Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 32
  1. #11
    Silver Member Brimfield's Avatar
    Join Date
    Jun 2004
    Posts
    143
    Mass
    Kubota L 3800
    Default Re: quick & fun steel target (standing)
    Any one build one that will stand up to large rifle rounds like 30 06 or 308? I would like to build one. What is the best way to heat treat/harden steel at home? I don't mind spending $39 for one that will take hand gun but I have seen them for $150 and up that warn the frame is soft steel and would suffer from hits.
    Kubota L 3800 loader and back hoe, Allied Farm King 66" Snow Blower, clamp on forks 13 hp home made log splitter
  2. #12
    Platinum Member jwmorris's Avatar
    Join Date
    Oct 2007
    Posts
    705
    The last 3 in my post are rifle targets. 3/8" ar500 steel, good up to 300 win mag but don't shoot rifles at steel closer than 100yds.
    Handgunsports.com is where I get my hard plate steel from.
  3. #13
    Super Member SPIKER's Avatar
    Join Date
    Jun 2002
    Posts
    5,000
    Ohio, Jeromesville, Ashland County
    Jinma 284
    Like JW said, it is the type of steel, the harder steels are good are resisting the rounds better but can also chip if hit just right or get warn. 100 or 1000's of rounds will work harden the metal to eventual fatigue. I used 3/8" T1 for the smaller targets on mine which the T1 is mostly Wear Resistant but also better at anti fatigue over time. I will be using them for any high velocity rounds.
    You can get small hunks of steel bar in about any dimension so you can buy small hunks in thicker materials even A36 in 1/2" thick will stand up to most lead rounds without a lot of damage. Now toss in some armor piercing rounds I'm not sure what you can buy at the local machine shop that will stand up to those
    Mark
    I may remember why I went to the other end of the shop, I'm just afraid once I get there I'll forget how to get back!
  4. #14
    Join Date
    Jun 2004
    Posts
    143
    Mass
    Kubota L 3800
    I take it the rebar will stand up ok. I would just think it would deflect a round. Guess I will be looking around for some 500 steel. It has been way to long since high school but isn't there a way to heat treat steel that could be done at home or would that be brittle and prone to break.
  5. #15
    Join Date
    Jun 2002
    Posts
    5,000
    Jinma 284
    The Rebar is actually not what you are supposed to be shooting at but the stray round should not cause too much damage & if it does it is cheap & easy to replace.
    As far as heat treating standard A36 while yes you can but not much point unless it was all ya had & the cost and time to heat treat would far exceed the same size hunk of better stuff.
    again using thicker material works in place of harder stuff as well so dont try to get too complicated. Go after it and have fun smashing some rounds against the metal. If it dont hold up slap a NEW hunk in place of the other one in about 30 min...
    Mark
  6. #16
    Join Date
    Oct 2007
    Posts
    705
    again using thicker material works in place of harder stuff as well...
    I have to disagree with that statement. As soon as the surface of a steel plate is not flat, it will start sending fragments back to you. Not to mention 1" thick hot roll steel won't even contain some rounds.
  7. #17
    Join Date
    Jun 2002
    Posts
    5,000
    Jinma 284
    JW: you missed the "Previous Post" where I stated the following
    those shots you posted are of obvious armor piercing rounds and typically are not going to be in civilian home owner firing range use.
    Also anytime your target back stop gets damaged they should be replaced so if the target starts to CUP or Deform the chances of a bounced back or ricochet or target fragmenting gets higher.
    Also last post from the first page I also included warning about FMJs & Metal targets. I'll re-quote that.
    FYI I never recommend using FMJ rounds for metal targets as they can retain their shape better & ricochet much easier off the metal. Not to mention can damage the metal targets.
    Mark
    Last edited by SPIKER; 02-17-2013 at 03:10 PM. Reason: added in quotes from previous posts above & page1
  8. #18
    Join Date
    Oct 2007
    Posts
    705
    Sorry about that, took it out of context. I agree, with cast lead at non magnum pistol velocities and 3/8" mild steel are fine together.
  9. #19
    Join Date
    Apr 2006
    Posts
    2,175
    western NC
    Ventrac, Steiner
    I can say with certainty, that a 243 with a 60gr hollow point will completely sever 1/2in rebar at 100yrds. Found that out by slipping a paper target over a electric fence post while zeroing a scope.
  10. #20
    Join Date
    Jun 2004
    Posts
    143
    Mass
    Kubota L 3800
    So I do not know the makeup of rebar but I saw some sites telling how to harden steel at home I am thinking if I put rebar in my anthracite coal stove and get it red "cherry hot for some time I could put it in water. If I then heat it to a lower temp "blue"? And then put it in water this would eliminate the brittle factor. Or do I need to let it air cool. I have never seen steel go "blue" before it goes red so I assume they are talking about the 1st stage when you see color. I found a company that sells 500 steel targets good to go but I am afraid to weld them on to rebar and soften the steel. Could I spot weld them on with an arc welder taking my time? And the only alternative I saw was hanging targets using chain but I would think the bullet from a .308 would cut the chain before it deflected it.
Similar Threads
  1. Snow Equipment Owning/Operating Fun in the snow & h2o
    By TC33DRon in forum Snow Removal
    Last Post: 02-26-2010, 06:20 PM
  2. Quick disconnect fittings - brass? steel?
    By RobA in forum Kubota Owning/Operating
    Last Post: 01-27-2010, 10:45 AM
  3. Hoods & Fenders, Plastic & Steel, Mix & Match?
    By BluRidgDav in forum John Deere Buying/Pricing
    Last Post: 09-16-2005, 12:01 PM
  4. NEW & FUN attachments for PT 425
    By bubenberg in forum Power Trac
    Last Post: 09-27-2002, 09:40 PM
  5. Fun Fun Fun---Cub Scout Day Camp
    By RobertN in forum Related Topics
    Last Post: 07-16-2002, 09:01 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
