Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 28
  1. #11
    Elite Member
    Join Date
    Oct 2003
    Posts
    3,620
    the Steernbos (Holland)
    Zetor 3011, Zetor 5718
    Default Re: CDP MID600 "backhoe build" project
    Quote Originally Posted by Dongerosa View Post
    never used a backhoe before...So, what would be the best/most used pattern for controls to learn on....ISO or SAE or other?
    SAE is standard in North America, ISO is standard in Europe.
    Its a PITA when the machine acts differently than your autopilot operates it... so when in North America, get used to SAE so you're not a danger to workers when you ever use a 360 trackhoe.
  2. #12
    Join Date
    Jan 2008
    Posts
    87
    wellington ohio
    7510 bota...RTV 900
    Quote Originally Posted by ptgdigger View Post
    Looks great ! I like that the pieces have the modern style as see on a commercial backhoe unit.
    You mention CDP so I assume either the pivot weldments were bought from them or cut to their template, I just find it odd that the ends of the pivot weldments are straight were the get welded to the tubes. I was always taught that you should never weld straight across a boom or arm on ground engaging equipment, commercial machines like Case or Deere go to extremes to eliminate straight welds on their hoes and front loader arms. I realize this is a much lower stress application , it's just that CDP seems to have done a good deal of engineering on this and I'm surprised they left it out.
    Picture for clarity of what I'm talking about: Attachment 299830
    Ray
    Ray,
    Yep, bought the plama cut parts, and now that you mention it, I've seen that on hoes. Thanks for the marked up photo.
    I do have to say that all other hoe kits are the same way (straight across) the arms welding. But it would make a better looking and strong unit if they did add the taped to center side plates.
  3. #13
    Join Date
    Sep 2011
    Posts
    132
    near Johnstown PA
    Allmand TLB 425
    Quote Originally Posted by Renze View Post
    Backhoes never had a "standard" in North America, I've probably run somewhere over 50 different backhoes in my life and Cat was the only one I've ever run with SAE, Deere has always used ISO , although they never called it ISO, Case has always had their own proprietary 3 stick setup w/foot swing. If you ordered a new Case you could get "Case" controls or "Deere" controls, no mention of Cat controls. Of course Cat backhoes are not popular in this area , there are probably 10 Case and 7 Deere for every 1 Cat in my region of the US.
    All the arguments started when mini excavators started to get popular, the controls were wrong ! Not really but all the old operators thought so because if it had 2 sticks it should work like Deere controls, there were a few rough years there but now we see most of the mini's coming with electric over hyd controls which can be easily switched and Case and Deere are offering excavator style controls in their backhoes as well.
    Ray
  4. #14
    Elite Member
    Join Date
    Oct 2003
    Posts
    3,620
    Interesting !! Here in Europe we have "European" controls (ISO) and everybody hated the odd machine with "American" controls (SAE) so therefor my idea that in the USA every machine would have "american" controls
    My Bobcat bobtach 905B backhoe (converted for tractor use) is ISO, i allways though they switched the hoses for the European market, but they might just sell it with ISO controls in the USA too...
    I am bidding on a bankruptcy auction, an excavator superstructure for a Unimog. awkward to use on a Mog, but cutting it up and welding it to a sideshift 3pt frame it might be a very nice and strong backhoe for farm use, so i can sell the Bobcat to a campsite groundskeeper or other people with money but no stamina to use a shovel.
  5. #15
    Join Date
    Sep 2012
    Posts
    1,384
    Ottawa Ontario
    Kubota B3300SU
    Ray
    Case or Deere but not Cat? Interesting, controls here they are often referred to as Cat or Deere but no Case. Sometimes I'll run across someone calling them English (ISO) or Montreal (SAE) as french is often 'backward' of English. Seems the most natural to me that the bucket & stick are the same control and boom & swing are the other just purely by the way they are mounted ----> bucket is mounted to stick.
  6. #16
    Join Date
    Sep 2011
    Posts
    132
    near Johnstown PA
    Allmand TLB 425
    Quote Originally Posted by CDN Farm Boy View Post
    I couldn't agree with you more , if it were up to me we would throw all the other ones out, the nature of most construction dictates that someone is going to be in the area of the hoe placing pipe , setting a manhole or a valve and having multiple controls is an issue of safety. In our trades union system if you get called to a job you have no idea what you'll be operating until you get there as many contractors use rentals these days.
    Ray
  7. #17
    Join Date
    Jan 2008
    Posts
    87
    wellington ohio
    7510 bota...RTV 900
    Hard to believe no USA standard...Guess I'm going to have to let my elected officials know...i know they can pass a bill to fix this and have some more freebee to give away from my tax dollars!!!!!...lol
    Mea culpa
  8. #18
    Join Date
    Jan 2008
    Posts
    87
    wellington ohio
    7510 bota...RTV 900
    A little painting yesterday...
    CDP MID600 "backhoe build" project-20130129164732-painted-bucket-jpg
    also got 0.035 wire for welder to do some 3/16 thickness welding.
  9. #19
    Elite Member
    Join Date
    Oct 2003
    Posts
    3,620
    Modern track hoes are CAN controlled so you can choose ISO or SAE controls without switiching servo hoses on the sticks.
  10. #20
    Elite Member
    Join Date
    Oct 2003
    Posts
    3,620
    Looks like you need to turn up the amps on your welder. ?
Similar Threads
  1. Replies: 9
    Last Post: 12-31-2012, 04:03 PM
  2. "Red Clay" determining concentration to build on
    By AlanB in forum Related Topics
    Last Post: 07-18-2010, 11:31 PM
  3. BX2660 and B3030 TLB on the way...Barlows "build" pictures coming soon
    By imajeepnut in forum Kubota Buying/Pricing
    Last Post: 11-29-2009, 08:11 AM
  4. CDP BACKHOE BUILD
    By SLOWMANDOWN in forum Build-It Yourself
    Last Post: 05-09-2009, 08:45 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
