Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. #1
    New Member
    Join Date
    Apr 2012
    Posts
    12
    Latrobe Valley, Victoria
    Fergies TEA20 (80mm Bore, vertical oil filter) & FE35 (3 cyl Perkins)
    Default Rail Iron Smudger
    Who has built or used one of these, or similar.
    Idea is to use it to smooth rough ground in the spring and autumn.
    The photos show a rough mock up of the layout planned.
    It will have a 3 point hitch with a floating top hitch (similar to most slashers or brush hogs) the plan being to use it behind a MF35.
    The 35 lifts the weight with relative ease and still steers ok.
    I favour setting the front and rear level with the centre rail forward of centre
    Rail Iron Smudger-smudger-mf35-001-jpgRail Iron Smudger-smudger-mf35-001-3-jpgRail Iron Smudger-smudger-mf35-001-4-jpg
  2. #2
    Super Member mjncad's Avatar
    Join Date
    Aug 2006
    Posts
    5,114
    In the civilized First World
    A couple
    Default Re: Rail Iron Smudger
    Welcome to TBN John. I suggest you do a search for "landplane" as we call them here as that might give you some ideas. A number of members have built their own.
    Paraphrasing Douglas Adams - So long and thanks for all the bacon.
  3. #3
    Super Member
    Join Date
    Dec 2007
    Posts
    9,724
    Central Ohio
    JD 5520, 790- Kub L4300, B7800, MX5100, M7040
    All that weight should do a great job of scraping the surface, especially if not a lot of rocks. Please post photos along the way if you can.
    May I be the kind of person my dogs think I am,
  4. #4
    Join Date
    Apr 2011
    Posts
    645
    Jackson, NY
    none
    I would build something in the shape of a V or two that way all the dirt removed will get brought back in and re used for low spots. Otherwise I think that the dirt will just spill out the sides or ride up and over and become a problem.
    Something more like this: Land Leveler - FreedomŽ 3pt. Implements
  5. #5
    Elite Member
    Join Date
    Jun 2012
    Posts
    3,723
    Waynesboro Va
    John Deere X310, JD LA 145
    My dad built one and had the blades on a slight angle so the dirt ect. would spill off of one side. We ran it so that the front blade cut pretty good the middle one less and the back blade would barley drag the ground. Worked very well. I like the angle.
  6. #6
    Join Date
    Sep 2012
    Posts
    1,208
    north shore MA.
    Default
    you might want to lookup "split log drag"
    Dan H.
  7. #7
    New Member
    Join Date
    Apr 2012
    Posts
    12
    So Landplane is what you call these things.
    Searched for Landplane as mjncad suggested.
    Lots of land planes, land graders and drags out there and some great ideas from tractorbynet members. Found these interesting.
    Rail Iron Smudger-dsc00121-jpgRail Iron Smudger-image-4196853292-jpgRail Iron Smudger-p1000915-jpg.
    but this one from oreok has sent me back to the drawing board.
    Rail Iron Smudger-plane-1-jpgRail Iron Smudger-plane-4-jpg
    Now to figure out how much angle and protrusion to put rail iron on.
  8. #8
    Platinum Member catdozer's Avatar
    Join Date
    Sep 2011
    Posts
    508
    Indiana
    Bobcat CT235
    Default
    There are many build threads on landplanes. The one picture you posted is the one i built, very simple design
    Attached Thumbnails Attached Thumbnails Rail Iron Smudger-forumrunner_20130220_095229-jpg
    Bobcat CT235 with Deere Imatch, And a very bad addiction of attachments
  9. #9
    Platinum Member travlitt's Avatar
    Join Date
    Jun 2012
    Posts
    608
    Texas
    8050C Branson, Branson 2400 8N Ford Round Fender John Deere 110 3 60" ZTR mowers, a bunch of ride on mowers 8' Brush hog 15' Bat wing
    Pic. of the one that I built.Rail Iron Smudger-008-jpgRail Iron Smudger-009-jpg
  10. #10
    Veteran Member Redbug's Avatar
    Join Date
    Aug 2004
    Posts
    1,975
    Columbia, SC
    Kubota L3830HST
    I remember seeing someone on these forums that made a land plane attachment that hooked onto the bottom of his box blade. He could take it on and off the box blade. Pretty ingenious. Do any of you guys remember it? That would be a good way to go.
    Dave
    "If your sport does not put grease, blood, or dirt under your fingernails, then it's just a game!"
Similar Threads
  1. rail on db2g
    By ronwol in forum Owning/Operating
    Last Post: 08-15-2012, 11:00 AM
  2. Rail mulcher
    By Heavyduty in forum Land Clearing Equipment
    Last Post: 01-17-2011, 05:00 PM
  3. 3 rail fence
    By kwolfe in forum Projects
    Last Post: 01-01-2011, 05:09 PM
  4. rail road rail
    By gumper48 in forum Attachments
    Last Post: 12-26-2008, 11:31 PM
  5. 3 rail split rail supplies
    By Scrounger in forum Build-It Yourself
    Last Post: 04-10-2005, 02:07 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
