Page 1 of 6 1234 ... LastLast
Results 1 to 10 of 52
  1. #1
    Platinum Member BIG DOOLEY's Avatar
    Join Date
    Aug 2012
    Posts
    602
    MICHIGAN
    JOHN DEERE 2320
    Default Bucket Grapple Project Deere 2320
    I would say the hard part of the fabrication work is over.
    Lots of little details left to do.
    I have the cylinder mounted and the rest of the work is cross supports, gussets, cylinder guard, hydraulic lines and things of that nature.
    Bucket Grapple Project Deere 2320-new-tractor-520-jpgBucket Grapple Project Deere 2320-new-tractor-521-jpgBucket Grapple Project Deere 2320-new-tractor-522-jpgBucket Grapple Project Deere 2320-new-tractor-523-jpgBucket Grapple Project Deere 2320-new-tractor-524-jpgBucket Grapple Project Deere 2320-new-tractor-525-jpgBucket Grapple Project Deere 2320-new-tractor-526-jpgBucket Grapple Project Deere 2320-new-tractor-527-jpg
    Bucket Grapple Project Deere 2320-new-tractor-433-jpgBucket Grapple Project Deere 2320-new-tractor-436-jpgBucket Grapple Project Deere 2320-new-tractor-441-jpgBucket Grapple Project Deere 2320-new-tractor-447-jpgBucket Grapple Project Deere 2320-new-tractor-455-jpgBucket Grapple Project Deere 2320-new-tractor-471-jpgBucket Grapple Project Deere 2320-new-tractor-472-jpgBucket Grapple Project Deere 2320-new-tractor-480-jpgBucket Grapple Project Deere 2320-new-tractor-482-jpgBucket Grapple Project Deere 2320-new-tractor-515-jpgBucket Grapple Project Deere 2320-new-tractor-518-jpg
    2012 JD 2320, HOMEMADE CANOPY, 54" FRONT BLADE, 54" MID DECK MOWER, HYDRAULIC ANGLE 60" REAR BLADE, QUICK HITCH, STAINLESS FRONT MOUNT SPRAY TANK W/BOOM, 200CX LOADER W/ 61" BUCKET, HOMEMADE BALLAST BOX,HOMEMADE BUCKET GRAPPLE
    1998 "BIG DOOLEY" Chevy K3500 Crew Cab (36.000 miles & counting)
    United Steel Workers Union 12934
  2. #2
    Elite Member DT86's Avatar
    Join Date
    Dec 2010
    Posts
    4,028
    SW VA
    Kubota 9540, RTV 900 and David Brown 885.
    Default
    This would of been a lot easier to follow if you would put all the updates in the same thread instead if starting a new one each day. Just saying.
    With that said it looks really good.
  3. #3
    Join Date
    Aug 2012
    Posts
    602
    MICHIGAN
    JOHN DEERE 2320
    Default Re: Bucket Grapple Project Deere 2320
    Quote Originally Posted by DT86 View Post
    Thanks
    I hear ya.
    I'll add to the same string.
  4. #4
    Join Date
    Aug 2012
    Posts
    602
    MICHIGAN
    JOHN DEERE 2320
    I have done a little more work this morning.
    Added a 3rd grapple tine and put in some gussets.
    Now I need to round the front off a little and run one more pipe support across to tie in some upper gussets.
    Bucket Grapple Project Deere 2320-bracing-jpgBucket Grapple Project Deere 2320-new-tractor-529-jpgBucket Grapple Project Deere 2320-new-tractor-531-jpgBucket Grapple Project Deere 2320-new-tractor-532-jpgBucket Grapple Project Deere 2320-new-tractor-535-jpgBucket Grapple Project Deere 2320-new-tractor-540-jpgBucket Grapple Project Deere 2320-new-tractor-541-jpg
  5. #5
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    Default
    It is looking good. Are you going to reinforce then bucket any where it bolts on?
  6. #6
    Join Date
    Aug 2012
    Posts
    602
    MICHIGAN
    JOHN DEERE 2320
    Thanks
    Yes I have been thinking so.
    The metal is thin enough that the holes would easily get distorted if the bolts loosened up due to flexing in the metal.
    Eliminate the flex before any damage gets done.
    I can weld some sheet steel patches inside the bucket.
    also
    I think I will try and drill the pins in the center and tap threads to mount the zerks at one end of the pins.
    I will just have to cross drill some holes for the grease to escape.
  7. #7
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    Quote Originally Posted by BIG DOOLEY View Post
    Thanks
    also
    That is what I was thinking.
  8. #8
    Join Date
    Aug 2012
    Posts
    602
    MICHIGAN
    JOHN DEERE 2320
    Any more weight and I might need to shop for a turbo charger.
    This might have to do.
    I need a nap
    Bucket Grapple Project Deere 2320-new-tractor-545-jpgBucket Grapple Project Deere 2320-new-tractor-546-jpgBucket Grapple Project Deere 2320-new-tractor-547-jpgBucket Grapple Project Deere 2320-new-tractor-548-jpg
  9. #9
    Elite Member
    Join Date
    Jul 2006
    Posts
    4,409
    Northwest, WA
    Looks good BD.
    Has that bucket ever been used ?, looks brand new, still with sticker intact.
    ::Sent from a standard desktop keyboard::
    My Photobucket
  10. #10
    Join Date
    Aug 2012
    Posts
    602
    MICHIGAN
    JOHN DEERE 2320
    Thanks.
    Mostly hauling firewood up to the house the last month.
    It's full of redwood siding in the garage right now. I just lit a fire in the wood stove.
    I did some back blading for about an hour for my 2 neighbors and one small snowfall to clear.
    so not really.
    I thinking of calling it the Minnie Pearl bucket
    I think they used super glue to put it on.
    I know i'll have to warm the bottom of the bucket with the propane torch or get the milwaukee heat gun out to remove it.
    Bucket Grapple Project Deere 2320-new-tractor-549-jpg
Similar Threads
  1. BUCKET GRAPPLE PROJECT
    By BIG DOOLEY in forum Build-It Yourself
    Last Post: 11-24-2012, 07:21 PM
  2. Replies: 41
    Last Post: 02-26-2009, 07:16 PM
  3. Frontier/Deere grapple bucket
    By Millalien in forum John Deere Owning/Operating
    Last Post: 07-11-2008, 11:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
