Page 3 of 7 FirstFirst 123456 ... LastLast
Results 21 to 30 of 67
  1. #21
    Join Date
    Jun 2011
    Posts
    176
    central,wi.
    TYM 350
    Default Re: How To Cut Half Inch Steel?
    A 4 1/2" grinder with a .045 disc will do the job. The trick is to score a line acrose then use a back and forth movement. If you try to cut straight thru in one pass the disc gets too much contact area and doesn't cut as well.
  2. #22
    Gold Member
    Join Date
    Nov 2005
    Posts
    491
    Colebrook, N.H.
    Kubota L3830HST
    Just wanted to report that I got the cutting edge cut down this afternoon. I used an .045" cutoff disk in my 4.5" grinder, and it worked great. I had managed to get a nice straight groove across before the Sawzall blade pooped out, and I just kept making passes back and forth as it went down. As the blade got way down in the cut, it started to get grabby and hard to hold steady. I had the handle screwed onto the right side, I guess because I'm left-handed. I switched the handle to the left side and that made it easy to control, all the way through, untill the end flopped off. Then I switched to a regular grinding wheel and took the sharp edges off. Didn't take long at all. I set it on a couple of sawhorses outside the garage, and with a stiff breeze I didn't need a mask. Used goggles, though. Those sparks are rough on the eyeglasses. I compared the used disk to an unused one, and it had only lost 1/8" of it's diameter. It was a number 27 disk. Still don't know what the difference is between type 1 and type 27. They're both metal cutting blades.
    Thanks again to everybody that responded with suggestions, you guys are great!
    -Jim
  3. #23
    Join Date
    Sep 2012
    Posts
    1,208
    north shore MA.
    Default
    type 1 is just a flat disc.
    type 27 has a depressed center.
    Dan H.
  4. #24
    Platinum Member Reyer Farms's Avatar
    Join Date
    Sep 2012
    Posts
    655
    Lena, ms
    Mahindra 5010
    Default
    Sorry to be late, a Lennox brand reciprocating saw blade is awesome for your application. I have not used any that cut better or faster. Glad you got it cut.
  5. #25
    Join Date
    May 2004
    Posts
    108
    you people have something against a torch? or you like doing things the hard way?
  6. #26
    Join Date
    Jan 2011
    Posts
    708
    Westmoreland County PA
    Fords
    Quote Originally Posted by jimainiac View Post
    \I don't have a cutting torch, and I'd like a smooth cut anyway.
    this is why
  7. #27
    Join Date
    Sep 2012
    Posts
    655
    Lena, ms
    Mahindra 5010
    Default
    Quote Originally Posted by notme View Post
    The torch happens to be my favorite way to cut steel.
    How To Cut Half Inch Steel?-image-3243928742-jpg
    Not my cleanest cut ever but it gets cut again for elevation. 1"
  8. #28
    Super Member /pine's Avatar
    Join Date
    Mar 2009
    Posts
    7,540
    Even though I have a cutting torch I would have used the same method as the OP...merely because it would be EASIER than running out hoses and bottles and then putting them away again...for such a small task...
    And BTW...not everyone has a torch but most do have electric grinders
    Slash Pine
    blunt and succinct yet sincere I don't suffer fools and morons...in the immortal words of Popeye..."I yam what I yam"
  9. #29
    Super Star Member Kyle_in_Tex's Avatar
    Join Date
    Oct 2002
    Posts
    10,914
    Giddings, Texas
    JD 4310,JD5420
    Hate to say it, but if you have sparks actually hitting your goggles, you are getting plenty of metal dust. Dirty sooty boogers.
    One of these days....One of these days...
  10. #30
    Super Member crazyal's Avatar
    Join Date
    Dec 2003
    Posts
    7,002
    Northern Vermont
    Kubota, Case, Deere
    The reason why a torch wasn't used was because the cut would have required a 4 1/2" grinder to smooth it out. If anything it would have taken longer because of how jagged the cut would have been.
    Kubota L4240,Case 580K backhoe, Case 450 Dozer, Deere X500
Similar Threads
  1. Replies: 21
    Last Post: 12-07-2012, 09:37 AM
  2. Replies: 47
    Last Post: 08-06-2011, 09:22 AM
  3. steel casters, good price, 4 inch
    By texasjohn in forum Projects
    Last Post: 07-14-2010, 01:47 AM
  4. Cut your loading time in half?
    By BTDT in forum Trailers & Transportation
    Last Post: 10-10-2006, 12:31 PM
  5. cut sunshade in half
    By TractorDale in forum New Holland Buying/Pricing
    Last Post: 06-13-2006, 10:45 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
