new-tractor-694-jpgBucket Grapple Project Deere 2320-new-tractor-695-jpgBucket Grapple Project Deere 2320-new-tractor-698-jpgBucket Grapple Project Deere 2320-new-tractor-699-jpgBucket Grapple Project Deere 2320-new-tractor-702-jpg
    Adding the new lines to the remote SCV
    And installing the grapple then bleeding the air out.
    Bucket Grapple Project Deere 2320-new-tractor-704-jpgBucket Grapple Project Deere 2320-new-tractor-705-jpgBucket Grapple Project Deere 2320-new-tractor-706-jpgBucket Grapple Project Deere 2320-new-tractor-708-jpgBucket Grapple Project Deere 2320-new-tractor-711-jpgBucket Grapple Project Deere 2320-new-tractor-712-jpgBucket Grapple Project Deere 2320-new-tractor-713-jpgBucket Grapple Project Deere 2320-new-tractor-715-jpgBucket Grapple Project Deere 2320-new-tractor-716-jpgBucket Grapple Project Deere 2320-new-tractor-717-jpgBucket Grapple Project Deere 2320-new-tractor-718-jpgBucket Grapple Project Deere 2320-new-tractor-719-jpgBucket Grapple Project Deere 2320-new-tractor-720-jpgBucket Grapple Project Deere 2320-new-tractor-721-jpg
  4. #44
    Join Date
    Aug 2012
    Posts
    602
    MICHIGAN
    JOHN DEERE 2320
    My extra fittings arrived yesterday but i was busy smoking ribs and making homemade chicken noodle soup.
    Took a few minutes this morning and rerouted the hoses behind the ROPS support farther away from the tire.
    I used two 45' deg. JIC fittings and was able to change the angle of the hoses.
    1/4" hoses might have gone in better but I wanted to keep with 3/8".
    Bucket Grapple Project Deere 2320-new-tractor-704-jpgBucket Grapple Project Deere 2320-new-tractor-731-jpgBucket Grapple Project Deere 2320-new-tractor-733-jpgBucket Grapple Project Deere 2320-new-tractor-735-jpg
  5. #45
    Join Date
    Aug 2012
    Posts
    602
    MICHIGAN
    JOHN DEERE 2320
    I was going to put a JIC X NPTM X JIC (tee) connector on one set of the rear couplers.
    From that set of couplers run lines to the front set of couplers.
    Attachment 293869
    I made the bracket for the second set of rear remotes.
    Just waiting for my order from Surplus Center with the hoses I need.
    Bucket Grapple Project Deere 2320-new-tractor-785-jpg Bucket Grapple Project Deere 2320-new-tractor-786-jpg Bucket Grapple Project Deere 2320-new-tractor-787-jpg Bucket Grapple Project Deere 2320-new-tractor-788-jpg Bucket Grapple Project Deere 2320-new-tractor-789-jpg
  6. #46
    Join Date
    Apr 2011
    Posts
    1,174
    Erie Pa.
    Montana R4944, Ford Jubilee, Ford 621, Ford 841
    Ok looks nice lots of work involved there!
    What are the fittings called that you used to mount the couplers to your new brackets. I need a couple of those for my grapple connectors and I didn't know what to get. Did you get them from Surplus Supply also?
    Montana R4944
    Ford Jubliee, Ford 841, Ford 621 industrial with FEL & BH
  7. #47
    Join Date
    Aug 2012
    Posts
    602
    MICHIGAN
    JOHN DEERE 2320
    Quote Originally Posted by Guesseral View Post
    I bought all the fittings from Surplus Center.
    Look under the hydraulics tab for fittings, couplers and adapters.
    Here are a few pictures of what I used.
    If you have more questions please ask.
    Bucket Grapple Project Deere 2320-new-tractor-800-jpg Bucket Grapple Project Deere 2320-new-tractor-802-jpg Bucket Grapple Project Deere 2320-new-tractor-804-jpg Bucket Grapple Project Deere 2320-new-tractor-806-jpg
    There are quick couplers that use a retaining ring to hold the coupler 1/2 in the bracket.
    These are the OEM on my John Deere. I believe they are a Pioneer Coupler.
    Bucket Grapple Project Deere 2320-new-tractor-644-jpg Bucket Grapple Project Deere 2320-new-tractor-606-jpg Bucket Grapple Project Deere 2320-new-tractor-607-jpg
    The 3/8 quick couplers from S C allow you to push or pull the outer sleeve to release the male and female halves
    Attached Thumbnails Attached Thumbnails Bucket Grapple Project Deere 2320-new-tractor-799-jpg   Bucket Grapple Project Deere 2320-new-tractor-806-jpg
  8. #48
    Join Date
    Apr 2011
    Posts
    1,174
    Erie Pa.
    Ok so you just used NPT to hose fittings and then used oversized washers to take up the space on the threaded area?
    Montana R4944
  9. #49
    Join Date
    Aug 2012
    Posts
    602
    MICHIGAN
    JOHN DEERE 2320
    Yes I did>
  10. #50
    Join Date
    Apr 2011
    Posts
    1,174
    Erie Pa.
    Yes I did>
    Hear I thought you had found some fancy sort of fitting. But that was a good idea!
    Montana R4944
Similar Threads
  1. BUCKET GRAPPLE PROJECT
    By BIG DOOLEY in forum Build-It Yourself
    Last Post: 11-24-2012, 07:21 PM
  2. Replies: 41
    Last Post: 02-26-2009, 07:16 PM
  3. Frontier/Deere grapple bucket
    By Millalien in forum John Deere Owning/Operating
    Last Post: 07-11-2008, 11:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
