Results 31 to 40 of 63
02-06-2013, 10:33 PM #31Super Member
- Join Date
- Feb 2006
- Posts
- 6,764
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
Re: How To Cut Half Inch Steel?
This side of 40
JD2010, Kubota L3450/FEL w SK QC, L2550 w FEL
Mahindra 7520 [Pinky] /FEL w Skid Steer QC/w Tilt Tatch & BH, BX1500 [Mighty Mouse]
IH37 Baler, Hesston Haybine, JD Rake
Bushog, Flail,
SK Tilt Tatch
, KK tiller, Rhino rear blade, Post driver, post auger, chipper, pallet fork, Grapple/Loader Buddy, Homemade Splitter/DC Welder
02-07-2013, 02:03 AM #32Super Member
- Join Date
- Feb 2008
- Posts
- 7,738
- Location
- somewhere usa
- Tractor
- stuff
for cuts like this I use either a torch or a 14" chopsaw, I prefer the torch as it is alot quieter. Both methods work very well and are quick.
02-07-2013, 09:51 AM #33Bronze Member
- Join Date
- Jul 2012
- Posts
- 94
- Location
- St.Albans,Maine
- Tractor
- TYM T451,bolens G214.John Deere 440CID,Shaver sc25 stunpbuster,woods750 backhoe,wallenstien splitter,woods bb60 mower,woods 60"tiller,countryline tiller,99 international 4700 car carrier
Take a 1/8 drill bit. drill a series of holes then use your cut off wheel lot less time you have to dodge sparks
02-07-2013, 10:11 AM #34Bronze Member
- Join Date
- Jul 2012
- Posts
- 94
- Location
- St.Albans,Maine
- Tractor
Just a suggestion.When ya don't have the means you do what ya gotta do.I would cut it for free with my plasma cutter if he were close enough.
02-07-2013, 10:22 AM #35Member
- Join Date
- Oct 2012
- Posts
- 33
- Location
- Red Deer, Ab
- Tractor
- Minneapolis, Farmal, Tafe, homebuilt
Me too.
OTOH, the cut from my 14" Dewalt chopsaw is even smoother than the plasma cut.
0.065" cutting wheels in any one of the 4 angle grinders around my shop would give a cut quality nearly as smooth as either of the the big chop saws.
FWIW, I personally would never attempt to cut AR cutting edges with any kind of bandsaw or recip saw - too hard on the blade. But then I have 4 or 5 other, faster means to cut this kind of stuff.
02-07-2013, 12:49 PM #36Gold Member
- Join Date
- Nov 2005
- Posts
- 408
- Location
- Colebrook, N.H.
- Tractor
- Kubota L3830HST
CNC Dan, thank you for clearing up the mystery. I checked my stack of cutting disks, and the flat ones say type 1, the depressed centers say type 27, like you said. I looked at the label on the grinding disks and they said A-24 on the labels. Is that a code for the size or shape, also?
I think that even if I had a cutting torch or some of the other tools mentioned, in this instance the cutoff wheel was the best tool for the job, all things considered. It was a real eye-opener for me.-Jim
02-07-2013, 12:59 PM #37Silver Member
- Join Date
- Sep 2009
- Posts
- 165
- Location
- Western KY
- Tractor
- Kubota M6800 w/1600 hrs., Case Farmall 95 w/800 hrs., Long 2510 w/1100 hrs, Cat 236B2 Skidsteer w/1000 hrs
02-07-2013, 01:07 PM #38Gold Member
- Join Date
- Sep 2012
- Posts
- 342
- Location
- north shore MA.
yep. 24 grit, A luminum oxide
Dan H.
02-07-2013, 01:13 PM #39Gold Member
- Join Date
- Nov 2005
- Posts
- 408
- Location
- Colebrook, N.H.
- Tractor
- Kubota L3830HST
Jeez, that was quick! Thanks for the info. I'm always curious about designations on tools, equipment, etc. I figure the more you know about the stuff you're using, the better. Knowledge is power!
-Jim
02-07-2013, 05:42 PM #40Member
- Join Date
- May 2004
- Posts
- 27
put the right guy on the torch and u wont need all that grinding...its a skill in itself but nice cuts can be made with the right operator and a clean tip...a quick brush with the grinder to get rid of a lil slag is all.
Similar Threads
How / Who / What can bend this 3/8 inch plate steel bracket back to shape?
By Botabill in forum Parts/RepairsReplies: 21Last Post: 12-07-2012, 09:37 AM -
Recommendations, please - Half inch hammer drill
By Zxyrthe in forum ProjectsReplies: 47Last Post: 08-06-2011, 09:22 AM -
steel casters, good price, 4 inch
By texasjohn in forum ProjectsReplies: 0Last Post: 07-14-2010, 01:47 AM -
Cut your loading time in half?
By BTDT in forum Trailers & TransportationReplies: 11Last Post: 10-10-2006, 12:31 PM -
cut sunshade in half
By TractorDale in forum New Holland Buying/PricingReplies: 5Last Post: 06-13-2006, 10:45 AM
