Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 35
  1. #11
    Elite Member Zebrafive's Avatar
    Join Date
    Aug 2010
    Posts
    3,841
    South West MI
    John Deere 2030, John Deere 6415
    Default Re: welding table top what thickness needed /
    I was able to buy a scrap table with a heavy top, guessing at least 1" thick (too lazy to run to the shop to measure it ) maybe 3' x 6'
    I put steel wheels on it and a "foot jack" to keep it from rolling.
    You need more than 1-2 inch overhang.
    With a thick top you can drill and tap holes or even just drill thru and use bolts and nuts to hold things if required.
    John Deere 2030 JD 245SL Loader
    John Deere 6415 mfwd JD 640SL Loader
  2. #12
    Platinum Member bikerdib's Avatar
    Join Date
    May 2010
    Posts
    644
    Texas
    Kubota B3300SU
    I just finished making one for myself. I used what I had on hand. 2X2X3/16 angle frame around the top edge (turned so I have the 2" clamping space around the edge), legs of 2X2X1/8 inch and running gear of 3" steel wheels (two of those being swivel. The top is two pieces, three foot long by ten inch wide 1/2 inch plate run parallel with a 4 inch gap between for clamping space and that also gives me a gap to use a O/A torch. To help when doing something longer than will fit on the table I have two roller stands to support long items.
    '12 John Deere X320; '10 Kubota B3300SU with 504 loader with Kubota Quick Attach, Home built forklift carrier that fits on the FEL or 3 point, Landpride SGC0660 grapple, 3 point grader blade, 3 point dump bucket, BH77 backhoe with BXpanded quick attach for buckets, BXpanded trenching bucket, BXpanded ripper, 3 point subsoiler, Landpride RCR 1860 rotary cutter, 3 point log splitter, 3pt quich hitch, Pat's Easy Change, and hydraulic top link
  3. #13
    Elite Member
    Join Date
    Sep 2009
    Posts
    2,697
    Up State S.C.
    AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs
    I don't have a table. AlI can afford is a small frame, about 2'x5' and I don't want a vise or anything else attached to the top. Mounted objects tend to snag any big object I lay on there. On a huge table a vise might be fine.
  4. #14
    Super Member
    Join Date
    Aug 2004
    Posts
    6,847
    North of Mtl,Que,Can (Ste Adele)
    MT180D
    One fellow around here made his table top out of 4 x 4 angle stock with about a 2" gap between the parallel angles.
    The ends were also from the same angle stock.
    His intent was to be able to use clamps just about anywhere. Seems to work just fine.
    The table in question was about 12 ft long by about 3 ft wide with 6 HD legs.
    I might add that his work was largely stair cases, gates, signs and such as against smaller precision items.
    But then I often noted that he'd tack weld his parts to the table rather than clamp and simply grind away the tacks prior to the next job.
    He also had his welder permanently grounded to the table.
  5. #15
    Join Date
    May 2010
    Posts
    644
    Texas
    Kubota B3300SU
    I have never liked grounding the table unless I was also going to tack weld the work piece to the table.
  6. #16
    Veteran Member troutsqueezer's Avatar
    Join Date
    Sep 2010
    Posts
    1,308
    Pilot Hill, CA.
    Kubota B21
    I've been using a 1/4" top, works fine but I don't pound heavily on it.
    I don't ground the table either. Ground clamp always goes as close to the welding joint as possible, clamped to the workpiece itself.
    - Dennis
    Once you see the bandwagon, it's too late.
  7. #17
    Elite Member
    Join Date
    Oct 2003
    Posts
    3,629
    the Steernbos (Holland)
    Zetor 3011, Zetor 5718
    Mine was an old glue press of which i cut off the upper structure. 3/8" of deck on 4" C channel frame is enough meat to forge on the edges.
  8. #18
    Elite Member RedNeckGeek's Avatar
    Join Date
    Jan 2011
    Posts
    3,207
    Butte County, California
    Kubota L3240D HST, RTV900
    Last year I got really lucky and found a nice table on Craigs List only a few miles from here. It's about 4' x 5' with a half inch thick mild steel top supported by heavy wall steel tube for a frame. It rolls on 6" steel casters with locks on two of the wheels. There's even a shelf underneath that's almost as big as the table. Before that I had to make do with a 2' x 3' wooden shelf with a piece of 1/8" aluminum for a top. Not much good for pounding, couldn't tack anything to it, and I melted places on it a couple of times. Still, it was better than nothing. If cost was no object, I'd build one at least 4' x 8' on a heavy steel frame, caster mounted, with a stainless steel top at least 3/4" thick. But that's probably off in the next life...
  9. #19
    Super Member flusher's Avatar
    Join Date
    Jun 2005
    Posts
    7,409
    Sacramento
    Getting old. Sold the ranch. Sold the tractors. Moved back to the city.
    Quote Originally Posted by troutsqueezer View Post
    Same here. Don't see the need for 1/2" thick tops if you brace the 1/4" top properly.
  10. #20
    Super Star Member
    Join Date
    Feb 2008
    Posts
    12,465
    somewhere usa
    Deere 110tlb, 4520, x749, L130
    If you spend much time using tables you will find there isn't a perfect table for everything. I have used everything from a card table to super heavy 30' long tables with 2" plate tops. Usually I don't have what I need at the time but manage to get by with what I have. Right now my tables suck and I need to build a better one.
Similar Threads
  1. Table brakes for welding table
    By Bday in forum Welding
    Last Post: 02-22-2013, 09:03 PM
  2. welding table
    By mechanic in forum Welding
    Last Post: 11-14-2012, 06:43 PM
  3. Replies: 10
    Last Post: 09-23-2011, 09:26 AM
  4. Welding table from a cast iron tablesaw top?
    By jeffreythree in forum Welding
    Last Post: 03-25-2011, 10:49 PM
  5. Welding Table Top
    By BB_TX in forum Welding
    Last Post: 05-20-2003, 10:25 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
