Results 1 to 10 of 22
02-03-2013, 04:03 AM #1Gold Member
- Join Date
- Jan 2012
- Posts
- 294
- Location
- Southern Oregon
- Tractor
- Kioti DK45SE Hst
Just another DIY tractor canopy
Kioti DK45SE HST w/ backhoe, forks, PHD, box blade, chipper. Living off-grid, Listeroid 6/1 backup, masonry stove, thermal mass H2O storage
"Those who would give up Essential Liberty to purchase a little Temp Safety, deserve neither Liberty nor Safety." Ben Franklin, 1775
"The 2nd Amendment is the RESET button of the US Constitution"
02-03-2013 04:03 AM # ADS
02-03-2013, 06:08 AM #2Elite Member
- Join Date
- Dec 2007
- Posts
- 3,675
- Location
- Ohio
- Tractor
- JD 5520, 790 TLB-- Kub L4300, B7800, MX5100
Re: Just another DIY tractor canopy
Looks great and yeah, I need to build one myself. Sure is nice to keep out of the sun.
Any lights?******
Don't sweat the small stuff...
02-03-2013, 06:28 AM #3
Good Job! Looks great.
Phil. from Mass.
2008 Kioti ck20 with 380 hours
New to me 2011 K120 loader
02-03-2013, 10:48 AM #4
Looking Good! I can't believe the prices of canopies either.
The more I want to get something done, the less I call it work..........
02-03-2013, 11:02 AM #5Veteran Member
- Join Date
- Sep 2007
- Posts
- 1,428
- Location
- Doniphan, Mo.
- Tractor
- Kubota L4240, B7800 & BX2660
Looks good and it well get the job done. In the summer time I can't believe the differents in temp they make.
02-03-2013, 02:05 PM #6Gold Member
- Join Date
- Jan 2012
- Posts
- 294
- Location
- Southern Oregon
- Tractor
- Kioti DK45SE Hst
Thanks for the comments! Yes, I added both front & rear lights, just didn't realize no pics yet. I'll take a few more pics & post later.
02-03-2013, 04:19 PM #7
I like it. Could you provide a few details on the materials used?
02-03-2013, 05:31 PM #8Elite Member
- Join Date
- Oct 2004
- Posts
- 4,933
- Location
- east wells,vt
- Tractor
- 1986 MF 1040, 1942 Farmall A, 1949 Farmall Super A
Good Evenin schweizer,
Simple and functional, I like it ! Great idea using the loader frame a couple of holes, and threading the ends of the rod.
Nothing like staying out of the sun on those hot days !!!
scotty
,,,course,,it is gas,and gas is,,well,gas,,so,,but it kills the @#$$ oughta them yellow jackets,,,thingy
http://www.tractorbynet.com/content/...onth-scott_vt/
02-03-2013, 08:34 PM #9Gold Member
- Join Date
- Jan 2012
- Posts
- 294
- Location
- Southern Oregon
- Tractor
- Kioti DK45SE Hst
Sure, KennyG: it's all just material I had lying around.
Roof of 1/2" plywood, doubled up in the stressed areas or where there would be multiple screws for lights, etc.
Border of 1" x 1 1/2" ceder.
3" U-bolts, 2x4"s under and above distribute the stresses.
Everything glued and screwed w/ polyurethane glue (Gorilla glue).
Painted with 2 coats of rubberized RV roof coating/primer.
Top coat of dark grey Rustoleum spray paint.
Without the front supports, it would have worked fine, but it vibrated a bit.
I had some 1/2" threaded rod which fits perfectly inside EMT conduit, and I don't have an EMT bender so the 1/2" is easier to bend.
The holes in the loader frame were pre-drilled. I just bent some long bolts into 90 deg angles. The bolt heads fit quite snugly into the EMT with minimal grinding of the heads with an angle grinder. I was planning on securing them with J-B weld but didn't have to.
Been a 'Niner fan all my life, but this game is hard to watch.
MarcusKioti DK45SE HST w/ backhoe, forks, PHD, box blade, chipper. Living off-grid, Listeroid 6/1 backup, masonry stove, thermal mass H2O storage
02-03-2013, 09:15 PM #10Veteran Member
- Join Date
- May 2006
- Posts
- 2,095
- Location
- Lexington, SC
- Tractor
- 2001 John Deere 790 4x4, bar tires
That's a nice canopy, but what happens when you want to remove the loader??? Seems kind of problematic since the front of the canopy will have no support, if the loader was removed.
I bought a golf cart canopy last fall and plan to adapt it on my JD 790 before summertime gets here. Still working out the design the frame for it.Nothing could be finer than riding my JD790 in South Carolina!!
2001 John Deere 790 4x4 with Model 70 FEL, 5ft International World Agritech bush hog, 5ft Wallberg BB, 5ft Frontier disc harrow, Leinbach PHD with 9" & 12" augers, King Kutter II 60" Rototiller, Leinbach middlebuster, Leinbach #11 Field Cultivator, boom pole, custom 3pt handi-hitch, clamp on bucket forks, Pat's Easy Change.
Nothing runs like a Deere, or smells like a John....
Similar Threads
DIY dump trailer for my tractor
By MJPetersen in forum Build-It YourselfReplies: 24Last Post: 09-25-2012, 08:55 PM -
Yet Another DIY Canopy
By Sherweld in forum Build-It YourselfReplies: 8Last Post: 12-09-2010, 07:59 AM -
I would like to get a canopy for my tractor?
By Scratchnbell in forum CustomizationReplies: 36Last Post: 03-17-2009, 11:45 PM -
DIY Tractor Weights
By TBAR in forum Build-It YourselfReplies: 10Last Post: 03-23-2004, 07:34 PM -
DIY Tractor Lights
By TWINKLE_TOES in forum CustomizationReplies: 10Last Post: 04-09-2001, 09:23 PM
