DIY Bead Breaker
   / DIY Bead Breaker #11
On smaller tires, I have used my log splitter with some wood blocking. Works quite well for me.
   / DIY Bead Breaker #12
On large tires I just use one of the teeth on the backhoe. For smaller truck sized tires I have one of the cheap Harbor Freight bead breaker, tire remover tools.
   / DIY Bead Breaker
I very nearly bought one of those until I read that they were prone to failure, bending as I recall. So I got creative instead.
   / DIY Bead Breaker #14
Here is another way to do it, from when I didn't have a FEL.
   / DIY Bead Breaker #15
I have a tire machine at the farm but needed to change a valve stem a while back here at the house, just laid a section of channel iron on the tire and drove up on it. Simple, cheap and quick.
   / DIY Bead Breaker #18
If you own a log splitter and some scraps of metal that will also do the trick! (if U can lift and position the tire, that is)
2025 New/Unused Wolverine Snow Pusher (A51573)
2025 New/Unused...
PAIR OF 5' PIN ON FOLD UP TRAILER RAMPS (A51247)
PAIR OF 5' PIN ON...
UNUSED FUTURE FT380 STAND ON SKID STEER (A51247)
UNUSED FUTURE...
4004 (A51691)
4004 (A51691)
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
2023 John Deere 8R410 MFWD Tractor (A53472)
2023 John Deere...
