Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 59
  1. #21
    Join Date
    Dec 2007
    Posts
    555
    Default
    I will take plenty of pics, have another project to get in the shop so the walking around is probably all I will get done this weekend. I came to the quick conclusion I need to order the hollers, roll of plastic and drip tape. Just can't eyeball it all yet.
  2. #22
    Join Date
    Dec 2007
    Posts
    555
    Default
    Well crap I had to quit drinking, and it has really slowed my creative juices. I am starting back on this this weekend. I plan to cut a old 3 point grader in two to make the wings and want to make them adjustable. The frame needs to be 5 foot wide to get the 4 foot roll inside the frame and make a mounting point for the wheels and covering arms.
    Now without the beer I get a headache every time I do this.
    I have a question. We have trouble finding regular 12 inch hillier type disks around here. There are however plenty of the rubber 10 inch wheels used on planters to be had. Do you think they would work as well?
  3. #23
    Join Date
    Dec 2007
    Posts
    555
    Default
    Little completed today, got the form picked up and finalized some measurements. It is under way.
    Attached Thumbnails Attached Thumbnails Anyone built a raised bed shaper with a plastic mulch layer?-image-2675654533-jpg
  4. #24
    Join Date
    Sep 2012
    Posts
    104
    Southwick,MA
    Pasquali 993 w/FEL, Economy2414 w/FEL
    Default Re: Anyone built a raised bed shaper with a plastic mulch layer?
    Yup, built one last year!
    Mine would have worked better with a heavier MIL spec of plastic, but used what I had, lightweight UV resistant saran-wrap. The frame for the unit was the lower section of a machine skid, 10" discs stole from another project, water-irragation tube feeds thru broken piece of pipe from pop-up shelter.
    Anyone built a raised bed shaper with a plastic mulch layer?-img_0404-jpgAnyone built a raised bed shaper with a plastic mulch layer?-img_0405-jpg
    Shadow
    Growing older is... MANDATORY, Growing up is... OPTIONAL
  5. #25
    Join Date
    Dec 2007
    Posts
    555
    Default
    Cool, I am building my fame similarly. I put a bed shaper on mine that consists of that pan above and a 6 foot grader blade split in half and put in the frame as wings to pull dirt into the pan. I need to shorten the pan some as it measures 48 inches as is and that won't leave any mulch to press down. So I am thinking I will take 2 inches off and taper it so it is adjustable up and down. I will take a few more pix tonight.
  6. #26
    Join Date
    Dec 2007
    Posts
    555
    Default
    Another mock up pic. I have the frame pieces cut.
    Had to add an equipment pic. Old royal bandsaw still going strong! Still get coolant everywhere but blades last!
    Attached Thumbnails Attached Thumbnails Anyone built a raised bed shaper with a plastic mulch layer?-image-4026344892-jpg   Anyone built a raised bed shaper with a plastic mulch layer?-image-1318564206-jpg
  7. #27
    Join Date
    Dec 2007
    Posts
    555
    Default
    Some more today. Still lots to do!
    Attached Thumbnails Attached Thumbnails Anyone built a raised bed shaper with a plastic mulch layer?-image-2467555709-jpg
  8. #28
    Join Date
    Apr 2009
    Posts
    51
    Western,Md.
    IH 244,JD4300, 2-JD 4040s,JD2020,JD1020,8N Ford,990 David Brown,3JD318s
    Rio Grande; Not tryin to tell you how to do it,But you need to kinda create a funnel effect from your wings to the shaper as dirt will go over top of it if you dont
  9. #29
    Join Date
    Dec 2007
    Posts
    555
    Default
    Thanks for the suggestion. Already in the works, I ran out of plate. I plan to put a scoop on the top to knock anything that comes up back down. I wasn't real thrilled with the stringers from the 3 point lower links back to the pan attachment but it needed the rigidity. Frame wise very strong now. Still lots to do. Keep suggesting. I never even seen one of these in person just in pix.
  10. #30
    Join Date
    Dec 2007
    Posts
    555
    Default
    Forgot the pic
    Attached Thumbnails Attached Thumbnails Anyone built a raised bed shaper with a plastic mulch layer?-image-3572095916-jpg
Similar Threads
  1. Plastic mulch layers and raised bed equipment
    By Reyer Farms in forum Ag Tractors & Machinery
    Last Post: 01-16-2015, 08:10 AM
  2. plastic mulch layer
    By cpenn in forum Build-It Yourself
    Last Post: 02-25-2011, 12:31 PM
  3. Making A Mulch Layer?? and Bed Shaper?
    By znowybird in forum Build-It Yourself
    Last Post: 02-19-2008, 02:08 AM
  4. bed shaper/mulch layer (Buckeye Tractor Co)
    By psuedofarmer in forum Attachments
    Last Post: 03-06-2007, 01:24 PM
  5. Help please, plastic-mulch layer and bed shaper
    By Steve_Carver in forum Attachments
    Last Post: 09-11-2001, 03:16 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
