Page 3 of 7 FirstFirst 123456 ... LastLast
Results 21 to 30 of 61
  1. #21
    Super Member radioman's Avatar
    Join Date
    May 2008
    Posts
    5,878
    Ontario, NY
    Kubota BX24
    Default Re: Ideas on how to move a shed...
    LOL at jimmyj comments!! I moved my similar shed like op's on my property from one side to other. I elected to use my 16 ft trailer with rails and just jacked it up and cribbed with firewood I had laying around and used my tractor to pull trailer with shed on it. I put it down the same way I lifted with firewood cribbing. I didnt want to drag it over my nice lawn. It didnt take long -- I used a floor jack to lift it as high it would go and crib. next corner do same thing over and over till it was done all by myself in one day.
  2. #22
    Gold Member
    Join Date
    Nov 2011
    Posts
    289
    Canton, TX
    JD 301A and yanmar YM2500
    Default
    3pt with a drawbar, 2 drawbar hooks, and some chain if you have good runners. It should only take 1/4" gr43 or better chain to pull it and the 2 drawbar hooks to keep from pulling the runners together too much if you have to lift the front. Much less driving backwards. The other tractor if needed could lift with their fel
  3. #23
    Silver Member mowin's Avatar
    Join Date
    Sep 2012
    Posts
    123
    upstate ny
    JD 3320
    Quote Originally Posted by jimmyj View Post
    I like this thread. I can imagine all of us standing around at the OP's place with our coveralls on, bud or coffee in hand discussing how to move the old shed.
    "Well I remember back in 78 when ole Clem Smith had to move a shed just like this. Cept his shed had tin siding cuz Merle Barcklay used to keep chickens in it and the weasels was a chewin thru the wood siding."
    "Geez, I'd forgot about ole Merle, what happened to him after the wife moved out and he left for Tuscon..."
    5 hours later no work would have commenced!!!
    LOL.. but we would have a good time..
    Im going to talk to a firend of mine who has a log truck. My thoughts are..Wrap some straps around it, put in on his rig, and drive 30 seconds to it's new home and unload....Will have to brace the inside near the roof line from side to side so it doesnt collapse the sides when lifted. The shed is a barn style, so there are no eves to speak of
  4. #24
    Join Date
    Oct 2011
    Posts
    115
    What about taking a piece of metal siding, clamping some angle iron pieces across the front of it to hook a chain to, then pick up one side of the shed, slid it under there, and then pull it like it's on a sled. You'd just need to bend the front end of the metal up a little to keep it from digging in.
  5. #25
    Elite Member dex3361's Avatar
    Join Date
    Aug 2008
    Posts
    3,571
    N. of Charleston WV
    Kubota L4400-1 HST,FEL, 3x3 remotes, TNT. BX1500 54 mmm
    Spreader pipes would work well above the building if you are going to use a log truck as a crane. It would keep the chains off of the sides of the building. I had to move this building off of posts and across the field. It is a 8 x 12 building
    Randall
    1Timothy Chapter 2:
    3 For this is good and acceptable in the sight of God our Saviour;
    4 Who will have all men to be saved, and to come unto the knowledge of the truth.
    5 For there is one God, and one mediator between God and men, the man Christ Jesus.
  6. #26
    Super Member
    Join Date
    Jul 2009
    Posts
    8,576
    SW WA
    Kubota BX2360
    How many friends and relatives do you have?
  7. #27
    Platinum Member Carl Bert's Avatar
    Join Date
    Jul 2010
    Posts
    865
    Rockland county, New York
    Kubota B26, John deere X595
    Default
    Quote Originally Posted by bcp View Post
    YouTube Link: http://www.youtube.com/watch?v=o83W0gj_CRE
    Amazing what we could achieve when working together. Great video
    2010 Kubota B26 TLB w/hyd thumb. 2004 John Deere X595 w/62" MMM.
    Carl Bertuzzi
  8. #28
    Join Date
    Oct 2011
    Posts
    184
    Greene, NY
    TL80a, Ford 4000, Super H, F 12, F14
    helium ballons - lots of them
  9. #29
    Join Date
    Jul 2010
    Posts
    865
    Default
    I moved a 12x14 shed about 200' with heavy PVC pipe. We jacked up one side, laid about 6 or 8 4" pipes under it and let it back down onto the pipes. I attached a sling to my tractor and the shed and started to pull. As the shed rolled forward we placed more pipes from the back, in the front, and continued until we reached its new home. It worked perfect, without any damage.
    I don't suggest it for your situation, as I would imagine the transition from the yard to the street and back to the yard again, would be difficult. I think using the trailer is your best bet. Good luck
    Carl Bertuzzi
  10. #30
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    I moved a shed on my property with 4x4's underneath of it. If you had 3PH pallet forks you may be able to pick the front up and carry it to make it pull easier.
Similar Threads
  1. How to move a large shed?
    By avc8130 in forum Projects
    Last Post: 01-10-2012, 10:31 AM
  2. move the shed
    By schmism in forum Projects
    Last Post: 05-31-2010, 12:10 AM
  3. Shed move
    By schmism in forum Trailers & Transportation
    Last Post: 05-30-2010, 02:44 AM
  4. Shed Move
    By ceh007 in forum Kubota Owning/Operating
    Last Post: 04-22-2009, 06:16 PM
  5. How do I move my shed ?
    By Madman_Mark in forum Owning/Operating
    Last Post: 11-22-2004, 11:22 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
