Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. #11
    Join Date
    Oct 2010
    Posts
    578
    WI
    '13 Yanmar Lx4100
    Default Re: Electric window motor for snowblower help.
    Mine too, a rod connected to the top part of the chute slides through a washer on the bottom part of the chute and the spring rides on the rod to keep it in alignment.
  2. #12
    Gold Member 600rider's Avatar
    Join Date
    Jul 2007
    Posts
    361
    union city pa
    2004 kubota b7510
    I have used a window motor for many years to both rotate the chute and to deflect the snow and in my opinion they work best if you have the two wire motors and just reverse polarity so you don't need a dedicated ground. Also the rotation motor works best if you have the newer cable less type chute that has the screw that rotates the chute. That being said I used one on a cable type for years also! I will try to get pics for you tomorrow!I might have the window arm part from previous application. I will look tomorrow also. If I do you may have it for the price to ship it to Maine!
  3. #13
    Member
    Join Date
    Feb 2009
    Posts
    35
    Born and raised in the great state of Maine
    Kubota B7610HSD
    What I had planned is to weld round rod to both sides of the nut traveling the threaded rod. The brackets on the part of the deflector that moves will have a long slot just wider than the round rod welded on the nut. Im hoping that the round rod will push forward the deflector as it travels up the long slots of the brackets on either side of the nut and also allow the nut to pivot slightly as the deflector moves along the arc. The motor side I was thinking of mounting rigid, but mabey if I leave the bolts loose and allow the motor to tilt as the rod moves might work better?
  4. #14
    Member
    Join Date
    Feb 2009
    Posts
    35
    Kubota B7610HSD
    Thanks, I will keep an eye on the ice build up and I agree about a thread about projects with the little motors.
  5. #15
    Member
    Join Date
    Feb 2009
    Posts
    35
    Kubota B7610HSD
    Yeah the snowblower is the newer front mounted type only about 8 years old with the screw rotation. How did you use the window arm part along with the motor? I cant seem to picture it in my mind. Would love to see pictures if you have time. Thanks
  6. #16
    Join Date
    Jul 2007
    Posts
    361
    union city pa
    2004 kubota b7510
    I looked for the window regulator arm but could not find it. Here is a pic of the part I am talking about. Electric window motor for snowblower help.-window-regulator-jpg it is the arced part with the "teeth" on it and I removed it from the rest of the regulator and welded it to the deflector and bolted the motor to the chute.
    On my newer snowblower I used the linear actuator, here are the pics of that.Electric window motor for snowblower help.-image-jpgElectric window motor for snowblower help.-photo-jpg
    here are the pics of how I used a window motor to rotate my chute Electric window motor for snowblower help.-image-3-jpgElectric window motor for snowblower help.-image-4-jpg I put a small piece of round stock in the tube part with the screw on it and attached a love-joy coupling to that and the motor to connect the two.I have had it for 8 years and no problems! I do keep my tractor in a garage so all snow melts off but my old tractor I kept in an unheated garage but swept all snow off after each use.
  7. #17
    Join Date
    Jul 2007
    Posts
    361
    union city pa
    2004 kubota b7510
    I think I miss spoke when I said I got the linear actuator on Ebay. I am sure I got it from Surplus Center and also got the mount kit for it.
  8. #18
    Join Date
    Jul 2007
    Posts
    361
    union city pa
    2004 kubota b7510
    I went out to the garage yesterday and found my old chute of the snow blower and it had the lift arm part on it so I took some pics for ya. I remember that I had to mount the motor in a trial and error type test. The motor I mounted so that the deflector would not contact it in it's swing travel then held the "tooth bracket" and rotated it to make sure it had enough travel to move the deflector which wasn't too hard. I purchased a front mount for my kubota B7510 from a dealer that quit selling Kubota he had it in the show room and could not return "whole good" so I got it at a great discount it came with the chute and rotation screw so I converted my older blower to the newer setup and no longer use the old chute. Electric window motor for snowblower help.-image-3-jpg Electric window motor for snowblower help.-image-jpg Electric window motor for snowblower help.-photo-jpg
  9. #19
    Member
    Join Date
    Feb 2009
    Posts
    35
    Kubota B7610HSD
    Thanks for the pics! Still working on welding and fabbing some parts to try and make this work, mabey I will have a working model by summer lol.
  10. #20
    Platinum Member JohninCT's Avatar
    Join Date
    Jul 2001
    Posts
    984
    Central CT
    Struck Magnatrac 6000, Kioti DK40SE
    Quote Originally Posted by herringchoker View Post
    Jim, your idea about the threaded rod and nut sounds good in theory. You would have to mount the nut on a pivot so that the rod would not bind in it as its position changes. (The motor end should also pivot.) The speed would depend on the motor's RPM and threads per inch on the rod and nut. You may need to protect the rod and nut (motor, too) from ice and snow buildup. You are building a linear actuator!
    Yep you are reinventing the wheel so to speak, but you work with what you have available. I agree with pivot on both ends. Weld a shark fin on the back of your chute and drill a hole in it. Weld on a bolt or drill a hole thru a piece of pipe and use a bolt for the pivot at the fin. Weld the nut on the other end of the pipe. Screw your threaded rod into the nut and drive it with the window motor. Fabricate a pivoting bracket to mount the motor on and you have your linear actuator. The pipe will protect the threaded rod. You can add a grease fitting to it too if you wanted. You could also slide a larger dia pipe over to protect the threaded rod lower section when its extended.
    Or, you could just buy a linear actuator and just have to fabricate the attachment brackets at each end. Might be simpler and even cheaper in the long run.
    "I don't do landscaping... I do battle with vegetation"
Similar Threads
  1. Snowblower electric chute rotator motor resource.
    By Scaper in forum Snow Removal
    Last Post: 12-08-2012, 09:34 AM
  2. looking for detailed pics of window motor chute mods
    By tractordog in forum Snow Removal
    Last Post: 01-16-2012, 11:30 AM
  3. What is this electric motor for???
    By LD1 in forum Build-It Yourself
    Last Post: 10-23-2010, 10:46 AM
  4. Electric chute motor for snowblower
    By fototek1 in forum Build-It Yourself
    Last Post: 08-17-2009, 02:06 PM
  5. Electric motor help
    By slydog in forum Build-It Yourself
    Last Post: 12-08-2004, 01:31 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
