Results 1 to 10 of 23
02-25-2013, 11:32 AM #1Bronze Member
- Join Date
- Sep 2010
- Posts
- 83
- Location
- Central NYS
- Tractor
- Kubota B9200
Pole puller
Well here I am again asking the you folks for ideas. I have a flag pole that is 2 1/2" in diameter that has a busted pulley. I need to pull this pole to replace it. I have a B9200 with a loader. Thanks in advance, smoker
02-25-2013, 11:52 AM #2Super Member
- Join Date
- Nov 2011
- Posts
- 6,460
- Location
- Ohio
- Tractor
- Kioti DK 40-Massey ferguson 135-Simplicity Conquest
Re: Pole puller
Choke it and pull it up with your loader
Murph ------------ Sent from my HP laptop
Nothing runs like a Deere when being chased by a Kioti
02-25-2013, 12:00 PM #3Gold Member
- Join Date
- Nov 2012
- Posts
- 462
- Location
- mansfield,Il
- Tractor
- john deere
Re: Pole puller
How tall ?
02-25-2013, 02:22 PM #4Bronze Member
- Join Date
- Sep 2010
- Posts
- 83
- Location
- Central NYS
- Tractor
- Kubota B9200
Re: Pole puller
It's ~20' above the ground and ~ 4' deep. I'm sure I put in into another pipe but the ground here is kinda stiff and I can't expose the base. I've tried using a chain before on similar problems and it just mostly slips. You can bet I'll build something that allows me to pull a bolt and pivot it down.
02-25-2013, 05:58 PM #5
Re: Pole puller
Drill a 1/2" whole through both sides, put a 3/8" bolt through whole, use chain on bolt to lift.
Later on use the hole you drilled as the pivot point for new install.
02-25-2013, 06:16 PM #6Bronze Member
- Join Date
- Sep 2010
- Posts
- 83
- Location
- Central NYS
- Tractor
- Kubota B9200
Re: Pole puller
Simple and effective. Thank you Sir, smoker
02-25-2013, 07:35 PM #7Veteran Member
- Join Date
- Jan 2010
- Posts
- 1,834
- Location
- Mostly East Central Oklahoma
- Tractor
- JD cut
Re: Pole puller
A couple of high-lift jacks, one on each side, may work better than using your FEL.
02-25-2013, 08:12 PM #8Bronze Member
- Join Date
- Sep 2010
- Posts
- 83
- Location
- Central NYS
- Tractor
- Kubota B9200
Re: Pole puller
Have several jacks around but not that type. Got some pretty long bolts from a previous adventure that should do the trick. Thanks, GM
02-25-2013, 08:29 PM #9Elite Member
- Join Date
- Oct 2006
- Posts
- 3,243
- Location
- N.E., Ohio
- Tractor
- GC2310, Toro Reelmaster 5100D
Re: Pole puller
Theoretically, if you put one extension ladder on each side, and had two guys of basically equal weight going up them at the same time, you could simply change the pulley from the ladders.
I would make sure the feet are of the ladders are flipped up, and pressed into the soil. And, tie the ladders off on both sides of the pole at the top.
You could even fab up something attach to the top of one, or both of the ladders to hold them in place at the top.
02-25-2013, 08:57 PM #10Platinum Member
- Join Date
- Feb 2007
- Posts
- 673
Re: Pole puller
have some kid crawl up it, when in High school the kids would climb and write there names on the ball all the time,
put the loader on one side and a ladder on the other and you should be able to fix it, if your concerned about the ladder rope the top of ladder an and tie it off, use two ropes and go out to the sides to keep it from slippig side ways
Similar Threads
Tree puller
By melanelly in forum Build-It YourselfReplies: 11Last Post: 02-19-2012, 04:43 AM -
best rock puller?
By Groo in forum Construction EquipmentReplies: 3Last Post: 07-11-2010, 06:50 PM -
Log puller
By Egon in forum Related TopicsReplies: 18Last Post: 05-02-2009, 02:19 PM -
Help with sapling puller?
By TMcD_in_MI in forum Build-It YourselfReplies: 42Last Post: 01-01-2007, 12:04 AM -
3 pt pipe puller??
By JohnnyD in forum AttachmentsReplies: 3Last Post: 06-07-2002, 07:20 PM
