Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 28
  1. #11
  2. #12
    Veteran Member Redbug's Avatar
    Join Date
    Aug 2004
    Posts
    2,021
    Columbia, SC
    Kubota L3830HST
    Default Re: Make hyd hose "shield" yourself
    I have bought some of the spiral sleeving like that for my hydraulic hoses. Now I will have to give your technique a try and build one of those jigs.
    On the ends of the spiral sleeving after it is wound around the hydraulic hose I use a tie wrap to secure it from coming unwrapped.
    Dave
    "If your sport does not put grease, blood, or dirt under your fingernails, then it's just a game!"
  3. #13
    Join Date
    Apr 2011
    Posts
    736
    Jackson, NY
    none
    I'm trying to figure out if your jig is made on an angle or is it just the pics? I'm also trying to figure out how to make it motorized!
  4. #14
    Bronze Member graydog111's Avatar
    Join Date
    Mar 2012
    Posts
    95
    Mustang, OK
    5 Gravelys, 1963 4010 & 1950 B John Deere, Great Dane ZTR
    That is a great tool. How do you turn it or how do you turn the PEX tubing? It looks like the cutter could be mounted in a lathe and let the lathe turn. I would want someone with a hand on the switch ready to turn it off if necessary.
  5. #15
    Elite Member Rustyiron's Avatar
    Join Date
    Mar 2011
    Posts
    4,198
    Lakes Region, Maine
    M 9540 Kubota
    A lathe (slow, metal) is an excelent idea, I was thinking of an electric pipe threader. I stick it a vice and turn the tubing and it feeds in at a consistant rate, no reason it would not work by spinning the cutter.
  6. #16
    Super Member TomSeller's Avatar
    Join Date
    Jan 2013
    Posts
    8,694
    JD, Massey, Kubota, Case
    Default
    This is a great concept but the original configuration is about as far as I would take it. How much of this do you need anyway? The angle appears to be obtained by the blade being offset from the grinder wheel when it was ground down.
  7. #17
    Join Date
    Mar 2011
    Posts
    4,198
    Lakes Region, Maine
    M 9540 Kubota
    It really only takes a few minutes to make 8' or so, I only use it in chaffing or wear locations.
    I'd be happy to try to give some more pics or a measurement or 2 if someone wants to copy it. Pretty simple, it worked on the first shot at it and if a guy had a vertical mill, he could make something that looked much better
  8. #18
    Platinum Member jwmorris's Avatar
    Join Date
    Oct 2007
    Posts
    705
    Rusty, everyone that looks in BIY wants to copy it. More pics are always welcome. After that you will shortly see a PTO powered version.
  9. #19
    Veteran Member chopped's Avatar
    Join Date
    Dec 2008
    Posts
    1,871
    New England yankeee
    Id lover to see more pics maybe even a utube of it in action.
    Quote Originally Posted by Rustyiron View Post
  10. #20
    Join Date
    Mar 2011
    Posts
    4,198
    Lakes Region, Maine
    M 9540 Kubota
    Sorry, I kept forgetting to take some better pics during the day (light). It is as simple as it looks, I'm just going to make a list of things to keep it simple.
    1 The angle is 20* to make the cut in the pipe for the washers (mounting surface) this angle controls the width of the spirals. On 1" well pipe, the spirals are about 1 1/4" wide. With the small 1/2", it's more like 5/16.
    2 Those round things are just big washers, about 3" across (you'll need to "egg" them out to accomodate the angle)
    3 That "cutter" is a small chunk of a wide sawzall blade, the cutting "hook" is just cut with a small grinder with a cut off wheel.
    4 I welded some pretty heavy lumber banding to the lower washer to act as a spacer (equal to the cutter thickness) as well as a guide to keep the cutter from wanting to rotate when cutting. The banding is just the first thing that I found in the shop that was close in thickness to the cutter.
    5 The thumbscrew is to hold a smaller pipe inplace when cutting smaller tubing. This keeps it down & against the cutter, when cutting the (blue) 1" water pipe, it works just fine in the 11/2 main black pipe.
    It feeds it's self through, I just use a pipe wrench on the "in" side of the tubing, with the fixture in a vice. Can't think of much else to tell you, I just "cobbed" this together and it was done. If you had some milling equipment you could make a nice recess for the blade, and instead of those "egged" out washers, a nice milled oblong hole. I used the sawzall blade figuring that it was pretty hard and should hold an edge.
Similar Threads
  1. Best way to make "land" a "yard"
    By extrakt0r in forum General Lawn & Garden
    Last Post: 02-01-2012, 10:42 AM
  2. How to make a yard/barn cat "chicken safe"?
    By MossflowerWoods in forum Rural Living
    Last Post: 12-07-2011, 10:03 AM
  3. Replies: 13
    Last Post: 05-31-2009, 08:50 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
