Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    Silver Member dkhntr04's Avatar
    Join Date
    Sep 2010
    Posts
    140
    Northern MN
    Deere 3720 Cab
    Default FEL Grapple Build
    I thought I'd share the grapple I built for my FEL. I just finished it up this week and used it for the first time today. The task at hand was taking down 11 mature spruce trees that died this year. The grapple worked excellent and the trees were down, sectioned, and stacked in a pile in 5 hours. The grapple sure made quick work of the brush and logs versus using pallet forks, chains, and dragging brush by hand. For those who are curious, I don't have my grille guard on because the subframe for my 59" snowblower is still in place. I have the snowblower mounting system for the older generation tractors, and the blower would hit the guard at full lift if I left the guard on. I didn't feel like swapping them out for an afternoon of work especially with snow in the forecast for tomorrow.
    The grapple is 46" wide. The reason for the odd width is so I could incorporate the last tine as the side of the SSQA mount. I didn't think I'd miss 2" compared to the standard 48" width. It weighs in right about 375-400# based on calculated weights of the materials. The cylinder is a 2.5"x8" I had laying around from a snowplow lift I made for a previous tractor. The tines are .5x3" A-36 and tube is 3"x.25". The grapple arm is 2.5"x.375" with an assortment of metal for the cross-tubes, teeth, and reinforcements. The pivots are 2" wide, greasable, and ride on custom turned 5/8" pins. Welds are all 6010 and/or 7018. The hydraulic hose setup is temporary for now, I will be adding permanent hoses and couplers on the FEL cross-tube later.
    Here are the pics. Enjoy!
  2. #2
    Super Member murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    6,461
    Ohio
    Kioti DK 40-Massey ferguson 135-Simplicity Conquest
    Default Re: FEL Grapple Build
    Really nice job on that.
  3. #3
    Join Date
    Sep 2010
    Posts
    140
    Northern MN
    Deere 3720 Cab
    A couple more pics.
  4. #4
    Veteran Member Marveltone's Avatar
    Join Date
    Jun 2010
    Posts
    1,063
    Somewhere north of Roseau,MN
    Fordson Major Diesel, Ford 1510, John Deere L111
    Nice build! Looks like you really did your homework on this. Love the action shots!
    Joe
    Ford 1510
    Du-Al 105 Loader
    "The Thumb" Grapple
    Bush Hog RBC60 Rear Blade
    Woods HC54 Rotary Cutter
    Tarter 5' Heavy-Duty Hinge Back Box Blade
    Buhler Farm King Y600 Snowblower
  5. #5
    Join Date
    Sep 2010
    Posts
    140
    Northern MN
    Deere 3720 Cab
    Quote Originally Posted by Marveltone View Post
    Joe
    Thanks. I did most of the design work on Autocad to make sure everything would fit properly. I had been thinking about how I wanted to build this for about a year before I started, so I had ample time to really think things through.
  6. #6
    Join Date
    Jul 2007
    Posts
    710
    WV
    John Deere 1026R
    Default
    Looks good... and familiar ;-)
  7. #7
    Join Date
    Sep 2010
    Posts
    140
    Northern MN
    Deere 3720 Cab
    Quote Originally Posted by swick1 View Post
    Click image for larger version.
    Apparently we think alike! Yours looks nice from what I can see. The horizontal teeth on the grapple was actually a last-minute add on. It wasn't until I saw the whole thing together that I decided they were needed.
  8. #8
    Silver Member bigblock's Avatar
    Join Date
    Jul 2003
    Posts
    129
    SW Georgia
    JD 5105M
    That looks great, nice build! I have always wanted a grapple but just can't afford it right now.
    Where are you getting the hydraulic power? Rear remote or third function mid?
  9. #9
    Super Member k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    7,747
    Branson, Mo.
    Kioti DK35se Hydrostat
    That looks great, I wish I had the fortitude to start that big of a project..
    Oh, I have been told to not eat the pink snow
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. Home-Brew 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. Satisfied Everlast PA160 welder owner
  10. #10
    Gold Member BuzzardA91's Avatar
    Join Date
    Jul 2012
    Posts
    318
    West Granby CT
    JD 4105. 375 Backhoe. 2005 Polaris Ranger
    That looks awesome. I wish I had a 1/10th of those skills you needed to build that.
Similar Threads
  1. Replies: 15
    Last Post: 02-18-2012, 11:31 PM
  2. Grapple Build
    By woodlandfarms in forum Power Trac
    Last Post: 06-24-2011, 11:48 PM
  3. Boom Grapple Build
    By Oasis in forum Build-It Yourself
    Last Post: 01-01-2011, 01:09 PM
  4. My Grapple build
    By farmguy4 in forum Build-It Yourself
    Last Post: 04-02-2009, 09:49 PM
  5. Grapple build
    By 2310 guy in forum Build-It Yourself
    Last Post: 07-15-2007, 08:24 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
