Page 6 of 7 FirstFirst ... 34567 LastLast
Results 51 to 60 of 63
  1. #51
    Elite Member Redneck in training's Avatar
    Join Date
    Nov 2008
    Posts
    4,192
    South Central Iowa
    TYM 330 HST with FEL
    Default Re: How To Cut Half Inch Steel?
    If you want to use it as a weight I would sell or trade it. You could sell it and then make weight from concrete. Hardened edges are hard to come by.
  2. #52
    Join Date
    Apr 2006
    Posts
    2,159
    western NC
    Ventrac, Steiner
    Frank, are you trying to say that you cant cut a 1/2in x 5in piece of hardened metal cleanly with a o/a torch or plasma, or that nobody can.
  3. #53
    Gold Member
    Join Date
    Jan 2010
    Posts
    334
    New Hampshire
    Kubota 4310 Kubota RTV900
    How To Cut Half Inch Steel?-powermax45-edge-angle-003-jpgPlasma cut on 3/8 steel. I wouldn't call it terrible and I see no need to grind it. Cut with a Powermax45 from Hypertherm. 30 inches per minute cut speed.
    Jim
    Quote Originally Posted by Frankdozer View Post
    Your absolutly correct. BUT, he wanted and needed, for his application, a nice........neat............straight.............c ut. If he cut it with a torch or plasma cutter the cut would be terrible and he would be required to grind it. I repeat...............All other ways would fail to meet his needs............................................. .................................................. ...........................Frank
  4. #54
    Gold Member
    Join Date
    Jan 2010
    Posts
    334
    New Hampshire
    Oh, and here is some heavier stuff cut with same plasma...3/4" steel on the left, 1" on the right....with bevels cuts as well. The hardness of the steel has no effect on plasma cutting...I cut AR500 plate often.
    Of course not everyone has a plasma.....however most that have one will do a 4 second cut like the OP was doing.....for free.
    Jim
    Attached Thumbnails Attached Thumbnails How To Cut Half Inch Steel?-img_2850-jpg   How To Cut Half Inch Steel?-img_2305-jpg
  5. #55
    Join Date
    Sep 2012
    Posts
    1,208
    north shore MA.
    Default
    Quote Originally Posted by jimcolt
    <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=303919"/>
    Jim
    even my powermax30 did a passable job on a 1/2 x 5 snowplow cutting edge. Wasn't sure it would do it. Nice surprise that it could.
    Dan H.
  6. #56
    Platinum Member Buckgnarly's Avatar
    Join Date
    May 2012
    Posts
    529
    West topsham VT
    Kioti DS3510
    Quote Originally Posted by jimcolt View Post
    Jim
    Holy crap, was that by hand or a table?!?!
  7. #57
    Veteran Member xring100's Avatar
    Join Date
    Dec 2012
    Posts
    1,470
    Livingston County, Michigan
    Kubota M8540, ZD1211 60"
    Jim
    Wow I don't think i could use a cut off wheel and hand grinder and get a cut that smooth
    Dave
  8. #58
    New Member
    Join Date
    Feb 2013
    Posts
    1
    Big Spring, Texas
    Big One
    Anybody know what it would take to cut old pieces of oil pipe? We have about 20 pieces of 40' pipe that is about 10" outer diameter with walls that are between 1/2" and 3/4". I have thought of trying to use that as fence posts or to build deer blinds, but I didn't know how to cut it.
  9. #59
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    27,420
    Branson, Mo.
    Kioti DK35se Hydrostat
    Jim
    Dang Jim that is pretty, If you tried to "clean it up" you would just "mess it up" that is beautiful.
    James K0UA
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN .
  10. #60
    Elite Member
    Join Date
    May 2005
    Posts
    2,604
    Balls Creek, NC
    New Holland Workmaster 50, Ford 4610 SU
    When I purchased a front end loader for my NH 1720 the brush guard supplied by the manufacturer would not clear the loader arms when in use...
    My dealer did not install the brush guard due to this...
    My remedy was to cut out a notch in the guard with my dad's portable metal cutting band saw...
    It was a Milwaukee that was so old that the rubber bands that go around the drive wheels were dry rotted...
    A new blade and bands repaired the unit and the results were great...
    I have used that portable band saw on several other projects and it has performed flawlessly...
    The only downside is you are limited to the throat clearance of 4"...
    This is my go to tool for cutting metal if I can get around the throat clearance issue...
Similar Threads
  1. Replies: 21
    Last Post: 12-07-2012, 10:37 AM
  2. Replies: 47
    Last Post: 08-06-2011, 10:22 AM
  3. steel casters, good price, 4 inch
    By texasjohn in forum Projects
    Last Post: 07-14-2010, 02:47 AM
  4. Cut your loading time in half?
    By BTDT in forum Trailers & Transportation
    Last Post: 10-10-2006, 01:31 PM
  5. cut sunshade in half
    By TractorDale in forum New Holland Buying/Pricing
    Last Post: 06-13-2006, 11:45 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
