Results 1 to 10 of 20
12-25-2012, 10:47 PM #1Silver Member
- Join Date
- Dec 2012
- Posts
- 164
- Location
- Lucerne, IN
- Tractor
- 53' Allis WD, 54' Allis WD 45, 52' allis CA, Farmall 560, 656 , 47' Deere model A , 38' Deere model A
Log skidding machine!
She's an ugly beast, but works great minus the wide front we need to add. The bale carrier was converted to skidder attachment that I welded up. My son has skidded 24" x 60' whole oak trees. We added the loader yesterday. Should keep him from lifting the front end up as bad. He had 400 lbs. of weight on the front for counterbalance before the loader. He still was bringing the front up on some trees. Good old equipment!
12-25-2012, 10:48 PM #2Elite Member
- Join Date
- Sep 2010
- Posts
- 3,496
- Location
- PRINCE TOWNSHIP, ONTARIO
- Tractor
- MASSEY 1020 and 1945 CASE SC, 1914 1 1/2 hp EMPIRE HIT AND MISS ENGINE
Looks good. If it works thats all the counts.
"If the women don't find you handsome, they should at least find you handy" - Red Green
PRINCE TOWNSHIP TRACTOR CRUISE WEBSITE
https://sites.google.com/site/prince...torcruise/home
12-25-2012, 10:54 PM #3Veteran Member
- Join Date
- Dec 2002
- Posts
- 1,922
- Location
- Foster, RI
- Tractor
- JD 750
12-25-2012, 11:01 PM #4Silver Member
- Join Date
- Dec 2012
- Posts
- 164
- Location
- Lucerne, IN
- Tractor
Re: Log skidding machine!
12-26-2012, 06:41 PM #5
Just wondering if those bale forks are intended to prevent backflips or ?? Several years ago friend did that skidding with his 8N and luckily only broke his leg. Another guy a few miles away did the same but wasn't as lucky.
12-26-2012, 06:44 PM #6
That's a powerful machine, I can't imagine skidding a 60' tree with my tractor.
12-26-2012, 08:24 PM #7Silver Member
- Join Date
- Dec 2012
- Posts
- 164
- Location
- Lucerne, IN
- Tractor
Just think you could do with a new front wheel assist tractor and a loader!
We drop the tree , pull it to an area where we cut all the smaller limbs out of the top, then pull it out into an open field. We can save time not needing to drag brush. Some of the larger trees had to be cut in two pieces, but most were able to be pulled out whole.
12-26-2012, 08:28 PM #8
12-27-2012, 06:03 PM #9Member
- Join Date
- Dec 2012
- Posts
- 29
- Location
- BRF WI
- Tractor
- 55 Super John Deere 5303
How hard is that to put on and off the tractor.
12-27-2012, 09:42 PM #10Silver Member
- Join Date
- Dec 2012
- Posts
- 164
- Location
- Lucerne, IN
- Tractor
It's just a 3 point bale attachment modified with a piece of 2x6x3/8 walled tubing made as a top link. It's easy to hook up. We skidded out another 15 trees today, the loader made a big difference on stability. We have a wide front we are rebuilding to replace the narrow front.
Similar Threads
Log skidding cone
By Chilly807 in forum WeldingReplies: 20Last Post: 03-29-2010, 11:35 AM -
Log Skidding Tongs?
By VT365 in forum AttachmentsReplies: 25Last Post: 12-22-2007, 08:40 PM -
Log skidding
By MikeBeers in forum Mahindra Owning/OperatingReplies: 12Last Post: 03-25-2006, 10:37 AM -
Log Skidding with DK45
By krazykioti in forum Kioti Owning/OperatingReplies: 12Last Post: 04-21-2004, 11:21 PM -
Log Skidding
By vongiese in forum Build-It YourselfReplies: 46Last Post: 12-27-2002, 10:35 PM
